Question about Toshiba Satellite Pro 4600 Notebook
Re install 98se on new hard drive
Can't get windows 98se to install on satellite pro 4600, it goes through all the rituals then just keeps failing ti accept its got windows on board, I would like to know how to reset the toshiba system settings back to the factory defaults please ??
  • Toshiba Master
  • 13,433 Answers
Did you change the question? Something is wrong with this website?? it seems to me the questions are changeing.
Posted on Mar 21, 2008
  • Toshiba Master
  • 13,433 Answers
Try a newer version, windows 2000 or xp.
Im runing windows xp on my 500mhz laptop, yours seems to be 900 witch is more than enought.
if you insist on 98se,
1st make sure your laptop starts up from cd drive from bios
to enter bios press F1 or F2 or Delete Depending on your bios.
drop me a line if you need more asisntace.
Hard drive failure
You select custom if you want to either delete any old operating systems and format the drive first. If you want to keep all your old data select Upgrade. Other wise in the custom menu select each partiton and select delete. Then select the hard drive click New, Ok and next and the install will start.
Jun 08, 2013 | Toshiba satellite c660
Toshiba Satellite Pro 4600 laptop - which Keys to reinstall all windows after a formated hard drive error?
Do you have the Recovery Disks? I hope so because if you reformatted the drive you wiped out the Recovery Partition.
Apr 25, 2012 | Computers & Internet
It is running very VERY VERY slow. I thought reinstalling windows xp and drivers may solve problem but did not. I booted the system from C drive with windows xp pro in he system. It formats the hard drive,...
You may want to check the hard drive - sounds like it may be starting to fail. When it reaches the point of not continuing does it start to click? If you hear clicking then the drive is having issues and its time for a new one.
Nov 15, 2009 | Dell Dimension 4600 PC Desktop
Toshiba Satellite Pro 4600 Says D Drive is Out Of Memory
One can only venture a guess on this one: your hard drive is partitioned into C: and D:. Physically, there's only one drive, but it might have been split into 2 separate partitions. I'd go from there.
Jun 28, 2009 | Toshiba Satellite Pro 4600 Notebook
Satellite Pro 4600 SOFTWARE CD
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?selModel=1073792275|PS460U&modelFilter=4600&rpn=PS460U&category=&selCategory=3&moid=1073792275&os=&ct=SB&selFamily=1073768667
This is all you need, for any operating system ! If you need any more help, this is my yahoo mesenger ID : szasz.hunor
Feb 01, 2009 | Toshiba Satellite A135-S2276 Notebook
Password for windows 2000 on a toshiba satellite pro 4600
burn it to a disk put it in the disk drive turn off unit then fire it up and hold down the f10 button choose from cd and follow the instructions if you can not succeed then go to best buy spend 29.99 and have the geek squad reset it for you.
Jan 28, 2009 | Toshiba Satellite Pro 4600 Notebook
Lost installation cd
ask toshiba to send one for a nominal fee.
Nov 29, 2008 | Toshiba Satellite Pro 4600 Notebook
Loud clicking
You're going to have to narrow it down by removing components. Start by removing the hard drive, if the clicking stops then you know that it's a component that needs or uses the operating system. If it stops then put the hard drive back and remove other components, CD drive, keyboard, etc... until you can either locate exactly where it's coming from or it stops. The CD drive could be the culprit, and removing the keyboard will expose some of the inner workings so you can hear it better and possibly find what it is. This isn't a simple fix, it will take a little effort, but I believe you will find the problem, this is the exact same way that I would do it if you were to bring the computer to my shop.
Jul 24, 2008 | Toshiba Satellite Pro 4600 Notebook
Can't reboot windows cd on with cd drives
If you have it available, boot to the Dell DImension Resource CD and run the diagnostics on the hard drive. From the description of you problem, you may have a failing hard drive.
Other things to check:
1. Ensure the system BIOS (F2 at boot) sees the hard drive and has the correct date and time. If the motherboard battery is failing, the time and date will not be retained when system is powered off.
2. If you are able to format the hard drive, but the windows XP installation process gives you file copy errors, then you may have a bad RAM module. If the system has 2 or more modules, take out all but 1, retry the install. If you get file copy errors again, try a different module.
3. If the Hard drive passes dieagnostics, but fails to complete a format, replace the hard drive.
Jun 01, 2008 | Dell Dimension 4600 PC Desktop
Satellite pro 4600 windows 98 fatal error
What OS are you running on the system? Did you recently install any hardware? If there is a recent hardware install, remove it and try powering on the system on.
If this fails, then you'll need the restore CDs/DVDs from the manufacturer. This will bring the laptop to it's factory default installation. Before doing so, I recommend purchasing a hard-drive enclosure for a laptop hard-drive and backup all important data.
Hope this helps :)
Nov 25, 2007 | Toshiba Satellite Pro 4600 Notebook
Toshiba Satellite Pro 4600 Notebook Logo
98 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
