Question about GE Tritonr XL GSD6260JCC Dishwasher
Detergent cup door partially opens
The detergent cup door only opens a little bit so some of the soap is left in the detergent cup after it is thru.
  • Cwattrun Mar 21, 2008
    I figured it out myself. The door on the cup does not open all the way. Here is what I did. On the back of the dishwasher door are 7 phillip head screws. Take those out and the door inner cover comes off. There are 2 pieces of black insulation that are glued to the cover. The smaller one had slid down to where it was blocking the cup door from opening all the way. Pull this black insulation off and put it back in the right place. I even put a little hot glue under to keep it from sliding again.
  • GE Master
  • 43,501 Answers
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
y
Posted on Sep 30, 2010
Soap dispenser does not open during washing
Dishwashers have a soap dispenser located on the inside of the door. When the timer cycle calls for the soap to be emptied into the dishwasher, it either sends electricity to a bi-metal switch that opens it, or it mechanically opens the soap dish. On many dishwashers, a plastic actuator arm mechanically links the timer to the detergent cup. When the timer reaches the proper time in the cycle, the timer activates a lever that opens the detergent cup. If the linkage is broken or defective, the cup stays closed after you've closed it. Check the link and repair or replace it, as necessary.
The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. If not, you probably need to replace the entire cup assembly.
Dec 07, 2017 | Dishwashers
My office's GE QuietPower 3 dishwasher detergent
heatman101
Jul 29, 2011 | Maytag Dishwasher
Soap remains in dispenser after completed cycle and dishes are not clean
Hello laura.... there are three possible causes of the dispenser not opening:
1.Timer
On many dishwashers, a plastic actuator arm mechanically links the timer to the detergent cup. When the timer reaches the proper time in the cycle, the timer activates a lever that opens the detergent cup. If the linkage is broken or defective, the cup stays closed after you've closed it. Check the link and repair or replace it, as necessary. 2. Bi-metal switch or wax motor A bi-metal switch is a simple electrical device that deforms when electricity is applied to it. The degree of this deformation can be engineered to concise standards. The timer energizes the bi-metal switch inside your dishwasher door--directly behind the detergent cup--when the detergent cup should open. When energized, the bi-metal switch deforms away from the detergent cup latch, which opens the detergent cup. If the bi-metal switch is defective, it may not deform enough to open the cup. If that happens, you need to replace it. On some dishwashers, the bimetal switch is wired through the heating element or motor circuit. If the element is broken (or open), or if the motor is drawing low current because of a low-fill situation, the bi-metal switch doesn't open properly. Newer dishwasher models use a wax motor instead of a bi-metal switch. It's a sealed unit with wax that heats up and pushes a piston through to open the door. The wax motor, controlled by the timer, mechanically opens the door. 3. Detergent cup, itself The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. If not, you probably need to replace the entire cup assembly That said, one way around this is to simply add the soap or the soap tab into the dishwasher proper, not into the cup. Joe Thanks for choosing Fixya!
Mar 13, 2011 | Maytag Dishwasher
Soap still in large container on door at end of cycle. recently had center spinner arm and main console replaced twice. doesnt clean well. residue left in cups
residue..... check lower spinner arm and clean any bits from insideit by back washing with water, also check the pump inlet and filters.....
as for soap still in container, does the soap recepticle door open... if not just place the required amount of detergent on the lower half of the door..
If the door does open and there is still soap ing the recepticle there is definitely a water problem...
you can also try to remove both the upper and lower spinners and run the dishwasher for a couple of minutes to flush out any debris or buldup inside the lines.
A good quality dishwasher cleaner may also be wothwile trying....
Dec 17, 2010 | Electrolux EIDW6305GS Builtin Dishwasher
I have a whirpool dishwasher model #du980qpd85, soap door don't open. can you tell me what makes it open and what the problem could be/
Hello ramward. There are three reasons why the soap door won't open. The first is soap buildup. This is a common problem and requires old fashioned elbow grease, and hot water, and lots of cotton swabs. That said, read on:
2. On many dishwashers, a plastic actuator arm mechanically links the timer to the detergent cup. When the timer reaches the proper time in the cycle, the timer activates a lever that opens the detergent cup. If the linkage is broken or defective, the cup stays closed after you've closed it. Check the link and repair or replace it, as necessary.
3. Bi-metal switch or wax motor A bi-metal switch is a simple electrical device that deforms when electricity is applied to it. The degree of this deformation can be engineered to concise standards. The timer energizes the bi-metal switch inside your dishwasher door--directly behind the detergent cup--when the detergent cup should open. When energized, the bi-metal switch deforms away from the detergent cup latch, which opens the detergent cup. If the bi-metal switch is defective, it may not deform enough to open the cup. If that happens, you need to replace it. On some dishwashers, the bimetal switch is wired through the heating element or motor circuit. If the element is broken (or open), or if the motor is drawing low current because of a low-fill situation, the bi-metal switch doesn't open properly. Newer dishwasher models use a wax motor instead of a bi-metal switch. It's a sealed unit with wax that heats up and pushes a piston through to open the door. The wax motor, controlled by the timer, mechanically opens the door. Joe Thanks for choosing Fixya!
Nov 21, 2010 | Dishwashers
My soap cup (using gel soap) doesn't empty and soap is also left on inside of door. sometimes this does not happen and other times it does,
heatman101
gf
Sep 24, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Soap dispenser does not automatically open up during cleaning
heatman101
Sep 12, 2010 | Hotpoint 24 in. HDA2130Z Built-in...
When I fill up both soap dispensers, only one is empty after the wash. The cover never releases the other soap. It says fill both and then cover the right side. But after the dishes are washed - the...
The electric solenoid that opens the dispenser has failed. It is possible to replace it but you will probably have to disassemble the door to do it. An alternative might be to use a detergent tablet only in the open cup. It will partially dissolve during the pre-wash and what remains to dissolve in the main wash may be enough to get the dishes clean. Try this if the cost of replacing the solenoid is too high.
Aug 25, 2009 | Dishwashers
Dishwasher detergent door won't release soap
heatman101
l
Apr 06, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Soap door won't open
The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. In case it will not solve your problem, the unit should be replaced. Good luck!
Sep 13, 2007 | Kenmore 17252 Free-standing Dishwasher
GE Tritonr XL GSD6260JCC Dishwasher Logo
303 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
