TV Trouble: Toshiba Flatscreen CRT (Brazilian model: Linha Face)
I recently purchased a 29" Toshiba CRT Flatscreen TV and I noticed that on bright white scenes with high contrast, after 10-20 seconds, small areas of blue or yellow begin to replace what was once white. Then, when I change the channel, the areas that turned blue or yellow from the previous channel remain to affect the other stations for a few more seconds, almost like round blobs, that slowly disappear with time. I have already replaced the Toshiba twice, and each new TV gives me the same problem, particularly when I view a Closed circuit TV channel (the security channel for my building), which is black and white. The black and white picture eventually develops yellow and blue areas (that were once white in contrast)... similar to when someone puts a magnet near the screen. when changing the channel, and then returning a 3 minutes later, these are gone, but they will re-develop if the TV is left on the channel. Any ideas?
  • 55 Answers
I suggest if you buy it few months ago that item is under warranty
you to call the toshiba service and try to have changed with another
one or get free service - delfo
Posted on Mar 21, 2008
SOURCE:
Samsung flatscreen CRT 21 inch TV. problem no power?
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 18, 2014 | Samsung CW29M64NS 29" TV
Where can we pawn our 29 inch tv sony not flatscreen
Welome to Fixya.
Please post back the complete model number of your TV and your location.
Thank you for using FixYa.
Aug 23, 2011 | Televison & Video
Toshiba 32D46 - Need to know weight in order to determine whether tv stand will support it safely.
Hello
Your Toshiba 32D46 model TVs weight and diamensons are
Width: 29-9/16 in. (751 mm)
Height: 25-15/16 in. (658.5 mm)
Depth: 21-3/4 in. (552 mm)
114.7 lbs. (52.0 kg)
OK
Jan 02, 2011 | Toshiba 32D46 32" TV
I had to adjust the brightness to 100% and you can still barely see it and it has a blue tint
This TV is CRT driven and when the brightness is a issue you would need to diagnose the Blue CRT and or the Fly back transformer.
Many times the transformer is not providing enough power to that CRT witch can cause this to happen.
Without the TV in front of me it would be difficult to pin point.
Also you would want to consider if the TV is out of Focus thus causing this blue tint, Here is a on line part store that can help you in purchasing the parts for the tv if your interested in Do It Yourself repair.
http://www.partstore.com/Model/Toshiba/Toshiba/42H81.aspx?p=4&z=50&c=3b663bdcbb0b5634f5cc800d37496d25&bs=Category&bd=Asc&ms=Category&md=Asc&k=#1
First if the TV is not illuminating with the brightness function you would consider at this point the TUBE "CRT" or the Fly back witch drives them.
Thanks for your questions
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 13, 2010 | Toshiba 42H81 42" Rear Projection...
Ive got a 29'' tube flatscreen that wont work no more
seems to be an issue with picture tube.Please try after changing picture tube
Jul 28, 2009 | Televison & Video
JUST HAD MY TOSHIBA FLAT SCREEN REPAIRED AND NOW AGAIN I HAVE NO PICTURE JUST SOUND. IS THERE A RECALL ON THE FLATSCREEN TV.
In these cases you should be able to see a picture by shining a bright light right next to the screen front. Do not put the light there for very long or you will end up with a permanent bright spot burt onto the screen. I have discovered that applying light pressure with a 3/8" thick rubber or plastic shim corrects a panel driver board/card solder problem with these TVs. (Removing the back is required, try light pressure against the card while wearing rubber gloves and tv is then powered on.)
Apr 20, 2009 | Toshiba 32AF43 32" TV
Hooking up a toshiba flatscreen up
Here is a link to the manual on Toshiba's site:
http://www.tacp.toshiba.com/tacpassets-images/models/32a33/docs/32a33_om_e.pdf
You should find what you need in the manual, but if you have specific questions about connecting something just ask.
Feb 15, 2009 | Toshiba 32A33 32" TV
The Contrast and Brightness on tv appears to be dark.
If this is a CRT-based TV and it's been played most of the time, you may have a bad picture tube, especially if strong red colors bleed to the right. CRT's dim with use, unlike LCD or plasma. But it could also be trouble in the video circuits - none of this falls into the DIY category, unfortunately. High voltage involved, unless you're comfortable around it and want to try turning up the screen controls inside the TV. If you do, let me know - but "no response at all" from the external adjustments points to a more serious problem.
Dec 10, 2008 | Toshiba 36AF41 36" TV
Cluster of stuck pixels
sounds like its stuck in another mode. Do you have the original remote to sdee if you can switch off the display section or the closed caption?? good Luck
Jul 28, 2006 | Toshiba 20AF43 20" TV
Televison & Video Logo
151 people viewed this question
Top Televison & Video Experts
Ekse
