Question about NetGear WGR614 Wireless Router
Unable to complete router set-up: username & password problem
The problem comes at this point in the router set-up:
The server www.routerlogin.com at WGR614v7 requires a username and password.
Warning: This server is requesting that your username and password be sent in an insecure manner (basic authentication without a secure connection).
The username password is blank, but has my VZW mobile e-mail address selectable from the drop-down menu. No combination of usernames and passwords that I have tried has worked.
I would appreciate any assistance you could give me here.
Thanks,
John
  • 19,396 Answers
Www.routerlogin.com is not asking password here, but some of their features, as online search are not working, evidently they are passing throught some kind of trouble with the website.
Here is netgear help page for your router
The search box does not work but you can open knowledge base pages.
If you need your own router default password instead: User is 'user'
Password is 'password' or '1234'
regards
Posted on Mar 21, 2008
  • 807 Answers
Maybe it needs the default.
http://kbserver.netgear.com/kb_web_files/N100651.asp
How do I set the network in my netgear N300 for my laptop?
Visit http://www.routerlogin.com. You can also use the following if the http://www.routerlogin.com does not work: Enter the following default login credentials:
  • Username: admin
  • Password: password
Then go to Wireless and chose Name (SSID): and Passphrase :
Jul 04, 2014 | NetGear N300 Wireless Router
Tip
Configuration of NETGEAR router as Access Point: The below steps illustrates the...
The below steps illustrates the usage of router's like WGR614, WGT624, WPN824 as an access point to extend the wireless network in your location. The only required setup is that you should have a DHCP server running on your network ( be it your modem or a different router).
1. Connect a computer directly to NETGEAR router on any of the four LAN ports.
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on wireless settings in the left hand side menu Under Setup.
5. Change the network name SSID to some other name.
6. Select security options as 'WEP (Wired Equivalent Privacy)'.
7. Set the 'Authentication Type' as 'Automatic' and Set the 'Encryption Strength' as 64-bit.
8. In Key 1 type a 10 digit number.
9. Apply the settings.
Click on LAN IP setup from the left menu.
1. Change the IP address of the router from 192.168.1.1 to a free IP of your existing DHCP network.
2. Also disable the DHCP of the router by unchecking the box for 'Use router as DHCP Server'.
3. Click apply and click ok for any popup message that arise.
4. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, turn off the router and restart the computer.
Now, connect the two router in the following way:
1.Connect Ethernet cable from the Lan port of the existing router/modem to the Lan port of the NETGEAR router.
2. Powercycle both the routers and your computer
3. You may connect other computers' directly to NETGEAR router or wirelessly as per your requirement.
on Mar 18, 2010 | NetGear WGR614 Wireless Router
REST / Delete user / firmware update errors
Log in to your NETGEAR router by browsing to
http://www.routerlogin.net/orhttp://www.routerlogin.com./
Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
If you cannot log into your router:
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults.
however, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection.
Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and Clicking Apply.
If there is a small hole in the front or back of the router push a hair pin in to reset to factory settings.
Mar 29, 2014 | NetGear Stora MS2110 (MS2110-100PES) 1000...
Reset password
If you cannot log into your router:Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults.
Sep 03, 2013 | NetGear ReadyNAS NV+ RND4000 NAS server...
I have a netgear router and im not connected
Log in to your NETGEAR router by browsing to http://www.routerlogin.net/ or http://www.routerlogin.com./ Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed. If you cannot log into your router: Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings. If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and Clicking Apply. If there is a small hole in the front or back of the router push a hair pin in to reset to factory settings.
Apr 09, 2013 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
How do I change the log-in from the factory default. I tried to go the http://192.168.0.1, as directed, but got nowhere?
Try www.routerlogin.net www.routerlogin.com or http://www.192.168.1.1 instead.
the default username is "admin" and the default password is "password".
To change log-in details: On the main menu, under Maintenance, select Set Password to display the Set Password screen.
Have a good one.
Mar 10, 2011 | NetGear WNR2000 Wireless Router
Want to put a password to my router
  1. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  2. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings.
3. From the center screen, select your encryption type from under the Security Options heading.
    • If the wireless network passphrase is visible, review it and use it to log devices onto your network.
    • If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
Nov 08, 2010 | NetGear WGT624 Wireless Router
Cannot connect a router
Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin)and password by default the password is 1234 unless it has already been changed
from the left-hand navigation menu of the router manager,select wireles set up>wireless settings
from the center screen,select your encrytion type from under the Security Options heading
if the wireless network passphrase is visible,review it and use it to log on devices onto your network.
If it is not visible you can change your wireless passphrase but changing your passphrase will cause you to lose your wireless connection
Connect your computer to the router using an Ethernet Cable before entering a new passphrase into the text box and clicking apply.
If you cannot log into your router:Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
Note: restoring factory defaults on a device will erase any settings you have made
hope this helps
Oct 29, 2010 | NetGear WGR614 Router
I am using BSNL India broad band connection. I am not able to install my Netgear modem with router on my computer. on connecting the modem to the CPU, no further window is opened where i can enter user...
  1. follow the links hope this helps you
  2. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  3. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings.
NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
See the following articles for more information:
Sep 13, 2010 | NetGear DG834G Router
Can I set the WNR1000 as an access point
Yes, You can set it as a wireless access point. All you need to do is follow the steps below.
1. open internet browser, enter on the address bar http://routerlogin.com
2. username is admin, password is password.
3. Go to wireless, change the wireless settings like the ssid and setup the encrption. Go to LAn settings under advance.
4. Disable the dhcp server and change the ip address of your WNR1000
ex. You plan to connect your wnr1000 to a w ired route rwith an ip address of 192.168.1.1. You can set the wnr1000 to 192.168.1.x ( except 1)
Save the changes,
Plug the access point wnr1000 to the lan port on the main router and the other end also on the lan port on the wnr1000.(LAN to LAN)
It should be working now as an access point.
Kevin
Jul 03, 2010 | NetGear WNR1000 Router
NetGear WGR614 Wireless Router Logo
317 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
