Question about 2wire (1000-100052-000) 802.11g/b Wireless Adapter
2wire 802.11g/b Wireless
Serial number & key codes are too long for configuration
  • ineen May 22, 2008
    2wire home portal 1800hg
  • Henru Mentz
    Henru Mentz May 11, 2010
    please elaborate in order for an expert to respond with a functional solution
    Scholar:
  • 53 Answers
What's your ISP name? for list of activation keys or keycodes go to:
http://www.2wire.com/?p=268
as for the serial nos. well every product has its own unique serial no. and you can't change that; it's every product's unique identity.
Posted on Apr 09, 2008
Trying to hook up internet and computer is aking for a keycode
a key code or Serial is usually on the router in the back or under its that white or yellow (sometimes other) sticker with a long number it will say serial or key-code there. it is sometimes also located on the manual
Feb 04, 2011 | 2wire 2700HG-B Router (2700HGB)
Where and how do i find my access point I'am trying to set up a wireless internet connection
Hi Kregerbc,
If you want to know your Access Point it is the Name of your Network or Network Key (SSID). Usually the Network Name of 2wire router is 2WIRE and the Last 3 digits of the Serial Number of the Router. The Serial Number is located at the side of the router you will find a Sticker and look for the Serail Number you can also see there the Wireless Network Key under the Bar Code. Another Procedure to find the information of the router is to access it. listed below are the steps on how to access the router.
  • Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
  • Click the Home Networking tab at the top of the 2Wire Home page.
  • Click on Wireless Settings. then click EDIT SETTINGS located on the right panel.
  • Here you will be able to fine the setting for your Wireless Connection
  • You can change the SSID, Wireless Channel, Wireless Security, and Network Key
Rate me if this helps so i can help others
Thanks for using Fixya.
Feb 04, 2011 | 2wire (2701HG-B) Wireless Router
I have a 2wire gateway with 4 routers i have a desktop on it with a dsl cable line and two laptops on wireless going to the router. So that is 3 computers on the 2wire. I am trying to connect my third...
it depends on what type of OS that you are using. But the key point to this is that your computer was able to see your network, usually your network name would be 2wireXXX (the X is the 3 digit of your serial number of your 2wire modem or router. if it is asking for password or wep key. the wep key for your 2wire is the number enclosed in a bracket, that is usually 10 numbers below the serial number
Jun 23, 2010 | 2wire (1000-400108-001) Router
Installiong 2wire usb wirelees adapter. Now configuring-wont let me type in serial number. now I'm stuck
I had to reinstall my 802.11b legacy 2wireless adapter. installation went fine until I had to enter the sn and wireless encryption key off of unit. These numbers are on wireless unit but have letters. The software won't accept what is written on unit. What do I do?
Feb 21, 2010 | 2wire (1000-100052-000) 802.11g/b Wireless...
2wire configuration
ok...
the wireless key will be located on the bottom of the wireless 2wire router not the card..look at the bottom of the 2wire box and compare the picture below you will see 10 digit key code that will be the wireless encryption for you..dae0bae.jpg
vedhick...
Feb 22, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
I need help installing my 2wire wireless adapter card.
I used this one:
Introduction
This document describes the procedure to install driver for the 2Wire Wireless USB Adapter under Microsoft Windows, and to run a wireless configuration program to configure your 2Wire Wireless USB Adapter to work with a 2Wire HomePortal or OfficePortal wireless gateway. These drivers work under Microsoft Windows 98SE, ME, 2000, and XP.
STEP 1 - Driver Installation
1. Make sure your 2Wire Wireless USB Adapter has not been connected to your computer USB port.
2. Double-click on the file to run WinZip Self-Extractor. The driver installation files will be placed in your hard disk in the C:\TWWUSB_TEMP directory
3. Connect your 2Wire Wireless USB Adapter to an available USB port in your computer. Windows Found New Hardware Wizard will startup.
4. Select the option to search for driver in specific location. Specify C:\TWWGUSB_TEMP as the location of driver.
5. Follow on-screen instruction to finish driver installation.
STEP 2 - Wireless Configuration
1. Run the program WirelessCfg.exe in the directory C:\TWWGUSB_TEMP. You can do so by clicking on the Windows Start button and select Run. The Windows Start button is typically at the lower left corner of the screen. Type in C:\TWWGUSB_TEMP\WirelessCfg.exe to launch the program.
2. Follow on-screen instruction to configure your wireless setting. Enter the serial number and encryption key as they are printed on the bottom of your 2Wire wireless gateway.
Sep 28, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
How
Hi
enter the serial number and encryptian code as directed to configure my 2wire wireless PCI Adapter and it does not recognize it.
You can find all the drivers and the manual for your Wireless Adapter here: http://www.2wire.com/?p=331
May 30, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
My usb adapter (2wire 802.11g usb wireless adpter) is having problems.
you cant change the wep key on the upstairs pc unless you change it on the 2wire 1st. the pc wep key has to match whatever the 2wire has it set to. go to the 2wire router settings throught the downstairs pc that is working to be able to see what the wep key is set to, then when you get the key or set a new one enter that key into the upstairs pc.
Jan 08, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
2wire (1000-100052-000) 802.11g/b Wireless Adapter Logo
181 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
