Question about Lexmark Z645 InkJet Photo Printer
Paper jam.... Hi im using lexmark Z645. I don't know what i did but it didn't feed properly and it jam.i tried many times to shut down my pc unplugged the printer cable but still same problem.Please help
  • 148 Answers
Try to load more papers. use thicker bond paper
Posted on Mar 21, 2008
Fax on Lexmark 901 pro not feeding
Does it also jam when you're just copying or scanning? Try to check if the scanner is closed all the way down. The cover needs to be closed all the way down for the paper to flow properly from the ADF to the exit tray.
Oct 27, 2012 | Lexmark Pinnacle Pro901
Lexmark x5495
You need to bend the paper feeder of an angle of roughly 30 degrees to insert it back inside the printer.
Oct 29, 2008 | Zebra 105Se Thermal Printer
Paper won't feed through to the printing area
If when you mash print and the paper doesn't move through to be printed on it may be because you don;t have the paper inserted properly or maybe someone jammed your printer and tried to unjam it the wrong way and didn't tell you....hope it helps
Nov 16, 2011 | Office Equipment & Supplies
My printer keeps showing the message "Clear paper jam, then press (check mark), there is no jammed paper in the printer.
If I load my paper at the 'proper' height, it will not feed. If I push the paper down too far, I get a 'paper jam' message. What works for me (even though it's a royal pain) is to feed 1 sheet of paper at a time. Put 1 sheet in so it's level with the top of the feed tray, then gently push it down 3/4 of an inch. That works for me. Good luck.
Sep 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5400 Series AIO Feed Problems
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Thanks, Anu
Jul 20, 2009 | Lexmark X5495 All-in-One &USB...
THE FAX MACHINE TELLS US THERE IS A PAPER JAM AND WE KNOW THAT THERE IS NO JAM, DO WE RESET THE MACHINE, TRIED TO UNPLUG AND SHUT OFF NOTHING IS WORKING
the feed jam switch is stuck down. if you can pop it open and use canned air and blow inside where you feed the paper then where the paper comes out. this may pop it free... let me know
Jun 22, 2009 | Office Equipment & Supplies
Paper does not feed into lexmark X5470 all in one printer
feeding problems
not take apaper
not feed a paper
hey im tuval from israel,
first of all im sorry about my english :)
and now to the point.......
look, if you know where the feeding wheel its good (like elastic material over this wheel) , now take a"nail cleaner" (aceton)
and clean this wheel (the elastic thing), i did thet and the problem is gone!!!
after the cleanning send 15-20 empty doc to print (remember - empty, dont use you ink - you dont have to - save money), if all the paper is out from the printer,
you fix that.
i hope i help you.
tuval.
vaadk3@netvision.net.il
hope fore replay.... :)
May 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
My lexmark t520 wont print it says paper jam but there isn't one?
Hi Melissa:
I think that you problem is feed rollers. If you take the paper tray out and look inside you will see two white rubber paper feed rollers. If you feel them and they are smooth,then they need to be replaced. They should feel ruff.
Jan 09, 2009 | Lexmark T520 Laser Printer
Paper Jam
The problem is that after the cover sensor clip is replaced, the logic that tells the printer to feed the paper just to the beginning of the input roller is corrupted. The feeder roller (grey one at the paper feed) rolls to feed the paper and once the paper get to the input roller, another switch detect the paper, that tells the logic to change the direction of the input roller to feed the paper to the cartrige.
There's should be a way to reset the logic part of the printer to get it working right. Maybe pushing a combination of the front panel buttons.
Try playing with the power/green or power/"X" while unplug and plug the power cord.
Good Luck!!! email me with more sugestions/ideas... jmjc_65 at hotmail...
Jan 15, 2008 | Lexmark X3470 All-In-One InkJet Printer
Lexmark 1185 - paper feed problem
You may be missing a very small jam. Use a torch and tweezers, check down the back, also open cover, check even where you think paper wouldn't jam. Especially in teeth, rollers. Look for foreign debris as well as paper. Also, turn off, unlplug all cables/usb etc and replug, turn on. Finally, never load more than about 20 fine sheets at a time, reset printer settings to default. As a last resort, try uninstalling and reinstalling the printer.
Aug 25, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark Z645 InkJet Photo Printer Logo
56 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
