Question about Tomtom GO 700 GPS Receiver
Tomtom battery replace
Hi could you help me i have bought a new battery for my tomtom go 700 .would you be able to tell me how you change change it i have managed to take the front of so you can get to the screen but i cant see where the battery goes please help as i dont want to damage it thanks please contact me at cbligh@talktalk.net thanks again.
Chris
  • 1 more comment
  • Anonymous Apr 10, 2008
    Hi I need help replacing my tomtom 700 battery got the tools and got so far decided to stop as i cant see my next move.thanks Dave
  • vengy Apr 10, 2008
    hi ive undone the shell removed all plastics, removed the 4 outer star screws around the screen, the two holding in the speaker and the inner two that are visable and a size smaller behind the speaker.I worked out how to release the green circuit board and speaker but cant see anymore screws and am searching for advice before removing any foil. Your help will be gratefully recieved
  • QHFella Feb 10, 2009
    Got the shell off, and the speaker, but the battery is above the circuit board and that is glued in with aluminum tape (heat shield, I suspect) and I can't find any more screws or way to open the device further.
Http://wiki.answers.com/Q/How_do_you_replace_a_tomtom_battery
Posted on Jun 17, 2010
Change TomTom Go700 from yards to meters
I have a 720 but I suspect it will be the same or similar.
Tap the screen and then Change Preferences. Use the forward arrow to scroll to the relevant page (5 on mine) where you will find Set Units. Tap this and then change whatever units you wish.
Sep 24, 2009 | Tomtom GO 700 GPS Receiver
Www.tomtom.com/10
i just bought a tomtom one iq. how can i register and get the £10?
Jun 21, 2009 | Tomtom GO GPS Receiver
Changing the battery tomtom go 710
wow go to the nearest tomtom store
Apr 10, 2009 | Tomtom GO 720 GPS Receiver
It tells me: No GPS devise!
Hi folks,
Sorry for such a late reply but have been away. The original problem with my TomTom Go 700 Satnav hasn't been solved. It's just that I was advised by the company (They took it away for checking before returning it untreated) that it would be cheaper to buy a replacement! So that it what I will do!
Best wishes,
Kim
Mr. Kim Sabido
kim_sabido@sky.com
Aug 02, 2008 | Tomtom GO 700 GPS Receiver
Battery tomtom 700
I took out the battery in my tomtom go 700 by following the information in the links below. These links are for changing the battery in a tomtom 300, but it's all I could find and as it turned out the 700 was almost identical to the 300. Also, there were some good photos that helped. The first link is the instructions and the 2nd link has the photos. Good luck!
http://www.tomtomforums.com/showthread.php?t=7947
http://www.zaurus.org.uk/opentom/go300-dismantled.html
May 11, 2008 | Tomtom GO 700 GPS Receiver
Hi, Can you tell the difference between the tomtom go 500 and 700 please. cheers
Hi, the 500 takes an sd card, the 700 has an internal memory.
Apr 06, 2008 | Tomtom GPS
Tom 700
You can replace it yourself if you have some experience with dismantling electronic equipment. Unfortunately it is not an easy operation though. The main tools you need are a small star-shaped screwdriver and a soldering iron.
Jan 03, 2008 | Tomtom GO 700 GPS Receiver
Will not stay on
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
contact them about the problem...
http://www.tomtom.com/support/support.php?ID=2
Dec 03, 2007 | Tomtom GO 700 GPS Receiver
Tomtom troubleshooting
My daughter had this problem and it actually turned out to be the cigarette lighter connection. The fuse needed changing and bingo all working well now! Check you have a green light on the charger cable going into your cigarette lighter - if you dont its probably the fuse.
Aug 01, 2007 | Tomtom GO 700 GPS Receiver
Tomtom GO 700 GPS Receiver Logo
420 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
