Dell A215 Computer Speakers Logo
Posted on Apr 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Installation of speakers
I have no sound - the speakers are connected by one cable - there is one cable that goes from one speaker to the back of the computer to the audio jack (hooked up). I have 1 more outlet on one of the speakers. I have a 12 volt transformer that one end will fit into the speaker and and the other end to a 120v outlet. I need to know if I need to hook this up. I'm hesitant to hook it up in fear that I will damage the computer.
thanks
Anonymous
Level 2:
Scholar:
  • Expert 77 Answers
  • Posted on Apr 18, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
77
Questions
Helped
24315
Points
211
The speakers need to be powered separately, thus the need to connect to mains power. The extra outlet will be for the socket to connect from the transformer which you have mentioned.
So, yes, you need to "hook this up", it is required. I can understand your concern, the Dell Site for your speakers makes no mention of the need to power the speakers. Link provided for those interested.
http://accessories.us.dell.com/sna/productdetail.aspx?c=us&l=en&s=gen&sku=313-1810#Overview
Kind regards
Anonymous
Level 3:
  • Master 3,940 Answers
Anonymous
Master
Level 3:
Answers
3940
Questions
0
Helped
1405379
Points
12062
The speakers require the AC adapter to be connected for the speakers to function. The AC adapter powers the amplifier of the speakers
http://support.dell.com/support/edocs/acc/ada215/ada215.pdf
tip
How to set up a seven-speaker home theater system
Set up a home theater
How to connect your speakers
In order to deliver surround sound, home theater systems require 5, 6, or even 7 speakers--and that's not even counting the subwoofer. Connecting all those speakers together can be quite a challenge, so here's a quick overview of the basics.
If you don't have an all-in-one, home-theater-in-a-box system, you'll probably need to supply your own speaker cables. There are several different types available--they vary in terms of wire size (or gauges) and termination types. Make sure you pick cable that's a good match for your speakers and receiver. And make sure they're long enough; the rear-channel cables in particular will be stretching all the way around the room.
Once you've selected your system and have all your speakers ready to set up, begin by placing each speaker at or near its intended location. Then, attach the cables to them one by one. After securely fastening one end of the cable to the speaker, connect the other end to the appropriate speaker output on the back of the A/V receiver. Be sure to connect the cable to the correctly labeled output.
For instance, the front-right speaker wire needs to go to the terminal labeled front-right. Also, make sure that each speaker connection is in phase, meaning negative to negative and positive to positive. Otherwise, your system's sound will sound out of whack. Repeat the process for every speaker in your system. Note that the subwoofer uses a coaxial-style RCA cable instead of standard speaker wire.
Once all the wires are connected, you should test the system with several DVDs and CDs, to ensure that everything is in working order.
For our first example, we used an elaborate 7.1-channel system, so it may have 1, 2, or several more speakers than your system. Some systems even employ wireless rear speakers, or virtual surround-surround modes that simulate multichannel experience from 3, 2, or even 1 speaker. And some listeners still prefer good old stereo sound from 2 speakers. No matter what type of speaker setup you prefer, however, the wiring basics remain the same.
How to position surround-sound speakers and a subwoofer
To get the best performance from a surround-sound speaker system, you must install each speaker in the correct location. There are three basic types of surround-sound speaker systems.
  • The 5.1-channel system has five satellite speakers and a subwoofer.
  • 6.1-channel systems have six satellites and a subwoofer.
  • And 7.1-channel systems have seven satellites and a subwoofer.
Start by placing the center speaker either directly above or directly below your TV. The center speaker can be perched atop a direct-view TV or mounted on the wall. Aim the center speaker at ear level.
In most cases, the front-left and front-right speakers can be wall mounted or placed on stands. However, if your speakers have rear-panel bass ports, they should not be wall mounted. Space your front-left and front-right speakers the same distance apart as the distance between your center speaker and your listening position. Position the front-left and front-right speakers no more than two feet above or below the front-center speaker. The tweeters in the front-left and front-right speakers should be roughly at ear level relative to your seating position.
Ideally, the surround-left and surround-right speakers should be mounted on the side walls of your room, slightly behind or parallel to your listening position. If your speakers have rear-panel bass ports, place them on stands instead. If installing the speakers on the side walls isn't practical, you can mount them on the room's rear wall or place them on stands behind your listening position. The surround speakers can be installed up to two feet above the front speakers.
Also, 6.1 surround systems have a back-center speaker. You'll typically mount this on the rear wall of your room, centered behind your seating position. Position the back-center speaker no more than six feet behind the surround-left and surround-right speakers. If your speaker has a rear-panel bass port or if the rear wall is too far behind your seating position, place the back center speaker on a stand instead. The back-center speaker should be installed at the same height as the surround-left and surround-right speakers.
Instead of a single back speaker, 7.1 surround systems use a back-left and a back-right speaker. These, too, are typically mounted on the rear wall of your room. Position the back-left and back-right speakers so that each is approximately aligned with the left and right edges of your listening position. Place the back-left and back-right speakers no more than six feet behind the surround-left and surround-right speakers. If your speakers have rear-panel bass ports,or if the rear wall is too far behind your seating position, place the speakers on stands instead. Install the back-left and back-right speakers at the same height as the surround-left and surround-right speakers.
A subwoofer is the last component of a 5, 6, or 7.1 system. Because bass frequencies are nondirectional, you can place the subwoofer in various locations. You may get the best performance by installing the subwoofer in the front of the room, approximately six inches from the wall. If you want more bass, try placing the sub near a corner in the front of the room.
Connect your DVD player to your A/V receiver--digitally
To hear a movie's soundtrack in surround sound, you must first connect your DVD player to an A/V surround-sound receiver. You'll need to make what is called a multi-channel-compatible connection.
The easiest way to do this is to use a cable that carries a digital signal. There are two digital options: optical and coaxial.
An optical digital connection, also called TosLink, uses pulses of light to deliver a digital signal. According to some experts, one advantage of optical digital connections is that optical cables don't pick up noise, while lower-quality coaxial cables can. Many, but not all, DVD players have an optical output. Most A/V receivers have at least one and usually multiple optical inputs. Plug one end of the optical cable into the DVDs player's optical-out jack. Plug the other end into the receiver's optical input.
Finally, you need to tell your receiver to use the optical connection whenever you switch to the DVD input. This is called assigning the input. Information about this simple process can be found in your A/V receiver's manual.
A second option is a coaxial digital connection. This type of connection is also used for cable TV, but the connectors are different. This type of coaxial cable has an RCA connector. Coaxial cables are less expensive than optical ones. In fact, you can use any old RCA cable to make a coaxial digital connection, and you won't lose any audio quality.
Most, but not all, DVD players, have a coaxial output. Some have coaxial and optical outputs, so you get a choice. Audiophiles argue over which connection is better, but it's very hard to hear the difference. Most A/V receivers have at least one and usually multiple coaxial inputs. Plug one end of the coaxial cable into the DVD player's coaxial-out jack. Plug the other end into the receiver's coaxial input.
Finally, tell your receiver to use the coaxial connection whenever you switch to the DVD input. Again, your A/V receiver's manual will have instructions for assigning an input.
Putting aftermarket radio in 1997 ford Mercury grand marquis but wire color doesn't match up... what colors do I use for speakers and battery and ground
Get your self a D or C battery fully charge. Set aside the cables that you think it goes to the speakers. Now grab a pair of cables that you think it goes to one speaker, it don't matter if it's from, back, right or left, we are going to figure that out with the battery. Grab on of the cable, if you think the cable goes to the positive, connect the cable to positive (battery) and the other one just tap the bottom of the battery, you should hear a thump sound. Now you know to which speaker those cable belong to, but you need to be sure which is negative and which is positive. For that, take out the door carpet, or wherever the speaker's at, and expose the speaker, try again with the battery, if the thump sound makes the speaker go in, you need to swap the cables, if it goes out, you have them correct. Best of luck.
Sound goes out & speakers "disappear" from computer prefs panel
I would open it up (assuming it's a desktop pc not a laptop), and make sure the sound card (if it's an expansion card and not built-in to the motherboard), is properly seated (all the way in) in the expansion slot.
2answers
Don't know how to hook them up
What a lovely daughter, how very nice of her,
here goes....straight for Mr. Koss
To Operate with AC Adapter
  1. Open battery compartment located at the back of both speakers and remove wires.
  2. Replace battery covers.
  3. Connect DUAL PLUG CONNECTOR on left speaker to right speaker at connection marked "TO LEFT SPEAKER."
  4. Connect remaining wire with 3.5mm plug to headphone jack on your audio source.
  5. Connect AC adapter (not included) to back of left speaker at connector marked "DC 6V." Plug remaining end of AC adapter into wall outlet. Be sure your AC adapter is built with the center pin as ("-") negative. Connect remaining wire with 3.5mm plug to the headphone jack on your audio source.
  6. Turn ON/OFF switch at back of right speaker to "ON."
  7. Set "INPUT SELECTOR" switch to audio source.
  8. Turn on audio source
  9. Adjust sound in the following ways: Turn volume control to desired level; push Bass Boost button located on right speaker to "ON" for added bass; push Treble Boost button on right speaker to "ON" for added treble
  10. Operating a microphone through your speakers require an additional 3.5mm plug to 3.5mm plug cable (included). Connect cable with 3.5mm straight plug to right speaker at input marked "MIC" on back of speaker. Plug the remaining 3.5mm L--plug into the mic input on audio source. Connect your microphone to the front of your speakers at "MIC" input (microphone not included)
Hope you have all of the skinny you need, good luck,
please leave a rating, thank you kindly
Need a wiring diagram for connecting KOSS HD 50 COmputer speakers
Hello there! lellya
First,
1) you have to tell , what kind of sound card you got? on board audio? A7, or Creative Audigy? 5.1 or regular.
2) then, you have to connect one speaker to the other, one two way connector cable, for the 2 KOSS speakers.
3) another cable that goes in back of your koss and from the out of your KOSS Speakers to the input of your sound card, at back of your PC, this input is your sound card jack.
4) its supose to work like so.
good luck
2answers
No sound
This issue could be caused by any of the below reasons.
  1. Sound card does not work
  2. Speakers are not connected properly
  3. No power to the speakers
  4. Volume on speakers turned down
  5. Volume on sound card turned down
  6. Bad hardware
  • make sure the speaker setup is correct. It is possible that during an installation of another program that the speakers software setup was changed causing issues with your sound. To do this follow the below steps.
  1. OpenControl Panel
  2. Open "Sounds and Multimedia Properties" or "Sounds and Audio Devices" in Control Panel.
  3. Click the "Audio" tab
  4. In the Audio tab click the "Advanced" button under "Sound Playback."
  5. In the Advanced Audio Properties window make sure your speaker setup is correct. If you're not sure what to set this setting as, set it to the default "Desktop Stereo Speakers" option.
  6. If you changed this setting click "Apply" and close out of all windows.
  • Ensure that the sound card works properly by connecting either another pair of speakers to the computer, or a pair of headphones.
  • the left speaker will generally have a cable that cannot be removed from it. This cable should be connected to the other speaker (generally this cable has no color or is white / gray). The next cable is the line out cable, it is generally green in color and should go from the right speaker to the line out hole in the back of your sound card.
  • Finally, the power cable generally should be connected to the back of the right speaker, or in some cases, the sub woofer. The power cable can vary; while most speakers are in the above configuration, some speakers may also not utilize a power cable connection but instead have batteries, while other speakers that connect to the side of your monitor may use a portion of the power from the monitor itself (via another type of cable).
  • Most speakers will have a small LED (light) indicating if the speaker is on. Verify that if this light is present that it is illuminated.
If no LED is seen or the speakers don't appear to be getting power, verify the power cable is properly connected to a working outlet or if your speakers use batteries that the batteries are good. Finally, most speakers can be turned on either by using a button or by moving the volume knob from left to right.
  • Verify that the volume knob on the speakers is properly turned up. If you are un-certain what direction to turn the knob, play a long sound file or CD and while the sound is being played, adjust the knob left to right or up to down.
  • The sound is also able to be turned up and down through the software installed on the computer. Verify the sound settings in the software are properly turned up.
  • Finally, if all of the above recommendations do not resolve your issue and connecting another pair of speakers or headphones to the computer does work, it is likely that the speakers are bad. It is recommended that you contact the manufacturer of the speakers or computer for a new replacement.
1helpful
2answers
Connect BX8A speaker to PC
Hello waddragon,
First, let's start with the BX8a. Those are powered speakers (built-in amplifier in each) so, you do not need a pre-amp. What you need to connect them to your computer is a 3.5mm to XLR cable OR a 3.5mm to 1/4" TRS cable, also known as 3.5mm to two 1/4" mono plugs (the back of the BX8a has inputs that accept either type). Cables are available at most any electronics stores. Make sure you buy a long enough cable to run from the back of the computer to where the speakers will be.
It sounds that you only have one BX8a which means you'll be listening to only one channel of the stereo output. In any case, make sure before connecting the speaker(s) to the computer that speaker power is off and volume control is at minimum. Connect the 3.5mm cable end to Line Out 1 jack of the X-Fi sound card and either the XLT or TRS ends to the speaker(s) input(s). Play some audio content on your computer, turn on speaker(s) and slowly increase volume to a safe level. Everything should work fine.
Let me know how it goes.
cancerags
Speakers
you need to ensure that the speaker lne cable is connected, this should be a double ended 3.5 jack plug cable, one end plugs into the back of the monitor, the other goes into your speaker port on the motherboard of your computer, sometimes there is a power cable required too
Not getting sound from right speaker
How do you have the audio hooked up from the TV set? If its s video or RCA plugs? If it is switch them around and see if it swaps channels that goes out . If it does then the output cable or the jack is bad. If your using an HDMI ir a scart cable. The cable or connections could be bad. Unplug it and reinsert it or while the units on mover it around and see if the audio comes back on.
Top Dell Audio Players & Recorders Experts
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
 Grubhead
Grubhead
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
