Question about Whirlpool LER5636P Electric Dryer
Dryer smelling hot and smoke detector goes off
The other night my wife was drying clothes when the smoke detector went off and the smell of burning was in the air. We saw no smoke but the smell was that of like metal or something we thought. We have disconnected it and i have cleaned all i can see with the vacuum and the heating element is black on the top portion of it with no broken element components, Could this be it?
  • 770 Answers
Clean the venting going to the outside and the dryer really ahould be taken apart and delinted to avoid a fire if the unit is older
Posted on May 12, 2008
My amana dryer smells like something's burning
You will need to open the dryer ans clean the internal duct work.
May 22, 2012 | Amana NED7200TW Electric Dryer
As describe earlier, my dryer started smoking, and maing a burning smell from behind the drum. There is no evidence of lint buildup in the exhaust, and the dryer still starts smelling as if it is on fire...
i just had this problem. Did you notice the lint buildup under the lint drawer? Well, there is no way to recover that lint, it is not accessible by the consumer. So the lint bits get sucked in to the out take which actually pulls across the hot element. The "solution" is to replace the element and the parts surrounding. It is very expensive, and does not resolve the issue. The lint will continue to be drawn across to that area and build up and become a fire hazard. I am about to try Bosch for a solution, but that is what they have told me for now. Eventually this make/model of dryer will burn someone's house down. I am very glad I was home when the smoke detector went off. I will have to get a new dryer.
Aug 04, 2010 | Bosch Nexxt WTMC3321US Electric Dryer
Maytag Neptune Dryer with strong "burned electrical wiring" smell
Sounds like the motor went out. Before trying to start it it needs to be inspected. If you are not comfortable opening up the cabinet then I would would recommend calling a service tech. If you need further assistance please let me know.
Ken
Mar 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
The dryer smells as of something is burning and it is leaving a bad smell in the clothes
The dryer may be getting too hot. Check vent for obstruction from unit to outside.
May 25, 2009 | Maytag Dryers
Dryer smoking, burned rubber smell
if the rug has a rubber side it will melt make sure dryer is clean and no left over burnt material ..
Sep 18, 2017 | Dryers
LG TROMM DRYER DLE5977 Burning Smell
It is a POS dryer, we have the same one. My suggestion get another dryer. We vacuumed it all out (don't you have a problem with the lint catcher?) Then it started loud pounding noise, which a lot of people seem to have the same problem, then our sensor went out and we had to dry the clothes 5-10 x's...now crack in stainless steel drum and is chewing up all our expensive clothes!
Feb 21, 2009 | LG DLE5977 Stainless Steel Electric Dryer
Duet Gas Dryer- burning smell
first is first ,,, disconnect dryer from plug,, now open bottom panel 2 screws ,, now go and get youre vaccum,shop vac, anything ,, reason for burning smell ,, usually catching on fire ,, we recommend do this 1 as year,,, after cleaning , put about 2-3 fabric sheets inside dryer and let it runn for about 30 minutes to remive smoke from drum,,, thank you
Dec 29, 2008 | Dryers
LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Dec 01, 2008 | LG DLG5932W Gas Dryer
Maytag Dryer
the high limit switch may be malfunctioning. i would have it looked at by a professional. this could be a fire hazard.
Jul 10, 2008 | Dryers
Whirlpool LER5636P Electric Dryer Logo
650 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
