Question about Hitachi ( 0A30229-20pk) 400 GB Hard Drive
Dell Dimension 5000 Desktop
I am installing a replacement Sata Hdd and cannot find the drivers anywhere to install it can you please help?
Kind regards
Jay
  • mrjay Mar 22, 2008
    Thanks matt
    Novelist:
  • 155 Answers
You don't need drivers for a hard drive! Just plug it in and it will be recognised by the BIOS.
The only thing you will need to do is make sure you designate it as a primary or slave drive - whatever the old drive was set to. On the back there is what looks like an eight pin plug, with a jumper across two of the pins. Depending which pins are connected will change the drive designation. There is usually a sticker next to them telling you which to connect for primary and slave.
Matt
Posted on Mar 21, 2008
SOURCE:
Sata hdd windows dell recovery cd will partition install windows
The system is originally designed to use IDE HDD, make sure the necessary chages for Sata HDD are made in the BIOS, next make sure the Recovery disc is fine without any scratches. You can order a new Windows OEM recovery disc by calling Dell tech support (1-800-624-9896-US) and try installing the OS. The disc will cost you not more than $12.
Nov 15, 2009 | Dell Dimension 4700 PC Desktop
Dageezer sdays the LG GH22 dvd writer is a sata
You can refer to the following user manual , for the drive installation
http://support.dell.com/support/edocs/systems/dim3100/en/sm/parts0.htm#wp1244168
Thanks for using Fixya
proton
Nov 08, 2009 | Dell Dimension 3100 PC Desktop
I have a dell dimension e520 and I just bought a wd 320 gb sata hdd. When I want to install xp it stops before the welcome to setup screen and it gives me a blue screen help please
The blue screen you are seeing is probably not the regular BSOD (blue screen of death)
Wat you need is the DOS SATA drivers for your adaptor on floppy or some other suitable form (USB formatted as a floppy)
I think you may have missed it but as the XP CD is booting at the bottom of the screen was a message that said "press F6 to install additional storage drivers"
You should have hit F6
In a little while it will then ask you for those drivers and you just point it at the floppy or other device set to act as a floppy.
Now it will load them and let you continue setup.
otherwise it will quite often fail as it may no know how to find the SATA drive.
Sep 07, 2009 | Dell Dimension E520 PC Desktop
Windows can't install because it says it can't find a hard drive. Setup indicated both HD's are there and working. Installing Windows 2000 from Disc. Changed boot sequence so Rom boots first. Windows loads...
Check for sata drivers, if it is system is shipped with SATA hdd, need to install SATA Raid drivers during reinstallation .I believe that the dell system was originally shipped with Windows XP or Vista Operating system which has SATA drivers for SATA hdd. Since windows 2000 Operating system does not have SATA drivers hence unable to recognised hdd.
Aug 17, 2009 | Dell Dimension 9100 PC Desktop
Can't reboot dell 4100 dimension desktop
First put the hdd installation cd into the cd drive and try to boot. This should install the hdd driver as well as start formatting the new hdd. After the drive is formatted take out the hdd cd & insert the Windows installation cd into the drive. Boot. Windows should start installing on your new drive. After Windows is installed check the Dell support site for updated drivers for your system. Install drivers as needed. Any other software you had on your old drive will need to be reinstalled to the new drive. Hope this helps & please rate my answer. Thanks.
Dec 27, 2008 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Dimension 4700 with Barracuda 500Gb SATA HDD
You have to go online and search then download the drivers for preparing SATA laptop harddrives for installation of Windows XP otherwise during installation it will tell you there is no hard drive found.
Dec 12, 2008 | Dell Dimension 4700 PC Desktop
Dell dimension 3000 hard dirve what type do i need to install a sata pata or ide
Hi
Dell Dimension 3000 accepts IDE hard drive. Any modern IDE drive should be fine
Check out Dell Dimension 3000 Service Manual for spec and how to remove and install parts.
Mike
Aug 21, 2008 | Dell Dimension 3000® Pentium® 4...
Dell Dimension 5000
you problem is most likely that your bios is out of date. download the latest bios updates for your motherboard and then when you install windows format you HDD with the ntfs system (using the long formatt system not the quick format). Then you should install the bios update. then your mboard shoud no longer have the problem of recognising your large capacity HDD. thanks
May 18, 2008 | Computers & Internet
Dell Dimension 5000 - Installing extra Hitachi 500GB SATA Hard Drive
you need to turn it on in the Bios so the computer sees the drive, then format it.
Jan 20, 2008 | Hitachi ( 0A30229-20pk) 400 GB Hard Drive
Drivers
You have probably not installed sata/raid support floppy disc on the initial install of windows when prompted to press F6. You will need to find the make of the drive, then go to the manufaturer web site and download the HDD drivers to a floppy disc. The motherboard may also need the driver for sata/raid from the dell support site http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid=
May 22, 2007 | Dell Dimension 4600 PC Desktop
Hitachi ( 0A30229-20pk) 400 GB Hard Drive Logo
334 people viewed this question
Top Hitachi Computers & Internet Experts
Ekse
Alun Cox
Marvin
Marvin
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
