Question about Ricoh CL4000DN Laser Printer
Error Code SC 304
This error message is preventing my business from being able to print anything. What exactly does this error message mean, and what can I do to fix it?
Do I need someone to come in and fix the problem, or can I do it myself?
Thank you for your help.
5 Suggested Answers
silly girl
  • 513 Answers
SOURCE: error message
Not sure if your printer is the same, but one ricoh I saw had an energy saving setting, that's meant to play with the warm up time of the heating roller. If you still have the manual and can find the access to such settings, you could try it with each one of the settings, to see if it fixes the problem. It's possible that with energy saving turned off your problem will be solved, which isn't a bad idea for a frequently used school machine. If it does solve it, you could ask the users to make sure the machine is turned off when it's not being used for a long period of time. Good luck
Posted on May 23, 2006
  • 37 Answers
SOURCE: error code sc 202
This code is a problem with your machine polygon motor it is defective or the cable running to it is defective , it is quite a big job getting to that motor so i sugest you get a profesional to fix that up for you .
Posted on Jan 07, 2008
drichards
  • 87 Answers
SOURCE: Error Code SC 541
Its a fuser code. Hold down both of the arrow keys for 10 seconds, then press enter. Select 2 for engine, ok, select 7 for data log, ok, scroll to 7807 and execute. exit all of the way out until you get back to engine, then select 3 for end. Recycle power.
Posted on Apr 01, 2008
infiernet
SOURCE: Ricoh AP610N error message SC-545
Hi, i recently got this error on Ricoh Aficio AP 610N
and This was the Fix..
0.- Hold on your breathe...
1.- Turn Off the printer.
2.- Press "ONLINE and SCAPE" buttons..
3.- without stopping pressing them (ONLINE and SCAPE) TURN ON THE PRINTER.. and wait about 10-15 seconds and Service menu show up.. after this.. release the buttons...
4.- Go to.. Engine Maintenance... Enter..
5.- Search for SP5810 (Fusing err clr) and Enter.
6.- Accept the change and enter...
7.- Turn off the printer...
8.- Finally turn on the printer and try to print something :)
9.- if the printer works.. you can breathe again :)
Thanks to everybody..
Posted on May 21, 2008
SOURCE: error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Posted on Nov 10, 2008
What does error message F61 mean on Panasonic SC-AK25 Shelf System
Problem with the amplifier assembly. Check to see if the fan is spinning and if not there could be alot of dust on it which is preventing the unit from powering up. If the fans fine its going to be the I.C audio chip.
Feb 20, 2012 | Panasonic SC-AK25 Shelf System
I purchased the HP officejet 4500 all in one. The message "fatal error" comes up while installing. I have business Vista. What do I do? Thanks. Lisa
some errors usually include a four-digit numbered code. if there is, please let me know. I also need to know the exact error message. where do you see the error message? on the computer or printer? PLEASE TAKE NOTE THE EXACT ERROR MESSAGE AND LET ME KNOW.
for the mean time, you can use the printer without troubleshooting the error by just installing the basic driver. the product will still print as usual however the product might not have its full functionality. steps in installing the basic driver: restart the HP software installation then select the "express" or "minimal" installation option instead of the "full recommended" installation option. Then follow the on-screen instruction to complete the installation.
Jul 26, 2011 | Office Equipment & Supplies
Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Jan 15, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
A05-304 error & Top section of page cutting off
the thing might be down to an old master stuck to the drum this could cause the faint copies and the missing print.. pull the drum out check under the master.this would also cause the paper to jam on exit. the error is for no master eject check the calmp is free where it grips the master and also the path for the master eject to the waste bin
Jun 12, 2009 | Riso RZ220 Duplicator
Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
Feb 02, 2009 | Gestetner DSm615 Digital Imaging System
SC-HT75 home theater
This error means that the unit is in "protect" mode. An error condition was detected in the final stage of the amp and the unit has shutdown to prevent further damage. This is usually the output amp pac that needs to be replaced. Expect a parts replacement cost in the $75-$90 range.
Dan
Dec 04, 2008 | Panasonic SC-HT75 System
Error code sc 101.... sc 350
SC101 Scan Lamp Error
SC350 ID sensor pattern test error
Your scanner should be checked by a technician to determine what is causing the error. There isn't any calibration or troubleshooting that can be done unless you have scanner parts.
Aug 21, 2008 | Office Equipment & Supplies
Panasonic DVD SC-RT70 whilst recording disc stopped and shows error code U61. Recovery process did not work message keeps repeating
I have a SC-RT70 model and there is U61 error code in my dvd player's display. what does this error means?
Jun 16, 2008 | Panasonic Televison & Video
Printer message: Unable to Print
5A means that the purge cam stopps abnormally when it is in use. This could be of a broken cam shaft. You have to replace the whole purge unit. This is a service job to do!
Aug 27, 2007 | Brother MFC 420CN All-In-One InkJet...
Ricoh CL4000DN Laser Printer Logo
1,157 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
