I have hot water in my Laundry room and Master Bath, this is the side where the water heater is located, my kitchen, and guest bath on the other side of the house has no hot water, it's a 3300sq foot house, I have the Taco 265 on my water heater, how does it work? how do you set it? HELP!!
All of the white pegs on the outside of the dial are on and off times. If they are pushed out they are on and pushed toward the center is off. You want to set those for the times you would usually used hot water. There is a white arrow on the face. You want to rotate the face clockwise until the time of day is infront of the arrow to set the time. Last but not least there is a switch on the right side of the dial it has three settings, on off and timer. If you set it to the clock the pump will turn on and off at the times that were selected on the face. You can also turn it to the constant on position and it will run constantly. I would suggest flipping it to constant on and wait a few minutes to see if it fixes your hot water problems. If not the pump might be bad.
