Question about Sony XM-D1000P5 Car Audio Amplifier
Sony XM-D1000P5 in protective mode
Hi a fuse blew under the bonnet of my car and my sony xm-d1000p5 locked itself in protective mode. how do i reset this?
  • caneopoly Mar 30, 2009
    sony d1000p5 amp in protected mode please help
  • 27 Answers
Sounds like a wiring short somewhere in the powerline from the battery to the amp. I'm guessing the fuze you're refering to is the one inline from the vehicles' battery to the amp. You'll need to find the short, fix it, then replace any blown fuzes before the amp will power up. Just take your time and go over all the wiring to and from the amp. Make sure the battery power cable hasn't shorted against the firewall(use a rubber grommet here), no screws have gone through it while reinstalling interior panels, and that your amps terminal connections aren't grounding out against each other due to stray copper strands.
Posted on Mar 21, 2008
How do yu reset amp
I dont lnow what "just quit blew fuse getting power" means. But there is not reset on that amp.
Mar 28, 2014 | Sony Xplod XM-1652Z Car Audio Amplifier
Wires touched now no output
It is quite possible that the outputs were damaged when the wires shorted. In some case the fuse can blow or the protect circuit will trip . If so remove power , remove the short and reconnect. If there is no power check the fuse of the main positive line. If the fuse is intact or if the fuse blows on connection there is a short which must be confirmed. Disconnect the output drive and check to confirm.
Mar 04, 2011 | Sony XM-D1000P5 Car Audio Amplifier
Amp xm-ZR604 keeps going into protect mode
check the ground and the positive wires to make sure that they are getting good continuity. if your amp is too small for the speakers you are pushing this will also put the amp into protect mode
Feb 09, 2011 | Sony - XM-ZR604 4/3 channel car amplifier
My fuse went out on my sony 800 watt amp and cant figure out how to swap out the fuses.
The fuse blew for a reason DO NOT replace it without repairing the problem. You will burn up more components.
Apr 27, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony xm gtx1852 amp new and worked for 1 day now is in protect mode even with nothing hooked up but the remote and power and ground.
meter the power side of the amp. sometimes the amp will go into protect if it doesnt have power. if power and remote and ground are good the amp is probably bad.
Dec 29, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Wont stop going in to power protect mode
Hi, does it still do it with speaker disconected?
Aug 04, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
My SONY XM-ZR1252 fuse keeps blowing
hi
maybe you have defective mosfet power transistors thats why your fuse is blowing...
Thanks!
Apr 25, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Hi i have a 600 watt sony xplod amp model xm-554zr and it recently stopped working. when i turn my car on the amp turns on but only for a sec then the protection light comes on, on the amp and it wont...
sounds like maybe a speaker short, try unhooking your speakers and then powering up your amp, if it then powers up with the speakers unhooked try hooking up each speaker one by one untill the amp goes back into protection and then you have your bad speaker.
Mar 08, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony XM-D1000P5 Car Audio Amplifier Logo
154 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
