Question about Panasonic Lumix DMC-FZ18K Digital Camera
FZ18 Lens Cap error message with telephoto converter
My Panasonic FZ18 is currently unusable after I added a telephoto converter lens.
The converter lens is attached to the original camera lense via an appropriate adaptor. It cannot however be removed as the camera believes it to be a lens cap. As a result, it continues to display the "Remove the lens cap" message and will not extend the original lens to allow the converter to be removed.
As the connector on the FZ18 is designed to rotate freely, no matter how much I unscrew the converter, it will not unscrew as the internal connector rotates along with it. This is tucked away inside the retracted lens.
If any one knows how I can get the original lens to extend, or alternatively to stop the converter being recognised as a lense cap, I would be very grateful.
  • Gargol Apr 12, 2008
    I have just a copy this problem. And the worst thing is that they didn't mantion about some problem like this. I was in a proces of taking of the telephoto lens and the camera went to "sleep". Could you please describe more specificly how to solve this "stuck" problem ? It would be very helpful. Thank's.
I have the same camera, and had the same problem. Make sure the camera is switched off. Then take 2 hard pieces of plastic with sharp ends. Carefully try & jam the outer ring with one, and try turning the converter with the other. I used a mini screwdriver, and left some marks on my camera. Thats why I recomend using plastic of some kind.
When you use the converter, switch off the battery saver in the camera. That way the converter won't jam again, as the camera won't switch off automatically. There is also a programme in the menu that is used for converters and external lenses. It also prevents the lens from retracting completely.
Hope I have helped you.
DaveSA
Posted on Mar 24, 2008
I purchased a Vivitar 2.2x lens for my Lumix DMC FZ18 camera & I'm getting a lot of distortion. Suggestions?
It's a cheap(ish) generic screw on lens multiplier and so compatibility with anything it's screwed onto is a matter of pot-luck, especially as the conversion factor is so high.
There is nothing you can do, other than to try alternative brands (preferably not exceeding 1.4x) or to obtain the expensive Panasonic version which is designed to be compatible with your camera. Even the official product will produce some distortion (usually barrel distortion) and most likely a fair bit of chromatic aberration. It's just usually less adverse than with the generic products.
Jun 18, 2011 | Zeikos ZE2X58B 58mm 2X Telephoto Lens
Error message saying remove lens cap
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
May 09, 2010 | Panasonic Lumix DMC-FZ18K Digital Camera
Error message- remove lens cap and press > button
Is your lens not retracting?
I've got the same problem and with the lens not retracting - this is why i get the message.
Jul 29, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Dust
This problem has plagued digital slr users for years. Unfortunately adding extension rings will change the focal length of whatever lens is used (could be a plus, but most likely not). Best thing is to change lenses in a clean environment, keep all your lenses clean and capped when not in use. Also when changing lenses it may help to keep the camera inverted with the body opening pointing downward. If stuff gets inside (which it will its only a matter of time) take it to a shop for a sensor cleaning (typical $40-50) or read about cleaning tools here http://www.photosol.com/
May 14, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
Lens adapters
I received an answer on Flickr (almost immediately!) thanks, anyway!
Apr 05, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
Lens Error - Cool Pix L6 - Camera unuseable
helppppppppppppppp mne is stuck open and it wrks but whn iturn it off it stays open (1/2 of it)
Jan 07, 2008 | Panasonic Lumix DMC-FX10 Digital Camera
Wide angle adapter
I wouldn't worry about the adapter. I'm going to try ordering a telephoto converter this weekend.
Sep 06, 2005 | Panasonic Lumix DMC-FZ1 Digital Camera
Telephoto lens for digital camera
It will not work because it is the wrong thread size. Here is info on the Olympus TCON-17 lens for the 5050: TCON-17 (1.7X) Telephoto Conversion Lens Extend the capabilities of your digital camera with the TCON-17 Telephoto Converter lens. This telephoto lens will increase the magnification of your subject by 1.7x when your camera lens is set to the telephoto position. This will help you bring in the subject when you can't get closer, for example, shooting sports or concerts. Please see below for additional items required to attach this lens to your camera. The following models require the CLA-1 and 43-55mm Step-Up Ring: C-2000/2020/2040/3000/3020/3030/3040/4000/4040/5050 Zoom ....... The video lens is too small (diameter). If you found one with a 43mm thread and put it on the 5050, you would experience severe vignetting (clipping of the corners of the photo).
Sep 05, 2005 | Olympus Camedia C-5050 Zoom Digital Camera
Open Questions:
Panasonic Lumix DMC-FZ18K Digital Camera Logo
377 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
