Question about Microsoft Office Outlook 2003 for PC
My Internet explorer icon is not working on my PC
Sir,
when I double click on Internet Eplorer on my deskop it is not working. I shows from which file it has to open. But when I click on internet explorer it is not working. What is the problem?
  • 59 Answers
Either your shortcut is being not working properly in this case u can make it again from start->all programs
otherwise your explorer is courepted u have to install it again ok
best of luck
Posted on Mar 29, 2008
What version of internet explorer am I using
1) open internet explorer2) check if you see menu bar. it has file, edit, etc. 3) click help4) click About Internet Explorer. it will show you the version for your interent explorer.5) click Ok to close it
if you don't see menu bar1) open internet explorer2) click wheel icon located on the upper right corner. 3) click About Internet Explorer. it will show you the version for your interent explorer.4) click Ok to close it
May 10, 2012 | Microsoft Computers & Internet
Tip
How to remove the content advisor password?
Solution:
Although the removing the password in content advisor is not covered under warranty. It is a few simple steps to clear it and resolve the issue.
Follow the steps below:
(It is advisable to make a backup of the Registry before proceeding. To do this, go to the File menu, choose "Export Registry File..." and give the file a short name (e.g.: Backup1.1.04) storing it in the root level of the primary hard disk drive or floppy.)
1) Click on Start and choose Run.
2) Type in RegEdit and select OK.
3) Now click on the little plus sign to the left of HKEY_LOCAL_MACHINE.
4) Continue to drill down, always clicking on the plus sign at the left of the named key, through Software, Microsoft, Windows, Current Version and Policies.
5) Now click on the Ratings folder.
6) In the right pane of the RegEdit window, you'll see an icon called Key. Click on it and press Delete.
7) Next, choose Registry and then Exit to exit RegEdit. You've just deleted your original Content Advisor password.
8) Restart the computer and run Internet Explorer again.
9) Choose View and then Internet Options (or Options for version 3.x). For IE 5 or greater, Click on Tools, Internet Options.
10) Click on the Content tab and click on Disable. When asked for a password, don't enter anything; just click on OK. This will disable Content Advisor because there's no longer a password.
How to Fix Problems with Content Advisor Missing Information?
In most cases, this problem occurs when the Ratings.pol file is damaged, follow the instructions below to fix this issue.
1) Quit Internet Explorer
2) Open My Computer, click on Tools, Folder Options
3) Click on the View tab and make sure "Show hidden files and folders" is selected, you may also want to uncheck the box next to "Hide extensions for known file types" and click Ok
4) Double click on Drive C in My Computer
5) Double click on the Windows folder and then double click on the System folder
6) Search for the file RATINGS.POL and right click on it and choose Rename. Rename it to RATINGS.OLD
7) Close out of the open Windows and then reopen Internet Explorer
8) Click on Tools, Internet Options
9) Click on the Content tab, then click on Settings
10) Type in the Supervisor password if necessary and click Ok
11) Select the Ratings options you would like and click Ok and close out of Internet Explorer
12) When you reopen Internet Explorer, everything should work.
on Mar 29, 2010 | Computers & Internet
Tip
How to uninstall Internet Explorer 8 if SP3 is installed after the IE update?
Here are the steps to uninstall Internet Explorer 8 Beta from the computer:
Note: These steps are only for Windows XP with Service Pack 3.
1) Click on Start, click on my computer.
2) Browse to C:\WINDOWS\
Note: You will have to unhide the files and folders:
1. Start Windows Explorer. To do this, click Start, click Run, type userinit.exe , and then click OK.
2. Click Tools, and then click Folder Options.
3. Click the View tab.
4. Click Advanced Settings.
5. Under Hidden files and folders, click Show hidden files and folders, click to clear the Hide Protected Operating System files (recommended) check box, and then click OK.
3) Double click on the folder “ie8′.
4) Double click on the folder “spuninst”.
5) Double click on the executable “spuninst.exe”.
Follow the prompts and then click on “Finish” to restart the computer.
Your Internet Explorer will roll back to the previous version (IE7 or IE6).
on Jun 19, 2008 | Microsoft Windows XP Professional for PC
Why i cant open internet explorer
When you click the Internet Explorer icon, window may flash a second and quits. Or, it may show an Error-Reporting dialog. This may be due to a malware Browser Helper Object which causes Internet Explorer process to terminate. If you see the Error-Reporting dialog, click "to see what data this report contains" and identify the Module Name causing this error. In most cases, it may be the malware DLL; in which case, reinstalling Internet Explorer may not help.
1. Click Start, point to Settings, and then click Control Panel.
2. Double-click Internet Options.
3. Click the Advanced tab.
4. Under Browsing, clear the Enable third-party browser extensions (requires restart) check box.
5. Restart Internet Explorer.
Download Ad-Aware from www.lavasoftusa.com and follow this:
1. Start Ad-Aware.
2. Click "Check for Updates", "Connect" and download the latest pattern file if available. and click Finish
3. Click "Start", "Next"
4. After the scan is finished, click "Next"
5. Select all the items (checkboxes)
Right click on any object in the "Scan result" list and choose [Select all objects]
6. Click Next and click OK to confirm removal.
Jun 23, 2011 | Computers & Internet
Internet explorer is not visible on desktop
Find a Missing Internet Explorer Icon in Windows XP
  • Step 1 Click the "Start" button. Click on "All Programs." Look for an icon called "Internet Explorer." Right-click the icon. Select "Copy" from the menu.
  • Step 2 Find a blank space on your Desktop and right-click on it. Select "Paste" from the menu. You should see a new icon called "Internet Explorer." Double-click it to make sure that it works.
  • Step 3 Open "My Computer" on your Desktop if you were unable to find the Internet Explorer icon in "All Programs." Double-click the "C:" drive. Double-click "Program Files." Open the folder named "Internet Explorer."
  • Step 4 Select the "iexplore.exe" icon and right-click on it. Choose "Create Shortcut" from the menu. Scroll down to the bottom of the window. Right-click the "Shortcut to iexplore.exe" icon. Click "Copy."
  • Step 5 Paste the icon to your Desktop. Open it to make sure it works.
  • Step 6 Click the "Start" button and select "Search" from the menu if you are unable to find the "iexplore.exe" icon in your Program Files folder. Search for "iexplore.exe." Locate the file. Right-click it to create a shortcut. Paste the shortcut to your Desktop.
  • Find a Missing Internet Explorer Icon in Windows Vista
  • Step 1 Click the "Start" button. Select "Run." In the "Run command" box, type "regedit.exe."
  • Step 2 Look for the key ""HKEY_CURRENT_USER." Click twice to open it.
  • Step 3 Navigate to "Software" and open it. Open "Microsoft," "Windows," "CurrentVersion," "Explorer," "HideDesktopIcons" and "NewStartPanel."
  • Step 4 Open the "{871C5380-42A0-1069-A2EA-08002B30309D}" key on the right side of the screen. Change the value to "0" to show the icon on your Desktop.
  • Jul 14, 2010 | Microsoft Internet Explorer 8
    Internet explorer cannot be found...
    Check if you maybe have some IP and DNS settings to your WL network adapter:
    Control panel
    Network connections
    Right to your WL adapter and click Properties
    On the end of the list in the middle you'll find:
    Internet protocol (TCP/IP)
    Double-click it and set IP and DNS to Automatically. . . .
    (OK, and than, again OK).
    Check Internet Explorer settings:
    Control panel
    Internet Options
    Click on Security Tab
    Set ALL zones to DEFAULT
    Click Apply and OK
    Regards.
    Mar 28, 2009 | Toshiba Qosmio F15-AV201 PM-1.8 Ghz,...
    It takes my PC a very long time to boot up, what can i do?
    If you have installed any softwares recently it might slow down the pc as many softwares will install a startup file in order to start faster. You can shut these programs from starting up when the pc starts.
    I put 2 steps to resolve this in order of simplicity.
    Remove icons from the Startup folder
    Some programs open with a shortcut icon in the startup folder (Startup icons). Use the following steps to show any startup icons that might be hidden and remove startup icons from the startup folder:
    NOTE: Removing items from the Startup folder does not uninstall the software program.
    1. Right-click the Start button, and click Explore . The Windows Explorer window displays with Start Menu already selected.
    2. Click the plus sign ( + ) next to Programs .
    3. Click Startup . The shortcut icons are listed in the right pane of the window.
    4. To show any hidden icons, click Tools , click Folder Options , and click the View tab.
    5. Click Show hidden files and folders (Windows XP/ME) or Show all files (Windows 98), and click OK .
    6. Click an unwanted startup item in the right pane of the window and drag it to a blank area on the Windows desktop. Release the mouse button to drop the icon onto the desktop.
    7. Continue dragging unwanted icons until all unwanted startup icons are on the desktop. Click Yes to any window that display asking to confirm the removal of a read-only file.
    8. Close Windows Explorer and restart the computer for the changes to take effect. Delete the startup icons that were moved to the desktop after you are satisfied with the way the software programs are working.
    If you find that a particular software program should not have been removed from the Startup folder, double-click the startup menu item to open the Startup window. Then drag the icon from the desktop back into the Startup window.
    Jan 11, 2009 | Compaq Presario 5000 PC Desktop
    Microsoft internet explorer problem
    Solution - I
    1. Open Internet Explorer.
    2. Go to "Tools Option" in "Menu bar".
    3. Go to "Internet Options" in "Tools Option".
    4. When you Choose "Internet Options" an "Internet Properties window" will Popup.
    5. Click on "Advanced Tab".
    6. Under Advanced Tab Look for "Unable third party browser extensions"
    7. Uncheck this Option
    8. Click "Apply"
    9. Click "OK"
    10. Close Internet Explorer.
    11. Restart your Computer
    Now you wont face Problems with your Internet Explorer
    Solution - II
    1. You Try Using Mozilla Firefox.
    2. It is free you just need to Download it from http://www.mozilla.com/en-US/firefox/.
    3. Download and save it on Desktop.
    4. Double click on icon and follow the Screen instructions.
    5. Compleate the Installation.
    6. you are Ready to Use.
    Jul 04, 2008 | Computers & Internet
    Internet explorer restarts when i try to download itunes
    try to download with mozillo firefox it will work.
    Apr 26, 2008 | HP Pavilion dv9000z Notebook
    Choose program to open with .... comes when i double click the hard disk partitions in MY computer
    download a43 a file manager
    run a43.exe and use it to explore your computer
    check the "hidden file" option and look for an autorun file
    delete the autorun file reboot and check with a43 again
    if the autorun.inf file is still present on your harddisk then you have an infection\\
    get back to me
    Dec 12, 2007 | Dell Latitude D600 Notebook
    Microsoft Office Outlook 2003 for PC Logo
    1,601 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
