Question about Canon PIXMA iP4300 InkJet Photo Printer
I have refilled my IP4300 8BK cartridge and the red light keeps flashing for that cartridge I forgot what I have to do
  • 2 more comments
  • alim4 Apr 12, 2008
    I am using the original ink cartridge that came with the ip4300, when I put it in it is all green but as soon as it locks in with printer on the side it now longer detects it and it is red.
  • Anonymous May 06, 2008
    **** u n ur printer
    78989689
  • trustedone_1 Jun 22, 2008
    i still havae ink in all the tanks. But the printer is still flashing the the little yellow light under the start button light. The error message i got said printer is busy retyr
Not true. i have 4300 and i refill it at list 2 a week. :) just tell the printer to stop monitoring you ink level when it askes and it should work.
Posted on Apr 25, 2008
  • 148 Answers
Some printers are not compatible with refilled ink. The best thing to do is buy original cartridge
Posted on Mar 21, 2008
SOURCE:
The one light keeps flashing red. (Looks like a waterdrop). Printer does not want to print
your printing catridge is empty. to refill by using inkjet cartridge or put some new cartridge it will work.
Mar 13, 2017 | The Office Equipment & Supplies
Ink light and paper light keep flashing alternately on my epson l110, how can i fix this ?
It may be a paper jam error. I find when you use an old or rough page in your printer, it don't properly go to its way and cause to displace a sensor that is situated at under the Head carriage of this printer which can be seen in following pictures.
Solution: check if this problem is occurred after paper jam then check the sensor is on its proper place or not if not then open the printer upper cover, open the lock of carriage rod from both sides. Set the sensor at its proper place and then check it.
Apr 17, 2015 | Epson Workforce 1100 InkJet Plotter...
Empty cartridge light keeps flashing
These cartridges don't have anything internally to check for new ink. They simply work on a basis of counting pages and page coverage to estimate ink levels. As such it is perfectly normal for your printer to warn of low ink once the cartridge has been refilled.
A low ink warning in itself should not stop your printer from printing though. If it does it is likely that the light is actually indicating a problem recognising the cartridge after refilling. I would recommend cleaning the copper contacts on the front of the cartridge and checking for any messages on the connected PC or laptop for more information.
Oct 16, 2012 | HP DeskJet F380 All-In-One Printer
Red light flashing
Dear assistenc, In laser printer red light flashes for mainly two reason. 1. If there is no paper, 2. If there is no cartridge or the cartridge is empty or having problem. So check the paper and cartridge. Must probably, it is the cartridge. Change the Cartridge and it will solved. But remember, in samsung printer, cartridge refilling is successful. So if you can, refill the cartridge, it is less expensive. Thanks.
Sep 05, 2011 | Samsung ML-2851ND Laser Printer
I have a Samsung ML-2525 BW laser printer. Recently, the red bar second from the top started flashing and then it went solid. I thought this was because of the ink toner, and the cartridge was running low...
I guess it FixYa didn't accept my (very long, but totally correct) solution that I took the time to type. Because I refused to "sign in".
Here's the short version. Load Paper. The same thing happened to me. I replaced the toner cartridge with a new one (because of a FLASHING red light for several weeks) after the red light went to STEADY red. But it still would not print. The paper was "out". When I'd refilled the paper-tray, it printed fine. I had just ASSUMED that the steady-red light meant toner was finally OUT. WRONG! That steady-red light had nothing-to-do with toner; it meant "you're out-of-paper". Don't get confused like I did. Refill the paper-tray. Then take that expensive NEW toner cartridge OUT, and put the OLD toner cartridge back in. And keep using the "dregs" of the toner out of the old cartridge for several more weeks. And DON'T get confused by the paper-is-out condition making that red light STEADY.
Nov 01, 2010 | Samsung ML 2525 BW laser Printer
Just changed cartridges to refills and clour and black lights flashinghowever we can still print ok. Why are the lights flashing?
The lights are flashing because you are using refilled cartridges. The printer "sees" those cartridges as empty, since it can not know that someone has refilled them. When you put in new cartridges, the lights will stop flashing.
Just ignore the lights and print!
Hope that helps!
May 19, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Hp f335 just refilled ink carts. Now i keep
Unfortunately there is no way to reset the electronics on this type of cartridge so your printer will always think they are empty. If the light flashes and you can still print, then just ignore the flashing. If your printer won't allow you to print, then the cartridge electronics must be bad. If the electronics are bad, there is nothing you can do to rescue the cartridge and you need to get a new one. I would return the cartridge to where you purchased it from and instead see if you have a Cartridge World store in your area. These stores would not sell you a refilled cartridge with bad electronics.
Dec 19, 2009 | HP Deskjet F335 All-In-One InkJet Printer
About Nashuatec Aficio SP 3200SF question
You could try going into the sp modes and check sp 5052-1 this is for independent toner check if the toner cartridge was checked by the copier as empty and you refilled it the machines check of the chip still senses it empty by turning this off it could reset it for you .. I have had some mixed results sometimes it works only occasional failure.. Hope it helps Good Luck A
Jul 03, 2009 | Ricoh Office Equipment & Supplies
Ink cartridge error message
Turn the printer off.
Hold down the Stop, B&W, and the Color buttons.
Press the ON button.
The LCD screen should flash 3 times.
Release the Stop, B&W and Color buttons
Press the Color button again.
Then turn the printer off and back on.
Aug 25, 2008 | Epson Stylus RX500 All-In-One InkJet...
Canon PIXMA  iP4300 InkJet Photo Printer Logo
397 people viewed this question
Clive
Clive
old marine
old marine
Ekse
