Question about Dell Inspiron 6400 Notebook
Laptop battery I have a dell laptop that i have had for about 5 month. I just about allways leave it plugged in to the outlet. Will this reduce the battery life by constantly charging? or does it not charge when connected to the outlet? Thanks
My Inspiron 6300 has always been plugged in and is circa 20 months old. I now find the unplugged unit (when moving from room to room) only lasts about 3 minutes from a full charge. Care should be taken with laptops if majority in charge. However, my Latitude is three years old and gets a mixture of on and off charge (docked via a port replicator) has been fine for about 30 months still giving out a respectable 3 or so hours use.
Posted on Apr 24, 2008
    Problem Solver:
  • 4 Answers
I have an ei systems 4411 left it plugged in to the mains all of the time and as a result overcharged the battery so be careful.
Posted on Mar 31, 2008
  • Dell Master
  • 19,396 Answers
It does charge until the battery reaches full charge, then charger stops and laptop use adapter's power. The whole system is thought to not damage or wear the battery while in charge. Leave battery safely inside your Dell while using it with power adaptor, it should not make any difference in your battery life.
Posted on Mar 21, 2008
Battery low while already plugged in
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 25, 2012 | Dell Vostro 1000 Laptop
When the laptop is unplugged does it l loose its charge even though it is not turned on? Also, can you overcharge and hurt the battery?
There is a gradual discharge from the laptop and the battery will go flat in a few weeks. The laptop is designed to charge the battery at an optimal rate. If you use the laptop on the mains supply with the battery allways, the battery will degrade. If you don't need the battery, charge it up and then remove it when you turn your laptop off. That way the chemical reaction is reduced and it will have a good shelf life. Charge it up twice a year if you are storing the battery.
Feb 16, 2011 | Dell Latitude D600 Notebook
I had my Dell Inspiron 1525 laptop running. The battery was running down so I plugged the power pack into the electrical outlet first and then into the laptop. The screen went blank and I have not been...
Which ever way round you plugged in should not have resulted in what happened.
You should have a green light on the adaptors case when plugged into the mains weather it's plugged into the laptop or not, if not check the plug fuse.
Is it the correct adaptor for the Laptop? TO CHECK look at the underside of the adaptor the output voltage and amps should be the same as on the base of the Laptop.
Hold the power button down for longer than 5 seconds to ensure the Laptop is off.
Remove the battery and try with just the adaptor plugged in ONLY if its the same output voltage as the laptop.
Remove the memory stick and replace then try and boot again this can sometimes reset the computer.
Leave the adaptor plugged in with the Laptop off to try and put some power in the battery and then try with just the battery.
I have a feeling the adaptor is faulty and it was coincidental that the laptop switched off as you plugged it in, I think you just ran out of battery power.
If in doubt get an electrical shop to test the adaptors output.
I have several 19.5V, 3.34A LAPTOP AC ADAPTER FOR DELL PA-12 KA04A
Sep 12, 2010 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Power problem
Seeing as you notice that your battery life is half, this most likely means your battery is no longer able to hold a charge, or a full charge. It could also mean the battery is defective.
If your laptop is still under warranty, the manufacturer may replace it. If not, you'll have to buy a new battery, unless you always keep it plugged in anyways.
Mar 23, 2009 | Dell Inspiron 600M Notebook
Battery percentage is decreasing...
If your battery is a lithium ion battery then according to the folks at Battery University:
"The worst condition is keeping a fully charged battery at elevated temperatures, which is the case with running laptop batteries. If used on main power, the battery inside a laptop will only last for 12-18 months. I must hasten to explain that the pack does not die suddenly but begins with reduced run-times"
see their website at :
Hope that helps.
Mar 13, 2009 | Dell Inspiron E1505 Notebook
Dell 530s unplugged for 5 months now asking for password?
I appears you have a Power on Password, the password is stored on an EEPROM chip and removing the BIOS battery will not reset or remove the password.
Try this password - Dell
Feb 25, 2009 | Dell InspironTM 1501 Notebook
Dell Laptop Battery
watching dvd reduces the the battery power especially when its uesd simultanously with other computer application that may reduce the hrs but since your mobile you need a portable device,and the option is to purchase another battery with more Ampere Hour (AH)rating that will last for longer hours more than 4hrs
Jul 19, 2008 | Dell Latitude D820 Notebook
Dell Inspiron 6400 Notebook Logo
146 people viewed this question
Alun Cox
