Dimension 2400 wont boot up screen remains blank and light to left of "on" button just blinks
  • 10 more comments
  • 12David Mar 21, 2008
    No but there is a flash of array lights on keyboard (momentarily)
    Have only a wireless router which has been running for over 6 months. Should i disconnect this?
    Is this a common problem?
    Cant open CD drive
    Not screen no beep black screen from start
    If i disconnect router will be unable to talk to you
    Have not refused any solutions just rerporting problem - server does not beep and remains inert, screen remains blank despite power light being on.
    will disconnect but this means shutting down this computer. I will return to you in about 30 mins when suggestions attempted.
    Have a second computer with wirelss router
    Thanks. But dont have a vga card (?) or memory card. Computer as supplied sealed and intact. CPU is not burnt no evidence of this. Motherboard - is this terminal?
    after shutting down for 15n mins and testing screen only change is that screen gives Dell logo for a mini second when booting up
    Dont understand yr response. Have told you staus and attempted all you have asked. But will re try other experts
    Thank you at least i know the problem is not fixable at my level.
  • 13,433 Answers
Hey, you said you dont get anything on the screen at all.
Do you hear any beep sounds?
If you don't hear anything and no picture comes up,
there are a few possible reasons
1. bad vga
2. faulty memory
3. cpu failed
Posted on Mar 21, 2008
  • 2 more comments
  • Ekse Mar 21, 2008
    Try with a difrent vga card
    If that doesnt help,
    try changeing the memory cards, example remove one
    then remove the other one and put the other one back in.
    check your cpu is it burned.
  • Ekse Mar 21, 2008
    on top of those 3 reasons there is a 4th one
    4. motherboard failty.
  • Ekse Mar 21, 2008
    Please take the computer to a local pc repair shop or a professional for analysis.
    or contact dell / dealer for warranty repairs.
  • Ekse Mar 21, 2008
    yeap, well good luck, theres not much to do since you don't have exeprience / knowledge in the internal parts of the pc.
    And it seems to be a hardware problem witch needs to be analysed by opening the pc and so on..
    If you need anything else let me know :)
    and do vote my support as helpfull or fixya if this is solved.
    Thanks
  • 796 Answers
It's possible that you have RAM problems. If you have more than one RAM module in your system, try removing different modules and seeing if you can boot. If you can boot with one of them removed, you've found the bad module.
  • isaac johny
    isaac johny Mar 21, 2008
    does it boot with a boot cd in drive??
  • 19,396 Answers
Aoes it give any diagnostic beep on start up?
  • 10 more comments
  • Ginko
    Ginko Mar 21, 2008
    If the computer does regular single beep then it can be the screen that is gone.
    Check first the screen cable moving it and checking that connector is well plugged in the socket.
    Then find a spare screen, even old crt ones are fine, and connect so that you can test for sure if it is the screen.
    Once you are sure that it is not the screen, start troubleshooting the PC:
    1)disconnect pc from poer outlet for 15 mins. and connect pc back to the power cable, this is called hard reset and sometimes fix issues related to firmware or static charges problem.
    after this there are two possible situations:
    a)the computer does one beep and shows something on the screen, then freezes while booting up
    b)the computer does not beep and show blank screen or black screen from start.
    It will be easier if you tell me in which of above situation you are.
    Pleas answer if you read this.
  • Ginko
    Ginko Mar 21, 2008
    Disconnect all additional devices while troubleshooting
  • Ginko
    Ginko Mar 21, 2008
    well you refused our solutions while starting, why should we keep posting, seems you do not need us, please correct.
  • Ginko
    Ginko Mar 21, 2008
    Please correct rating if you want to follow up with us, and then answer my wquestion above, do you see anything on your screen on startup?
  • Ginko
    Ginko Mar 21, 2008
    disconnect just ehernet cable on faulty pc, not power on router, and please correct my rating, I am not supposed to follow you if you refuse my solution (as you did), it is part of the game.
  • Ginko
    Ginko Mar 21, 2008
    We have those two yeloow cubes, that means you rated our solutions as unhelpful, that is a problem for us
  • Ginko
    Ginko Mar 21, 2008
    If your computer is faulty and does not start , how comes you are using same computer to chat with us?
  • Ginko
    Ginko Mar 21, 2008
    I will not assist anymore, seems there had been someconfusion. My and others' solutions had been refused on start by the User.
    Thanks for using Fixya, ask other experts
  • Ginko
    Ginko Mar 21, 2008
    You have not attempted anything because I did not even ask, unfortunately Fixya rating system seems not to be clear enough. There is no point for me in going on with assistance once my solution had been refused, you may get help from other expers.
    Sorry about this.
    regards
  • Ginko
    Ginko Mar 21, 2008
    Yes, try other experts.
  • Ginko
    Ginko Mar 21, 2008
    PS. I have been working for dell repair centre 3 years, try other experts, good luck!
  • Ginko
    Ginko Mar 21, 2008
    Thanks Ekse, sorry to 12David for dragging here Fixya's problems.
Dell Dimension 2400 runnning windows XP will not boot up
there are several issues and there are several solutions for this problem. I need you to please be more specific. Usually when a computer doesn't boot up, it goes to the initial black screen and usually it will display a message by the top left of screen where cursor is blinking. Please tell me whet that says, and I will tell you exactly how to fix the problem.
May 20, 2014 | Dell Computers & Internet
Have used dell dimension 2400 hard drive died replaced it now it only goes to boot device menu or black screen with blinking cursor
You will a full blown version of whatever software you want to install. Also try using the F8 key during bootup. See if the computer will boot up into Safe Mode. You should be able to made System restore disks from there if it will get that far.
Jan 21, 2013 | Dell Dimension 2400 PC Desktop
My dimension 2400 wont turn on it has a green light on the motherboard but wont boot up please help
What you can do is to try to open the casing and remove all the connections specifically the cables/connections from the power supply. Reconnect the cables and try it again. if still not, reconnect the memory modules and disconnect the connection/cable of the hard drive and give it a try. If that works, just do the same process and reconnect the cable back.
Note :
Ensure to unplug the computer first from the power before doing this. Once you have unplugged the computer from the power, press and hold the power button for 3-5 seconds. this will discharge all the remaining power that is stored on the capacitor.
Hope that works..
Happy TS...!
~jash
Sep 17, 2011 | Dell Dimension 2400 PC Desktop
Hi, I have a Dell dimension 2400 desktop. I plugged in a (wiped securely) hard drive. After it loaded the DELL LOGO BIOS, it shows a blank screen with a " dash -" on the top right corner. I...
try tapping the F12 key over and over when you see the DELL Screen to bring you to the boot menu....with your CD in choose to boot from the CD and it should allow you to run the OS installation from there.....your machine is trying to boot from the hard drive that has no OS on it.
Mar 29, 2011 | Dell Dimension 2400 PC Desktop
I have a dell dimension 2400 with a blinking amber light what do i do
The blinking amber light on the dimesion 2400 generally means that the power supply on the system has gone bad. Switch off the system and disconnect the power cord from the back of the system . Press and hold down the power button in the front for 10 seconds.
Reconnect the cable back and try powering on the system.
If the same ,fails you would have to take the system in for repairs
Proton
Sep 03, 2010 | Dell Dimension 2400 PC Desktop
The power light on my dell dimension 2400 is orange (it is not blinking). The loading light next to it is green. the computer is on but it will not do anything.It wont show the dell logo or anything. What...
You May hev one of two problems, either you towers power suply is broken, or on of the system fans are not working.
Check the power supply fan on boot. If its working check the CPU fan
Regards
Feb 21, 2010 | Dell Dimension 2400 PC Desktop
Dell Dimension 4600 PC Desktop
try safe mode f8 and go into msconfig and uncheak startup stuff ok
Jan 21, 2008 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
