Have a dell dimesni0n 2400. After shutting down on 20th March at 1000 attempted to restart later that day. Nothing appears on screen and light to left of start button blinks. Have checked leads and attachementsd and power is on. Also unable to open CD tray. Help
  • 55 Answers
 i think you have to try to disconnet the power cord and after a little
time try to power up after connetting the cable, if the trouble remain
you have to see if the fun of power supply is running or not if it is running the main board i loading program , if not you have the power
supply with problem change it - delfo
Posted on Mar 21, 2008
SOURCE:
How can i go to bios setup
Straight from the Dell website:
  1. Turn on (or restart) your computer.
  2. When "F2 = Setup, F12 = Boot Menu" appears in the upper-right corner of the screen, press .
If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft Windows desktop. Then shut down your computer and try again.
I hope this answers your question!
Apr 15, 2011 | Dell Dimension 2400 PC Desktop
Cannot read disk
"A disk read error occured press Ctrl+Alt+del to restart " FOLLOW THE BELOW INSTRUCTIONS TO RUN DELL DIAGNOSTIC ON INTERNAL HDD Open the Dell Diagnostics on either your hard drive (F12) or from the Resource (Drivers and Utilities) CD. Running from the hard drive is the preferred method of using the diagnostics. If problems occur when running from the hard drive or there is no Utility Partition, the diagnostics can be run from Resource (Drivers and Utility) CD. From your hard drive: Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. When the boot device list appears, highlight ?Boot to Utility Partition? on desktop systems or ?Diagnostics? on portable systems and press . Note: On portable systems, PSA will be executed first. When PSA completes, press any key to load the Dell Diagnostics.? Go to step 2. NOTE: If you receive a message stating that no Diagnostics utility partition has been found, follow the instructions on the screen to run the Dell Diagnostics from your Resource (Drivers and Utilities) CD. From the Drivers and Utilities CD ResourceCD: Insert the Drivers and Utilities CD into the CD drive. Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. NOTE: This feature changes the boot sequence for one time only. On the next start-up, the computer boots according to the devices specified in the system setup program. When the boot device list appears, highlight IDE CD-ROM and press . Select Boot from CD-ROM option from the CD boot menu. Select Run the 32 Bit Dell Diagnostics numbered list. If multiple versions are listed, select the version appropriate for your platform. Go to Step 2. After the Dell Diagnostics loads, the Main Menu appears. Click the button of the option you want. If a problem is encountered during a test, a message will display the error code and a description of the problem. Write down the error code and problem description and follow the instructions on the screen. If you can not resolve the error condition, contact Dell. If you run a test from the Custom Test or Symptom Tree option, click the tabs above the right window for more information: When the tests are completed, if you are running the Dell Diagnostics from the Drivers and Utilities CD, remove the Drivers and Utilities CD. Close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and restart the computer, close the Main Menu screen. Regards Sunil Dsouza
Dec 04, 2009 | Dell Dimension 2400 PC Desktop
My Dell Lattitude laptop shut down and won't restart.
possibly faulty battery. Try replacing it for a new one.
Nov 22, 2009 | Dell Computers & Internet
Computer will not re-boot
your hard drive has been corrupted due to improper shutdown
Oct 07, 2009 | Dell Dimension 3100 PC Desktop
Possible water or hard drive damage to Dell Inspiron 1000 Laptop
its fryed the GPU, sorry it won't work anymore, unless a miracle happens. If it was off and you left it off until it completely dried out (6-7 days) it would of still worked.
Sep 27, 2009 | Dell Inspiron 1000 Notebook
Can not get into safty mode get floppy diskette seek failure i have a dell dimension 5150
restart the pc and press F2 immediately after the dell logo comes on.
go into BIOS and disable the floppy drive. exit and restart the pc.
Feb 23, 2009 | Dell Dimension 2400 PC Desktop
Dell Inspirion 1000 power short circuit
Good Evening:
Hope that you are wellJ
  • There appears to be a shortage in one of your lines to you computer. But, before you replace anything, try these methods.
  • Shut down the computer.
  • Remove any CDs, DVDs or external storage devices (like USB keys or external hard drives) from the computer, if any are present, then press the power button to turn the computer on.
  • Press and hold the <F8> key as your computer starts. You need to press <F8> before the Windows logo appears.
  • If the Windows logo appears, and the system still fails to boot to Windows, shut down the computer and try again.
  • From the Advanced Boot Options menu, use the arrow keys to highlight Repair Your Computer, then press <ENTER>.
  • Click to select your language, and then click NEXT.
  • Log in as a user with administrative rights, and click OK.
  • From the Choose a recovery tool menu, click Startup Repair .
  • Once completed, click FINISH.
  • Click RESTART.
If I can be of further assistance, please let me know
And, remember; always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful weekend.
Oct 03, 2008 | Dell Inspiron 1000 Notebook
Black screen sometimes, system restore not working, remote assistance,
Did you try reinstalling the video card and display drivers?
What game was installed and how many days after installation this problem appeared?
Jun 04, 2008 | Dell Inspiron XPS M140 Notebook
Replacing a motherboard in a dell Inspiron 1000 laptop, and the screen not working
u need to reset the bios to factory defaults..this would fix your problem
Feb 06, 2008 | Dell Inspiron 1000 Notebook
Open Questions:
ESET TEch sUPPoRt pHoNe +{18OO.8O3..1O69 nUmber king Usa ESET USA phone number is ranked #2 out of 2 because 7,728 ESET USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach t he ESET USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, ESET USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. ESET USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact ESET USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling ESET USA Calling ESET USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from ESET USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with ESET USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare ESET USA's phone numbers against each other. Contacting ESET USA in General While I8OO8O31O69 is ESET USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach ESET USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact ESET USA.
Oct 22, 2019 | ESET Computers & Internet
Computers & Internet Logo
49 people viewed this question
Ekse
Marvin
Marvin
