Question about Ricoh Caplio R6 Digital Camera
Ricoh caplio digital camera
Lens stays open and there is a motor noise after switching it off
  • 6 more comments
  • Stewin Apr 06, 2008
    Camera has switched off but lens has not retracted. Power button will not switch camera on but electric motor noises can be heard.
  • Anonymous Apr 12, 2008
    I am having the exact same problem, does anyone have a solution for this?!
  • rasker May 01, 2008
    Hello there,
    I have a problem with my new ricoh r8, bought last week..........
    .it does not focus in any recording  mode , (playback is fine ).
    When on the green mode it says : "in synchronised monitor  mode ".
     The screen is black and when i press the button, just vague (no picture  ,just some variations of light )
    The camera makes quite a bit of  mechanical noise when turning on (more then usual ) and a lot of noise when turning it off ,sort of coughing and screeching .
    Please note that i am very carefull with my camera  (actually for thirty years i am a nikon-adept ), no dirt or dust on the lens or in the tube .I did not drop the camera or anything like that
    I tried the different settings , charged the battery etc .
    So, what can be the solution  ???
    Please advise ,
    Ewout J. Rasker
    Amsterdam ,
    The Netherlands
  • broad77 May 25, 2008
    I have just posted about my Caplio R7 with exactly the same problem.
    Steve
  • hluder May 28, 2008
    My Ricoh R7 bought 2 months ago has a similar problem.When I switch it on the lens extends and retracts about three times and then just dies.No screen display or anything.If I press Play(>) and Menu button it displays the screen.It also displays an error message:00-00-00
    30-00-28
    Anybody an idea what this means?
  • Anonymous May 31, 2008
    Lens is open and will not retract. We can review the last shots taken but, apart from motor noise, nothing happens. Only 16 months since purchase.
  • OzDave Jun 06, 2008
    Same problem with an older Caplio R3 model - lens wouldn't retract, camera made nasty grinding noises and the LCD screen showed a white and grey blur. Took it back to the camera shop where I bought it and they told me this is quite common with Caplios. Didn't tell me that when I was buying it!! Had it fixed but it took 5 weeks and cost almost as much as a new camera. When it works this camera is great - especially the 1cm macro - but the whole range appears to be mechanically unreliable.
  • baskey1 Sep 05, 2008
    Hi, Exactly same problem with my daughter's caplio R6 bought 9 months ago - lens won't retract on power off, image blurred in shoot mode, then goes black & lens makes whirring noise. Playback & menu screens working OK. sent back for repair under warrantee. Daughter is upset as it was her pride & joy - failed halfway into her holiday! I'll see if the repair is guaranteed as would expect a camera costing over £100 to last more than 12 months! Won't buy Ricoh again.
Stewin
Problem of lens not retracting fixed in one day by general camera serviceman. He said a part was broken and has fixed it without access to genuine parts.
Posted on Apr 29, 2008
This also happened to me last night.
My battery died mid-picture taking and now it's doing the same thing.
Any solutions? Please!?
Posted on Apr 13, 2008
Hi. Exactly the same problem here. it happened after I had a walk in the rain and had my camera in my backpack. It seems the backpack wasn't waterproof...
My lens isis stuck and will not retract
Camera requires servicing, which may not be financially viable. If this is the case, replace the camera.
Jul 15, 2016 | Ricoh Caplio R7 Digital Camera
Dear Sir, I accidentally dropped my Ricoh Caplio R6, 4 days ago, on concrete pavement while taking photos. The zoom lens was stuck open and cannot retract. Please give advise to me where to repair this...
Professional repair will likely cost more than the value of the camera. But here are some things that you might try yourself.Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
And here's a 16 minute video summary of the info shown in the link. But note that the article link above goes into even greater detail than this video:
utube.png You-Tube video "AkEfnF6zVxc" placeholder (do not delete) utube.png
Oct 23, 2011 | Ricoh Caplio R6 Digital Camera
Hi, someone drop my Ricoh R7 camera in the floor and since then the lens can not be withdrawn. It make some noise but isn't moving and doesn't switch on.
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
May 30, 2011 | Ricoh Caplio R7 Digital Camera
Ricoh Caplio R7 focusing problem
Go into the menu and find "reset"...follow the on-screen instructions.
Feb 24, 2010 | Ricoh Caplio R7 Digital Camera
Caplio R7 error 30-01-23
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 13, 2009 | Ricoh Caplio GX Digital Camera
Lens van mijn Ricoh Caplio R 6 gaat niet meer in of uit
Hoi Van de caplio R6 zijn geen onderdelen leverbaar, de camer moet worden aangeboden aan Ricoh Nederland ze zullen je een website aangeven waar je de gegevens kunt opzetten en daarna pas de camera kan opsturen aan hun servicecenter
Groet,
Rob Rotronica
Apr 15, 2009 | Ricoh Caplio R6 Digital Camera
Ricoh R7 Lens Jammed
you would love to see what was the truth as link following,
http://xiaolaba.wordpress.com/2009/04/25/camera-ricoh-caplio-r7-a-real-****-lens-error-00-00-00-30-02-23/
it was a **** design by RICOH, sent your message of compliant to them. you may get free service.
Jan 25, 2009 | Ricoh Caplio R7 Digital Camera
Camera jam
All the R series Ricohs have a pretty complicated lens system employing 2 swing-out lenses which can get stuck pretty easily, or worse, broken. If you are very good at taking things to bits you might have a go at fixing it (I've done several that were not TOO bad) since picking up one on Ebay with a good lens unit is almost impossible.
Jan 13, 2008 | Ricoh Caplio R5 Digital Camera
Ricoh caplio r3 digital camera.
This has happened to me a couple of times. It appeared when the camera was getting a lot of use and it wouldn't turn off - it was jammed on. I had to leave it a few minutes and not touch it - turn it off, then it was ok. I think it was overheated!
Jan 01, 2008 | Ricoh Caplio R3 Digital Camera
Ricoh Caplio R4 Lens
This is an easy fix for a camera shop. Just tell them that your lens is off track, and needs to be aligned. It should cost less than $50.00. If you are really good with electronics, you can attempt it yourself. Just let me know if you need the schematic to the camera. Best regards, Bill
May 20, 2006 | Ricoh Caplio R4 Digital Camera
Ricoh Caplio R6 Digital Camera Logo
434 people viewed this question
Top Ricoh Cameras Experts
Cleverer2
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
