Question about Black & Decker Compact Power Screwdriver
Instruction manual 5103069-09 ( a batter charger for a 14.4 volt drill) i need a instruction manual for the charger because i lost it and dont remember how long to charge the battery.
    Champion:
  • 313 Answers
See dewaltservicenet look for search info & type in model #
Posted on May 29, 2008
How do I recharge the 12-Volt Ni-Cad 3/8 in. Cordless Smart Select Drill
plug the batter into the correct charger or plug the charger into the side of the battery pack
May 07, 2016 | Drills
How can I test whether the charger or battery id faulty. I live in Windhoek,Namibia
You have to check You have to check the battery and charger for voltage with a volt meter. The charger should be putting out at least 14.5 volts and the battery should read 14 volts. There are metal contacks on the battery and on the charger inside the hole where you insert the battery.
Mar 11, 2011 | Bosch 33614-2g 14.4v Brute Tough 1/2"...
Both batters dead at the same time lithium ion 18 volt
sounds like your charger is faulty or both were drained & then got subjected to frost
Nov 30, 2010 | Porter Cable-Cable PCL180DK-2 18-Volt...
There is a yellow light flashing and battery not charging. I bought a second hand battery charger and it doesn't seem to be working either as there are no lights lighting up. Is there any way of testing...
the charger has three out points the one on the left at the side combined with the point at the back should be putting out 14 volts if not the charger is dead as for the battery the pack needs to be pulled apart and a test done on them that needs a tech with the proper equipment
hope this helps please remember to rate me
Nov 28, 2010 | Panasonic EY6409NQKW 12 - Volt Drill/...
My new Black Max 24v drill charger will not charge the battery
You indicate that the drill is new. I'd suggest you return it for a replacement. Seems to be a defective or wrong charger. If you have problems and If you paid by credit card call the card company and have them stop payment on that charge.
Feb 21, 2010 | Mx Black Max 24v Cordless 1/2 Inch Drill /...
2 Green lights flash, does not appear to charge. I have lost the instructions many moons ago. thanks.
try cleaning contacts on the battery and the charger then push batter in to charge, if the battey is old that will cause it not to charge. How old is the battery?
Aug 27, 2009 | Makita DC24SA 24 Volt Makstar Battery...
I have a mikita 12 volt and when I charge it it wont hold charge.
do you have a volt meter toi check the charger voltage? if so then read the voltage out of the charger, it should be 1 or 2 volts higher than the listing 12v would be 13 or 14 volts. if it's working you probally do have a bad battery. if the charger is out then you have a bad charger.
Aug 03, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Jobmate 18 volt chordless drill charging
About 60 minutes...max 90 minutes. Do NOT leave it on the charger for hours and hours...that just cooks the battery.
And switch regularly between the two batteries...else the one that doesn't get used will die.
Jan 20, 2009 | Drills
Black & Decker Compact Power Screwdriver Logo
229 people viewed this question
Top Black & Decker Hand Tools Experts
Robert Monigold
Robert Monigold
Don Numinen
Don Numinen
Are you a Black & Decker Hand Tool Expert? Answer questions, earn points and help others
