Question about Blaupunkt IDC-A09 5-Disc CD Changer
Cd player hi , i bought the above player it came out of a fiat but was said it would fit to a peugeot 307 the connections are the same but it will not power up
  • paulphillips Jul 17, 2008
    I can put CDs in and eject them, but I am unable to make them play or be recognised by the radio.
    Its in a Peugeot 307.
  • slowey Oct 10, 2008
    I have a cd player in my Peugeot 307 and it does not play CD's. The CD number lights flash. Can anyone help??
  • 199 Answers
Hi does it do anythig at all? does it flash?
Mark
Posted on Jul 21, 2008
SOURCE:
Fiat punto 2002 keeps draining the battery when i connect the new cd player
You will have to connect the power wire to the ignition switch so it powers off with the switch.
May 06, 2017 | Cars & Trucks
Why have I no radio reception on peugeot 307?
go step by step to find the fault.
check antenna connection behind the radio
check roof aerial and wire connection underneath it.
Take an old radio's antenna and connect it to your car's radio antenna input and check whether your car radio is working properly.
Apr 15, 2012 | Peugeot 307 Cars & Trucks
Peugeot 307 Audio
Anything is possible with a bit of fore thought ,take old one out then try to fit the new one the wiring plugs should be the same for two of them but the third one will work the changer so leave that disconnected
Nov 29, 2011 | Blaupunkt IDC-A09 5-Disc CD Changer
Connection problems
If the CD player has left and right outputs and the receiver has those inputs for a CD or DVD then there's a start.
Speakers...match them up to positive and negative with no power to either component.
Jun 09, 2009 | Kenwood VR-307 Receiver
Peugeot 307
having same problem. faulty after disconection of battery
Jun 03, 2009 | Blaupunkt Car Audio & Video
Flashing lights on cd changer, Peugeot 307!
There are a few variations of this model eg; IDCA09,IDCA04,Fiat & aftermarket units.As already stated these models do suffer from mechanism faults quite a lot.This is due mostly to the complexity of the mechanics.The flashing lights are a classic symptom of a jammed or broken part of the mechanism.They can however be repaired by certain car audio repair centres here in the UK.I'm afraid unless you know what you're doing then just by stripping the mechanism down is unlikely to cure the faults than can occur.
Feb 03, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Peugeot 307 Blaupankt CD Changer IDC-A09
Hi, I know this is an old post, but I'll reply, so that other readers may get the benefit of my answer.
2004 was the year that Peugeot/Citroen changed from VAN bus to CAN bus wiring on their stereo's. If your car is before or early 2004 you will need the IDC-A09 blaupunkt in dash changer, which should just plug in and work straight away.
However, If your car is later 2004 onwards you will need the IDC-A04 Blaupunkt changer which will plug in and power up, but will not work properly untill you go to a peugeot dealer and they hook up some diagnostic software to tell the car a changer has been added. Both the IDC-A04 and A09 changers look identical.
I would say that you got the wrong changer, as the IDC-A09 changers in pre/early 2004 should just plug in and work.
Remember: Pre 2004 cars need IDC-A09 (plug and play) and Post 2004 cars need IDC-A04 changer (get pug dealer to reprogram cars computer)...its a costly mistake if you bought the wrong one!
Oct 28, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Cd player
Ok guys thius it how it works.
Blaupunkt supply a repair kit for this unit, this basically is a fix. but only works for 8 out of 10units.
its a pain to fit too.
you have to replace the 3 spindle guides and arms. the part number is : 8619001490 there a reall complicated thing to fit.
i am looking to get a install guide sorted. and will soon be selling the kits on my website
www.carradiospares.co.uk
Regards
Mark
Blue ICE
Mar 11, 2007 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt IDC-A09 5-Disc CD Changer Logo
724 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
