Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
Overheating cpu i running amd athlon 64x2 dual core 4000 2.1ghz its overheating running at between 60 to 70. got 2 gig ram um dont know if my power supply could be the problem as its only 200 watts. had the thermal paste changed twice as i thought too much was applied that never helped. had two extra cooling fans installed to **** air into the casing that not helping either. set my bios menu to the fail safe settings no luck there. my motherboard model is GA-MA69VM-S2 chipset amd 690V. if anyone has any ideas or solutions to my problem as i am at the end of the road here. any advice would be greatly appreciated
  • puneetsa Apr 06, 2009
    what should i do i have same problem
  • Intel Master
  • 13,433 Answers
What kind of a heatsink you have on it? my x2 6000 doesnt go over 40 most of the time.
Posted on Mar 21, 2008
What is the best upgrade cpu for a compaq presario sr5110nx 32 bit vista O.S... ATHLON 64 (single core) without having to go to 64 bit, and/or new drivers ?
The 400W PSU is going to limit your CPU selection to dual-core at best, although you might be able to get away with a higher-end dual-core CPU if your RAM is not ECC and not dual-channel, and you're not running anything serious in terms of a graphics or sound card or a SCSI array.
Given your current setup I'd really look for a 1.6Ghz dual-core Athlon which has a decent amount of KB in its Level 1 and Level 2 cache, but 3MB for its Level 3 cache.
Anything beyond that ballpark of a CPU upgrade is certainly well within the bounds of diminishing returns, and you should look at getting a new PSU, motherboard, and probably RAM (I'm guessing you're using DDR2 RAM currently).
May 24, 2014 | Compaq Presario SR1050NX (DW257A) PC...
Processor upgrade
upgrade your ram mem, best bang for the buck
Mar 23, 2013 | Lenovo 3000 Computers & Internet
Driver for motherboard ga-ma69vm-s2 for amd athlon 64x2 dual core
To get all drivers for that motherboard GA-MA69VM-S2 for AMD athlon 64x2 dual core(AMD socket AM2). click the following link http://www.gigabyte.com/products/product-page.aspx?pid=2500#dl
And then select your present operating system to download all drivers compatible.
Let me known if not yet working properly your motherboard for that software driver.
Thanks for using Fixya.
Jul 25, 2011 | Computers & Internet
Hi i have a imedia desktop, the mobo is a msi 7168 ,( socket 939) the origional cpu is a amd athlon 3200 single core ! now i have replaced this with a dual core athlon 4400+ now the memory has 4 dimm...
First time I heard that But Maybe your board needs a bios update which I personally wouldn't do unless you really know what your doing. I would buy better ram and more of it and just use the two slots that work.
Jan 24, 2011 | AMD (90613) PC Desktop
What is the best procesors(powerfull) for motherboard NF 61S MICRO AM2 SE..?
AMD Athlon™ X2 Dual-Core Processor
AMD Athlon™ 64 X2 Dual-Core Processor
are the best processors for this motherboard
Nov 28, 2009 | Biostar NF61S MICRO AM2 SE...
I have a Lenovo 3000I have a Lenovo 3000 J115 7387-A32, I replaced the AMD athlon 64x2 Dual-Core 3600+ with a AMD Athlon X2 5000+ 3200mhz Scoket AM2+ CPU, when I turn on the computer the fan in the power...
I think the first thing to do is go back to the cpu Fan and check the plug and make sure you are on the pins as should be make sure that there isn't any Bent pins . Continue on to the next fan in question.If not then I would not continue Running this machine Until I had the fan problem fixed. It doesn't take long to mess things up. I am surprised that it will run . I would like to have faith in the hardware monitor to propely shut it down.then I would go to the power source Plug on the motherBoard . Check that it is connected good and try it for a short run on then off to make sure that the fans are running like they are supposed to.
Nov 19, 2009 | Computers & Internet
AMD Athlon 64x2 brisbane 2.9 ghz fans too loud now WHAT TO DO!!!
If you have no heating problems,and you used good cooling paste ,for resplace the CPU ,only loud problems, you can leave the original copper core cooling fan.first reset the pc, when you see the Welcome window of the motherboard (ASUS FOXCOMM, BIOSTAR ECT) click delete repeatedly, you will enter the bios setup, very carefully,only looking for (cool and quiet) and check this, you can also need to check the CPU temperature ,,normal is 35 C to 45 C ,(if the temperature is over 50 C,reistall the CPU and used new cooler paste) ,then you give scape. save the changes and restart the PC, now the motherboard fan speed controlled, as required, only spun faster when you really need to cool the prossesador, such as a very graphical game ect, really going to notice a big change cpu fan sound, if that cool and quiet and had been activated o this is a factory PC like DELL ,ACER ,ect ,and have no change, you can buy a new cpu fan on e-bay very cheap,like factory amd 64x2 6000 cpu fan and for no will have more trouble
Aug 05, 2009 | AMD Athlon 64 X2 5600+ 2.9 Ghz Skt Am2...
Want to get more ram for my computer
Use the free tool on this site to scan your PC to determine what kind of memory you need:
http://www.crucial.com/index.aspx
Mar 16, 2009 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
106 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
