HP OfficeJet J4580 All-In-One Laser Printer Logo
Posted on Apr 18, 2010
The machine does not print. It does not grip the paper. It does however grip the paper to do a Photocopy and it does print out the print align page. what could be the problem
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
518
Points
I had a problem with attaching the printer every time I hooked up the USB cable the computer said, " USB divise malfunctioned". I replaced the USB cable and it wooked fine.
Oki microline 280 eco jumps around .75" for each new page
There could be a few possible reasons why your Okidata Microline 280 Eco printer is jumping around 0.75" for each new page. Here are some things to check:
  1. Check the paper feed mechanism: Make sure the paper is feeding correctly through the printer and that the paper guide is properly aligned. If the paper is not being fed correctly, it can cause the printer to jump around.
  2. Check the tractor feed mechanism: The tractor feed mechanism may not be gripping the paper correctly, causing it to feed inconsistently. Make sure the tractor feed mechanism is properly aligned and tightened.
  3. Check the page length settings: Double-check that the page length settings are correct and that they match the size of the paper you are using. If the settings are incorrect, the printer may not be able to print the entire page and may skip to the next page prematurely.
  4. Check the top of form settings: Make sure the top of form is set correctly and is not too close to the top of the page. If it is too close, it may cause the printer to jump around.
  5. Check the print head alignment: If the print head is not aligned correctly, it can cause the printer to jump around. Check the print head alignment and adjust it if necessary.
If none of these steps resolve the issue, it may be a hardware problem with the printer itself. In that case, you may need to contact Okidata technical support for further assistance or consider taking the printer to a professional repair shop.
While taking a print or photocopy shadow is coming on the center of the paper
My printer printing shadow behind all the letters
f you are running the printer's Full Feature Software, go into the Solution Center in the Toolbox and look for a way to clean the cartridges and / or print heads. Do it twice. It uses a bit of ink, but it will get any extra residue drifting around on the nozzles.Your printer's Webpage:
HP Photosmart C4795 All-in-One Printer
Look on the Menu (on the Printer) for the Alignment test. This may also be listed in the same area in the software section where you find the "clean cartridges" option.
General Instructions (may vary):
Align the print cartridges
The printer automatically aligns the print cartridges after a new print
cartridge is installed.
You can also align the print cartridges at other times to ensure optimal
print quality.
To align print cartridges:
1. Load Letter or A4 plain, white paper in the In tray.
2. Open the printer Toolbox.
3. Click Align the Print Cartridges.
4. Click Align, and then follow the onscreen instructions.
How do I print on A4 envelope with Canon ir 4080i photocopy/printer machine?
in printer just put your envelope portrait position, then set your paper setting into envelope size in your laptop or PC and just print it
in photocopy machine just adjust the input tray into envelope size than put envelope printed face up, and just print it
11helpful
My printer is telling me to "press enter to align the cartridge". i did that but, nothing is happening. HELP!
Solution There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • The paper has already been printed on or is colored paper.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The ink cartridge is defective.
Follow the steps below to resolve the problem Step one: Examine the paper the alignment page was printed on The alignment page must be printed on clean plain paper of either letter or A4-size and that has a brightness level (as printed on the paper package) of at least 85. Colored papers or paper that already has printing on it will cause the alignment to fail. Back to top Step two: Does the alignment page print correctly For the HP PSC 900 series, if the page ejects immediately or a Paper mismatch or Paper too narrow message is displayed, the 4 x 6 paper tray selector located on the paper output tray is pushed forward. Move the selector all the way toward the front of the product. Look at the alignment pages that the product printed. Compare the alignment page to those that are included in the "Examples of alignment pages" section in this document. If any of the colors or the black is missing from your alignment page, a cartridge-related problem exists. Click here for information about troubleshooting ink- and cartridge-related problems (buu02176) (in English). Back to top Step three: Perform an print cartridge cleaning procedure The product can perform an print cartridge cleaning procedure even after the alignment message has displayed. Follow these steps to perform an print cartridge cleaning procedure at the front panel:
  1. On the front panel, press the Menu or Setup button (depending on the model).
  2. Press the right arrow button (>) until Maintenance or Tools is displayed, and then press the OK or Enter button (depending on the model).
  3. The Clean Print Cartridges message should display on the front panel. Press Enter or OK to begin the cartridge cleaning process.
A page will be printed during the cleaning process with all of the colors on it. If any of the colors (including black) are missing, faded, or streaked on the alignment page, there is a ink cartridge problem. Back to top Step four: Try to align the page again HP products have two methods for aligning the ink cartridges, fully-automatic and semi-automatic. The steps are different for each type. Refer to the information below to determine which alignment method your product uses. Automatic cartridge alignment Perform the following steps to align the ink cartridges:
  1. Disconnect the power cord from the unit, wait five seconds, and then plug it back in. This will reinitialize the unit.
  2. Print another alignment test page. If the Press Enter to align message is not currently on the front panel display, complete the following steps to print an alignment page:
    1. Press Setup or Menu on the front panel (depending on the model).
    2. Press the right arrow button (>) until Maintenance or Tools is displayed, and then press Enter or OK (depending on the model).
    3. Press the right arrow button (>) until Align Print Cartridges is displayed, and then press Enter or OK (depending on the model).
  3. To determine if the automatic alignment is functioning correctly, look into the output tray as the alignment page is printing; a blue light should be visible periodically on the page as the cartridges move back and forth. If this light is not visible, the product will not be able to align the cartridges and will require service. Service the product.
  4. If the blue light is visible and the alignment pages are printing correctly, but the alignment pages still fails, there still may be a hardware problem with the unit.
Only printing 1/4 of page
Follow steps below
Load photo paper or plain paper with the print side facing you.
Open the All-In-One Center.
Click the Saved images tab.
From the Creative Tasks section, select Print an album page with various photo sizes.
Click Change the category of layouts listed above.
From the Selected Layouts box, select for example Only Borderless.
Click OK.
Select a paper size for the photos <- use DIN/4 to print on whole page
From the Page Layout area, select a page layout.
Drag the photos onto the page.
Click Printer Settings.
Select the paper size and paper type. <- use DIN/4 to print on whole page
From the Quality menu, select Photo, and click OK.
Click Print Now.
Hope this is helpfull and answers your question.
1helpful
HP C6180 won't align print cartridges
hi Alignment of ink cartridges is very essential for the for the printer to print so first of all be sure that you are using geniun ink cartridges now lets try a reset on your printer press the # and 3 button on your printer together and then unplug the power cord from your printer and keep pressing the buttons now wait for 5 sec and while pressing # and 3 replug the power cord wait for the printer to initialize and see if it prints alignment page if no page is printed then click on the start button of the computer and then go to printers and faxes and then right ckick on the icon of your printer and click on printing preferences now go to the features tab and click on the button that says align print cartridges wait for the alignment page to print and now try and see if it prints fine
Always starts up and does an alignment page.
  1. After installing a new print cartridge, wait at least 20 seconds for the print cartridge alignment process to start.
  2. Wait for the print cartridge alignment process to fully complete.
  3. Make sure that the alignment page has printed on plain, white paper that has no other printing on it. If you need to create a new alignment page, load the tray with letter or A4 unused plain white paper and turn the product off and on again to create the page.
    after the alignment page prints then place the alignment sheet on the scanner glass and press the ok button
Changed black cartridge. Machine works fine, but
To align the cartridge from the control panel:
Please follow the steps given below:
1. Please Load a plain paper.
2. Press and hold the "Scan" button for three seconds.
3. An alignment page prints.
4. Place the alignment page onto the scanner glass.
5. Press the "Scan" button.
6. Once scanning is complete, the cartridge has been aligned for optimal print quality. Alignment must be complete before continuing with any print jobs.
Printing Alignment
Is the paper cassette set to the correct paper size and/or the printer driver printing to the correct paper size? Sometimes this can cause the image to be offset.
k24674
Grand Canyon Tech
Grand Canyon Tech
