Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
2003 gelly 50cc motor scooter
Can u tell me where the bottom fitting for fuel or air connects to on the carb its leaking gas and dont know where it is supposed to connect 2 have no idea but am searching for a blueprint of it ,,,it is 2 stroke also 21 model older looking style
  • 1 more comment
  • kilburn Mar 21, 2008
    helpppppp
  • Anonymous Apr 28, 2008
    getting to much gas
  • Louie  Role
    Louie Role May 11, 2010
    There two (2) types of carbs for the two stroke engine as used in scooters and/or pocket bikes. 1 is with the 2T oil premixed with the gasoline in the fuel tank and the other is where the 2T oil has its own reservoir separate from the fuel tank with the carbs doing the mixing.
    Please which one do you have? Additionally is it a branded scooter (Honda, Yamaha, Suzuki) or is it a China made?
    Looking forward to your post. Good luck and kind regards.
    Thank you for using FixYa.
Hi i have a 2 stroke gas-oil mixed motor scooter and the probelm i am haveing is that the pull start wont go back in after i pull the cord out
Posted on Jan 12, 2009
    Brigadier General:
  • 6,966 Answers
Hi again,
Any development(s) with your carbs?
Posted on Mar 23, 2008
SOURCE:
My 50cc scooter won't go over 30mph
Hi, Bob and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Damaged or restricted fuel tank venting system.
4. Dirty or damaged air cleaner element.
5. The accelerator pump is inoperative.
6. Vacuum piston assembly malfunction.
7. Enrichener valve is not seated or leaking.
8. Restricted fuel supply tract.
9. Plugged bowl vent.
10. Loose or plugged fuel and air jets or passages.
11. Improper float level.
12. Worn or damaged needle or needle jet.
13. Loose or plugged main jets or passages.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Help Ruck won go above 30mph Thanks
Advice please 49cc won go over 20 mph
gy6 50cc to 100cc bbk upgrade still wont go over 30mph It Is The Ride
My scooter won reach top speed anymore scooters
SCOOTER WONT GO OVER 20MPH HELP
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 28, 2017 | GAS Motorcycles
My 50cc Scooter has a brand new carb but gas is leaking from overflow ???
Hi, Kim and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Carburetor is leaking gas out of overflow tube need help
Carburetor Carb Leaking Gas How to Fix Repair it Motorcycle Honda DIY...
http://www.49ccscoot.com/manuals/Hyosung_SF50_Service_Manual.pdf
50cc scooter parts QMB139 49cc 4 stroke parts moped parts QMB139
http://www.yamaha-motor.com/assets/service/manuals/2008/zuma_lit-11626-21-15_1548.pdf
Jan 04, 2017 | Motorcycles
I took scooter for a ride everything worked fine get back to garage and fuel is leaking out of carborator to which it drained the fuel tank. Do I need a new carb or what's the problem.
Jason, You can replace carburetor or have the old carburetor rebuilt to fix your gas leaking problem, either float is stuck or if carburetor equipped with a solenoid shut off, are the actual problem likely.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Carburetor Rebuild Cleaning Instruction Video
3 50cc Scooter Moped Carb Theory and Common Carb Problems
How to clean scooter carburetor
rebuild scooter carburetor Google Search
Jun 18, 2016 | Motorcycles
Have no spark to plug found a 2 wire clip with the same colors at the battery area that is not connected to anything. dont know where to connect trouble finding manuals or video
My scooter has no spark how to fix. gy6 chinese ... - YouTube
? 2:29
https://www.youtube.com/watch?v=UU4S0Ov9q4c
Aug 24, 2012 - Uploaded by Rolling Wrench
Purchase our "NO SPARK KIT" click the link below: ... Myscooter has no spark how to fix. gy6 chinese scooter 139qmb qmb139 50cc 150cc .... i have a 2003 panterra fusion scooter with a 49cc motor,i just purchased a new cdi box,new coil wire and a new stator and ... Put gas in it tried it again nothing.Missing: rto
RTO 150cc scooter no spark Questions & Answers - Fixya
www.fixya.com/tags/150cc_scooter_no_spark/browse/rto
Ask your RTO 150cc scooter no spark questions. Get free help, advice & support from top RTO experts. ... no spark. Ad. Question about Gas Motor Scooter 150cc.
Nov 29, 2015 | RTO 150cc Gas Motor Scooter
How to bleed fuel lines
It is quite possible the fuel cap is not vented properly or the fuel is vapor locking ,,, is the scooter running till it gets very hot?
Check the fuel cap for venting first,, is it possible you have bad gas?
or the vacum pump on the carb is not working correctly
Aug 22, 2014 | RTO 50cc Moped Scooter
50cc taotao scooter the carb is runs then fills with gas untill it stalls out dont get much off the searchs i have made dont no if it is the carb our choke broke down carb and looks clean no clogs or
My 2012 Taotao 49cc scooter was spitting and sputtering then just died one day. I brought to a small engine repair person and come to find out, the hoses that came off the carb had cracks in them. Changed the hoses and the problem went away. Hope this helps.. I have since replaced the cheap hoses with new ones from the auto parts store and never had the problem again.
Oct 21, 2012 | Star 50cc scooter for kid
I rode my 50cc scooter in the rain, with no air filter.
If you allowed water to get into the air inlet, if a 2stroke, I suspect the crankcase seals are damaged. If 4 stroke check compression for damaged piston.
May 28, 2017 | Star 50cc MOTOR SCOOTER
On a kazuma 50cc engine carb adj screw location
The lower of the 2 screws is the fuel/ air mixture- the upper screw is the idle adjust screw
Jan 22, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Fuel bowl on my 50cc scooter keeps empting and killing the engine I keep adjusting the carb fuel screw on the carb but I still have the Fuel bowl empting. Does anyone know if I need to turn the fuel screw...
It has nothing to do with the adjustments, what is going on is your float is stuck in the carb , you will have to take the float bowl off , float is sticking than you will have to try and clean the needle and seat valve.
Sep 07, 2009 | RTO Gas Motor Scooter
Gas leak from bottom of carburator
The line you are talking about is the carb overflow line. It does not connect to anything. It sounds like the carb needle valve or carb float is sticking in the open position allowing fuel to constantly flow into the carb. You should take the carb apart and examine the two parts I mentioned.
May 04, 2009 | Yamaha XS2 Motorcycles
Lands Phones Logo
543 people viewed this question
Top Harley Davidson Lands Phones Experts
Tom Diffin
Sheldon Dedek
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
