Question about Epson Stylus C66 Inkjet Printer
Nothing appears on the paper
Hello Jaydbu,
DId you find a solution for the problem..?
my printer suddenly stopped printing any thing..? I cannot find the problem
Did you have any luck..?
Nikolaj
  • 1 more comment
  • hakimbensala Apr 23, 2008
    MY PROBLEM IS INSTALLING DRIVER FOR PRINTERS /EPSON STYLUS C66
  • prings48 Sep 23, 2008
    my paper comes out with nothing on it i have a epson C66 it was printing fine ink got low replaced all four cartridges and now nothing prints to paper black looks like it is going down when printer dispay appears on screen any suggestions
  • mwasserstom Oct 03, 2008
    everything checks out except nothing prints out on the paper. it worked fine for a year and now nothing
Www.lipfeed.com/user/bluejack i found a solution
Posted on Aug 29, 2008
SOURCE:
Hello, My daughter was printing off her university notes perfectly tonight and all of a sudden my Samsung SCK - 1400 printer stopped printing and said [No Paper] Add Paper. So I added the paper and i...
there is a paper sensor in a paper tray where you put papers just near the pick up roller kindly check it out that it actuates when you put papers in it
Jan 20, 2011 | Office Equipment & Supplies
My printer has stopped printing. it makes copies of documents but it wont print nothing. it stores the number of times i ask it to print a file. p,se help
Hello
Check the cabels from computer and printer , seems that it cant find your printer . Or the drivers is not working as they should. If your printer is trying to print and the paper is going thru the printer as it should , and if there is no text then its the cartridges. Or its wrong paper in the printer.. The worst thing is if you can not get your printer working at home or with a friends computer you need to buy a new one.
Best regards
Joakim
May 22, 2010 | Lexmark X4650 InkJet Printer
My printer cannot print
Hello there Some times this is down to a small bit of paper sticking in it or some some thing ells.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 08, 2010 | Brother MFC 210C All-In-One InkJet Printer
Hello, my Canon PIXMA IP1600 is suddenly not working and has a code 5100 erorr. What to do?
Error 5100 is always a carriage error.
first thing to do is check is check the timing strip(plastic strip wide around 1/4 inches and usually located behind the print head)
Make sure there is nothing around it like piece of paper or staple or pen/pencil etc.
Make sure the strip is moving freely and hasnt come out of the roller.
Check VERY thoroughly for any obstruction at all, a very small piece of paper can cause the problem.
Dec 01, 2009 | Canon MultiPASS F60 All-In-One InkJet...
DOES NOT PRINT ALL OF A SUDDEN STOPPED PRINTING AFTER RAN OUTOF OF PAPER.PUT IN MORE PAPER, PRESSED "PRINT" NOTHING HAPPEN HP S
Hi dep209
Clear all the documents in the printer queue. To do this go to the printer folder.
You can do this going to the Control Panel
Click on Printers
Click on the name of your printer to open the folder
If few documents are listed there cancel all of them.
Then turn the printer of and on again
Now try to print
Hope this will help you.
luciana44
Oct 04, 2009 | HP Office Equipment & Supplies
My printer suddenly stops printing then it says paper jammed even it isnt... i try not to load paper but still that message appears.
the paper sensor pin is jammed up in sensor so it detects that the paper is still there.even though its not there.get the printer serviced so that the sensor moves freely.this will solve the problem. please do not forget to rate the solution.thanks
Jun 12, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Printer suddenly stopped printing
verify if you are printing with the correct paper size..... long is 8.5 by 13 and not 8.5 by 14.....
or
1. delete the installed driver
2. turn off the printer and let your computer detect the printer.... let it finish
3. restart your computer
Nov 09, 2008 | HP LaserJet 1020 Printer
Hp psc 2175 all in one printer keeps giving me a paper mismatch message.
Hello tabbeach. The printing cartridge align page message appears if u have any alignment job pending, if it asks to print the alignment page. Follow the steps provided here.
Still if u are facing the same issue, perform a HP Media sense caliberation , which in most cases will resolve the issue
the steps to perform media sense calibration are provided here .
gud luck
Sep 25, 2008 | HP PSC 2175 All-In-One InkJet Printer
Epson Stylus C66 Inkjet Printer Logo
60 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
