Question about Ricoh Aficio CL3500N Laser Printer
Error code SC 544
Due to voltage fluctuation the problem occured
  • 2 more comments
  • Anonymous Jun 12, 2008
    error SC 544
  • claymepc Sep 24, 2008
    how do i get into service mode in a aficio cl3500n, please reply i need to reset the error
  • ogutierrez Mar 23, 2009
    I have a Rocoh 2238c and have an error code of SC 544. I already changed the fuser unit and oil but still no luck. How dod you reset the code from the machine
  • murujuju May 03, 2009
    the machine was working well then suddenly it started showing the error code sc544 and there was this information "functional operation fail".
  • Ricoh Master
  • 691 Answers
Relates to fuser unit. Needs to be reset from service mode.
Posted on Jul 06, 2008
The machine was working well then suddenly it started showing the error code sc544 and there was this information "functional operation fail".-
Posted on Jan 20, 2010
Reset from the service mode and turn off the printer and return back on.
Posted on Jun 11, 2010
    New Friend:
I reset alredy but not function ready sme error code 544 coming
pls find what problem
Posted on Jun 09, 2014
Help need for getting rid of SC 544-00 on a Ricoh SP C830DN machine.
SC 544 is a fuser overheat error. This could be caused by power outage or fluctuation in the power.
go to service mode. Hold down both "home" and "simple screen" for about 5 sec. and then press "user tools"
once in service mode go to SP5810 reset fuser error.
and reboot the machine.
Feb 19, 2017 | Ricoh Aficio SP C830DN - Printer - color -...
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
Pro c900. What does error code sc544 mean?
SC 544
Heating roller thermopile (center) error 3 The thermopile detected a temperature over 260?C. • TRIAC short, AC drive board defective • Defective IOB 2 • Defective BCU sc_note_1.gif
Related SC code: SC 553, SC563 1. Do SP5810 to cancel the SC fusing code. 2. Replace the AC drive board. 3. Replace the IOB 2. 4. Replace the BCU.
GO TO SERVICE MODE AND SP5810 to Clear - Check temp inputs - SP5803 150, 151, 152
Mar 13, 2016 | Ricoh Office Equipment & Supplies
I have LANIER LD115 Copier/ printer can not copy and print ,red light showen on copy button,Erro shown " SC: 544" AND " CALL SERIVCES" , GREEN Light on copy indicator, red on printer light, shown up
The copier error code SC544 / 544 is a fusing lamp overheat error code. (This is a hardware problem)
This error can mean the:
PSU board is bad
IOB board is bad
BICU board is bad
Defective thermistor in the fuser
Defective power supply
You need to contact a local service technician to take a look at your copier.
Nov 08, 2014 | Office Equipment & Supplies
I have copier it given me this code SC 544 & SC 542 & SC 500 can you assist me please .
overload of the main motor or fusing unit (SC 500)
Look at your fusing unit, (rollers, thermistor, lamp, gears...)
and don't forget to reset SC code in SP mode.
Good luck
Jul 03, 2011 | Ricoh Aficio MP 161 Black and White Copier
Error occured SC:302 Functional Problem Turn main power switch off and on if the error appears again. Call Service
SC:302
Charge roller current leak
Symptom: A current leak signal for the charge roller is detected.
Possible Cause:
?? Charge roller damaged
?? High voltage supply board defective
?? Poor connection of the PCU
May 27, 2011 | Ricoh Aficio MP 1600L Black and White...
Ricoh Aficio 1013 error code sc 544
Fusing low temperature error
Symptom: Detected fusing temperature
remained abnormally low for 1
second during fusing operation
(below 140°C) or during standby
mode
Possible Cause: Fusing thermistor defective
• PSU defective
• Bad connection between fuser and
machine
Dec 18, 2010 | Ricoh Aficio 1013 All-In-One Laser Printer
Error sc:544
Hi
SC544 error means Fuser Overheat Error 1 (Hardware). This has happened due to Fuser Low Temperature which occurs due to Abnormal Hot Roller Fusing Lamp Lower Limit Temperature Detected. Try turning off & unplugging the copier for 10-20 minutes to check if error code resets. If it doesn
Oct 09, 2010 | Gestetner DSm615 Digital Imaging System
Ricoh Aficio 1224c error code SC 544
Well, I have no idea why changing your password would affect it this way. the code you're experiencing is a fuser warm up error, due to blown fuse, thermostsat, possible power supply prob...regardless, it can only be reset by a service tech in service mode once the problem is fixed. Sorry.
Mar 05, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio CL3500N Laser Printer Logo
5,041 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
