Question about Vacuums
I need a part for my vacuum - Vacuums
  • 126 Answers
Make? Model? which part?
Posted on Mar 21, 2008
SOURCE:
Can it vacuum liquid
Hello, Atholl -
Only a vacuum which is identified as a "wet" vacuum or a "wet-dry" vacuum can vacuum up liquid. Also an electric carpet shampooer and an electric floor washer can "vacuum up" liquid.
If you need to know about a specific make and model of vacuum, you need to choose Comment and add the make and model there.
Best wishes.
Apr 02, 2018 | Vacuums
I want a diagram for a 1.9 tdi passat 2003 vacuum pipes to refit
you dont need any diagram, you need to know how it works. Start from vacuum pump , on all valves you have vacuum in on the top , in the middle is vacuum out (stgering) ad the bottom lines is going to air filter. Thats all you need to know
May 22, 2014 | Vacuums
My bissell will not stay on
turning off is probably most likely caused by over heating because the filters are clogged and need to replaced or cleaned.if you are in Colorado bring it in to the Bissell vacuum cleaner centerBagless vacuum owners have the misconception of maintenance free and part free vacuuming. Every Bagless vacuum machine has filters that need to be replaced usually every 6 months. That same filter also needs to be cleaned monthly or bi-monthly depending on usage.
Jun 05, 2012 | Bissell 6594 PowerForce Bagless Upright...
Good Morning, after plugging the kirby in, I began to vacuum and a light started flickering from the back of the motor and then the sound while vacuuming starting getting louder and the light flickered...
The carbon brushes in your motor are worn out and "sparking" against the motor armature. DO NOT operate the vacuum in this condition or you may damage the armature so badly it will need replacement. Most vacuum dealers can replace the carbon brushes and resurface the armature. This should cost $40 to $50. If you need a new armature you are looking at $100 or more.
Jul 01, 2011 | Kirby G4 Bagged Upright Vacuum
Need a belt for Kompressor vacuum. Micro-V=5EPH271
I NEED A LG LV200R BELT Kompressor vacuum. Micro-V=5EPH271
Jan 25, 2011 | Vacuums
When dry vacuuming, my shop vac is shooting dust out the back. What do I need to do?
Sounds like you need to re-install the air filter so there is a tight seal between it and the vacuum. You may have removed it to do the wet vacuuming and then did not re-install it properly to do the dry vacuuming.
Sep 05, 2010 | Shop Vac 85L500 Wet/Dry Vacuum
Need to replace vacuum belt
how do i change belt on morphy richards ultralight cyclone cleaner?
Jan 04, 2009 | Vacuums
Need vacuum cleaner bags for euro pro ep055
Needed bags for this vacuum and FINALLY found them at http://www.totalvac.com/parts/X10-3005.html?zmam=6843742&zmas=1&zmac=6&zmap=X10-3005. Ten bags and two filters for $10.95 plus shipping. Hope this does it for you and anyone needing bags for this vacuum.
Dec 12, 2008 | Euro-Pro EP055 Bagged Canister Vacuum
Replace vacuum hose
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=797809
Generic problem for all Vacuums
Replace vacuum hose
Posted by bombertony on Jul 17, 2008
Replace vacuum hose
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You should contact the place where you purchased your vacuum, or if it is a big box store, you would need to supply us with the brand name, model # and the serial # for the vacuum and then you can contact your local vacuum cleaner dealer in your area or to contact the vacuum cleaner factory phone #, you can use the Google search site to locate the factory or manufacturer or re-send a message thru FixYa with the info and we will try to get you the information you needs to purchase a new hose.
Jul 17, 2008 | Vacuums
Vacuums Logo
23 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
