Question about JVC Everio GZ-MG155 Camcorder
Independent audio input device
I have connected a helmet camera to the camcorder using the patch cord they supplied, for use on a motorcycle. The helmet camera doesn't have a microphone, (there would be too much wind noise anyway) and I need a separate audio device to plug into the patch cord.
The audio input specs are 300mV rms, 50k ohms. Any ideas?
Cheers
  • Jim Halligan Mar 21, 2008
    cheers for that. The specs I quoted are for the AV audio input on the camcorder. I need something compatible to plug into it. Somebody suggested a preamp, but nothing seems available and I don't know anything about them.
    The bike's a Suzuki DL1000 - I'm the old bit.
    cheers
  • 1,512 Answers
Hey old byke. The microphone that you supplied the spec for is a condenser mic. By using a dynamic mic(often 600 ohms) will help with wind noise and give you better results. I would tuck it up away anywhere that there is some shielding from the wind. A foam wind filter over it would help also.
What you ride mate... in the middle of a rebuild on my XS650 at the moment.gotta love the old bikes.
regards
Graeme
Posted on Mar 21, 2008
  • Graeme Ross
    Graeme Ross Mar 22, 2008
    you wont need a preamp, just plug it in and go for it. I DO understand what the specs are, a dynamic mic 600 ohms will STILL DO THE JOB. A 5k impedance mic plugged into a 600 ohm input impedance wont however. I am an electronics and sound engineer, my avatar is a picture of my studio control room. I suggested a dynamic mic as under the circumstances you are attempting to record in, and a condensor will pick up far too much noise. A dynamic has much different characteristics and will do the job much better.
    I didnt reply to your question only because I am into bikes, I DO know what I am talking about. But me thinks your "thanks for trying" rating means that you do not take my advice seriously. Oh well. I tried.
I am trying to playback videos on my JVC Everio Camcorder using the colored AV cords. I hear the audio coming through my TV but there is no video/picture. I have tried adjusting the settings and tried...
First, set [SWITCH TO ANALOG I/O] to [OUTPUT]
then turn off the (camcorder) unit.
After you connect the cable (from AV connector to the TV's AV Input Connector (accepting the 3 color cables), set the TV to VIDEO mode, selecting the AV input (from your Camcorder).
Then start your playback on the camcorder ...
slide the mode switch to select the (video) mode (instead of the picture/photo mode)... press the PLAY/REC to select the playback mode, and select the desired files/frames to play.
Hope this works for you. Have you tried using the HDMI mini connector instead ? (same process, just set your TV to accept input from the HDMI input)
Jun 03, 2014 | Video Cameras
I have a Sony Handycam Vision CCD-TRV65 and I want to convert the video to DVD to a VHS, how do I do that?
using the RCA outputs and an RCA patch cord, Input the signal into a VCR line input. Play the video back on the camcorder and using a good, high quality VHS tape insert in VCR and press record
Jan 17, 2011 | Sony Handycam CCD-TRV87 Camcorder
Hdmi connection for camcorder to hdtv does not work.
If i am to understand you correctly, you are are connecting a mini-HDMI adapter to the TV, and another adapter to the camera, then connecting the two adapters together.. i believe this may be an issue..
Too many adapters can actually cause signal issues, especially when converting a digital signal to analog, then back to digital, or vice versa.
Check to see if the manufacturer of your camera has an adapter to go directly from the camera output source to your TV's input.
Cam > adapter > TV = Correct
Cam > adapter > adapter2 > TV = Signal degridation
May 28, 2009 | Acer Aspire m5640 PC Desktop
How to copy
use s video cord or red white yellow cord to connect. camera comes with a grey adapter patch cord that will help do that easily.
May 02, 2009 | Sony Handycam DCR-TRV30 Mini DV Digital...
Hi8 to Computer for editing
Color: Black Part No.USBG-VX3 VISTA COMPATIBLE USB Video Adapter USB 2.0 Audio/Video Grabber S-video& Composite
AUDIO AND VIDEO GRABBER FOR WINDOWS VISTA GrabBee X+ USB 2.0 Audio/Video Grabber New Generation USB2.0 Audio/Video grabber is the best ideal companion for your portable audio/video application. Real-time MPEG 1/2/4 recording make you have powerful video application on hand. GrabBeeX+ USB 2.0 A/V Grabber is the bridge between your computer and analog camera, VCR, camcorder or other video source. GrabBeeX+ USB 2.0 Video Grabber is small enough to fit in the palm of your hand and is ideal for both notebook and desktop computers. Applications : Video recording & editing Take photo Video email Security monitoring system Features : Small Wonder--Dimensions are (L)81mm x (W)30mm x (H)15mm Audio and video go though USB 2.0 bus (WinXP) to make best performance High speed USB 2.0 data transfer rate for best video recording Encoding MPEG 1 or MPEG 2 format directly use InstantMPEG Technology, Ideal formats for creating VCD or DVD movies Up to 25 fps motion capture capability at 720x576(PAL) & 30 fps at 720x480(NTSC) SnapShot function support Composite, S-Video analog input, NTSC, PAL and SECAM multi system support Recording period setup Composite, S-Video analog input, NTSC, PAL and SECAM multi system support Support Brightness, Contrast, Hue, Saturation, Sharpness control Powerful video editing function include Motion Video Special Effects/ Title Effects/ Picture-in- Picture Effects/ Slow & ast Motion Video Effects/ background music/?color background/ Transitional Effects Plug & Play Low power consumption. Ideal for portable computer too No Battery---No need to install batteries or run off the wall adapter
  • Specifications : Video input : One RCA composite, One S-Video.
  • Video system : NTSC, PAL and SECAM multi system support Audio input : in WinXP, go through USB; in Win2000, go through sound card
  • Motion capture : AVI format from 160x120 to 720x576 resolution MPG format from 320x240 to 720x576 resolution Still image capture : BMP/JPG/TIF/PCX/TGA file format
  • Performance : Up to 25 fps at 720x576 for PAL, 30fps at 720x480 for NTSC Power Source : 5VDC,300mA(max) through USB port Minimum System
  • Requirements : USB 2.0 equipped computer Pentium 4 1G or above 128MB of RAM Windows 2000/XP Sound card
  • Package Contents :
  • GrabBeeX+ USB 2.0 Audio/Video Grabber
  • GrabBeeX+ drivers CD
  • Ulead VideoStudio editing software
  • User's manual
    I have heard this works, going to try one today, I have tried EVERYTHING else, downloading drivers, diffferent programs, firewire cords, so I think this will work, when I googled our specific camcorder, this matches, also, some people are selling the exact sony camcorder on ebay with this included, stating they have used it to connect to their pc. Hope this helps.
  • May 06, 2008 | Sony Handycam CCD-TRV608 Camcorder
    My camcorder
    You can transfer video from the camera to your pc by using an i.Link connection if your camera has it or you can use the supplied usb wire to connect it to your pc and transfer the video that way. If you do not have the cord it is easily obtainable at any camera repair or sales store.
    Feb 07, 2008 | Video Cameras
    Sony Handycam Digital 8 DCR-TRV140/Pinnacle Instant DVD Recorder/Windows Vista Home Premium/Sony Vaio
    I have a sony hi 8 video camera recorder. Someone dropped it and now we cant get the tape out to put in another camera. Can I use a USB to get the information off the camera?
    Jan 19, 2008 | Sony Handycam DCR-TRV140 Digital Camcorder
    Connecting analong camcorder to computer
    The only Analog camcorder that has a USB Connection for transferring pictures or video is the SC-L770. The SC-L770 can transfer video (live or recorded) and still photos through the USB connection. You can also transfer audio using the audio cable provided. After installing the driver and software, you can begin transferring data using the software provided. Connecting to a PC 1. Connect a USB cable to the USB port on the PC. 2. Connect the other end of the USB cable into the proper terminal on the camcorder. (USB jack) 3. Connect the audio cable to the Line input jack of the PC. If the PC has no Line input jack, connect the audio cable to the MIC input jack. In this case, however, a noise may be produced depending on the PC. Notes: * If you disconnect the USB cable from the PC or the camcorder while transferring, the data transmission will stop and the data may be damaged. * If you connect the USB cable to a PC via a USB HUB or simultaneously connect the USB cable along with other USB devices, the camcorder may not work properly. * In this case, remove the other USB devices from the PC and reconnect the camcorder. Some other Analog Camcorders have a snapshot mode which allows you to take a still photo with your camcorder. However, you cannot transfer these to a computer unless you purchase additional hardware such as a capture card. Some capture cards have analog a/v inputs which will allow you to use the a/v outputs on the camcorder to connect to your pc and transfer images and video. You can purchase a capture card at most computer and electronics stores. Samsung does not support capture cards.
    Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
    Watching tapes on TV
    To connect your camcorder to a TV (or VCR), you'll need audio/video cables. These need to be run from the VIDEO and AUDIO jacks on the camcorder to the VIDEO and AUDIO inputs on the TV (or VCR). Once cabling is completed, follow either of these scenarios: When connecting the camcorder directly to the TV, turn on the TV and tune it to the video input channel by pressing the INPUT button on your remote control. # When connecting the camcorder to a VCR that is already connected to a TV: Turn on the VCR and place it in the Line or Camera mode. # Operate the TV as you normally do to see the signal coming from the VCR. Select camcorders have an S-VIDEO jack, which offers higher video quality. Provided your TV or VCR has an S-VIDEO input jack, connect the camcorder to the TV or VCR using an S-VIDEO cable. Since the S-VIDEO cable only transfers video, you will also need to use an audio cable. Select the S-VIDEO input on your TV or VCR to view the signal coming from the camcorder.
    Sep 06, 2005 | RCA CC-432 Camcorder
    JVC Everio GZ-MG155 Camcorder Logo
    79 people viewed this question
    Top JVC Video Cameras Experts
    Larry Stiles
    Larry Stiles
    Are you a JVC Video Camera Expert? Answer questions, earn points and help others
