Question about Panasonic DMR-E50 DVD Recorder
DMR-E50 DVD RECORDER
My Recorder switches on to Record intermittently for a few minutes at a time and uses up disk space. Otherwise it works perfectly with timed recording. Please help.
  • 1 more comment
  • Hambel Mar 24, 2008
    Yes it switches to record on its own either while we are watching a programme on the tv (and makes a muzzy picture and we have to cancel Ext.Link or Timer-on to try and get back to tv programme we are watching) or when the tv is off. It records for a few minutes and sometimes 30 mins and leaves about 6 pictures on navigator all saying AV2.
    Thank you for your prompt solutions. I will try these out and may call the Engineer if necessary. The warranty runs out next month so I will be in time. Will let you know result. Best wishes and thanks again.
  • Palmbeach
    Palmbeach May 11, 2010
    Can you give a little more information?
    Does it switch to record on its own or only when you press the rec button?
    How long does it record?
  • 185 Answers
Hi
That's very strange, I have not seen a Panasonic do that before.
There are two things I would try.
1) Remove the batteries from the remote controller. This will rule out the possibility of the buttons making contact due to moisture or a fault in the controller. Then see if the problem occurs.
2) Unplug the power cable from the DVD recorder and leave it disconnected for at least 30 minutes before reconnecting it. This will reset your machine in case something has been corrupted.
3) When you have reconnected it, check the programme settings to make sure they are all clear.
4) Your machine could be picking up some radio interference if there is a transmitter close by. This is an unlikely cause, but if you suspect it, try plugging your machine into a different power socket and re-route the connection cables.
This particular model, like numerous Panasonics, suffers with an overheating regulator on the power board. They almost all fail from about two years onwards. The regulator gets very hot during normal operation and is not adequately protected from thermal runnaway. Regulator faults can cause a number of problems such as continuous self checking, switching off, and not reading certain discs. I have not known the regulator to cause unprovoked recording, but there can always be a first time. If the regulator is causing problems, the unit is easy for an engineer to repair. I can provide information on how to repair faulty Panasonic regulators if you need it.
Best wishes
Posted on Mar 24, 2008
Machine stuck on remote dvd 2 setting
Try holding 1 and enter at the same time for more than 3secs
Nov 16, 2009 | Panasonic DMR-E50 DVD Recorder
Recently, i;ve been trying to record tv programs on my Panasonic DVD Video Recorder DMR-E50, as i have done so for many years. However, lately, whenever i program it to record a tv program using the timer...
Hi Leah,
Good description and good job in narrowing down the problem. The lens is the remaining common denominator.
You need to get a CD/DVD lens cleaner. It should have a disk and a bottle of cleaning solution. They are available in the electronics dept of most chain stores.
A couple drops of cleaning solution on the feathery cleaning element attached to the disk, insert the disk into the machine and hit play. Takes just a couple seconds.
Best regards
Mike
Aug 17, 2009 | Panasonic DMR-E50 DVD Recorder
Will my non finalzied discs play on a panasonic ez 28 or ex 768
You will have no problem playing your non finalized discs on any of the Panasonic DMR range including the DMR EZ28 series. The DMR E55 can also easily be repaired if you can use a soldering iron and a little care. Please checkout my other postings for full repair details.
Cheers...
Oct 08, 2008 | Panasonic DMR-E55 DVD Recorder
Panasonic
There is a manual for a E50S and a E50K. Could one of these be yours? One might be close enough to help. Go here
http://www2.panasonic.com/consumer-electronics/support/
Aug 08, 2008 | Panasonic DMR-E50 DVD Recorder
No read
The DVD-RAM Disk had trouble afeter Multiple recordings or any scratches. Buy a new DVD-RAM Disk and Try using that.
Feb 19, 2008 | Panasonic DMR-E50 DVD Recorder
DMR-E50 DVD recorder versus DMR-ES15 are these equivalent recorders
The DMR-ES15 is a later model (around 2006/07) than the DMR-E50 (2003/04), but essentially both should do the same job so technically - a good equivalent in terms of recording and same brand so yes. The connections on the rear (of the replacement recorder) should suit and work with your other devices just as the old one did.
According to some other online reviews, the DMR-E50 has had a few issues with recording, and finalizing certain discs.
I'd say go for it - accept the replacement - as long as it comes with some kind of guarantee, works fully and has all the accessories (including remote, instructions etc.) you should be good. Contact the store and seal the deal.
I hope you can get this in time for Christmas.
Dec 21, 2017 | Panasonic DMR-E50 DVD Recorder
Pixilation when playback of dubbed and homemade DVDs
As mentioned on the Jan12 e-mailed Panasonic - surprise, no response! However on Panasonic's web site drill down to firmware upgrades for DVD machines. There is an upgrade available for the E50P. Straight forward fix, download to computer, expand it and copy to a CD-R. Put CD-R into E50 and recorder will check and update firmware. I did this on the 13th and have recorded two commercial free movies and both have played back perfectly after finalization. Time will tell. Hope this helps. Golferdon
Dec 29, 2007 | Panasonic DMR-E50 DVD Recorder
Blank disks won't record
FIRST HAVE THE LASER LENS CLEANED
THEN USE MEMOREX DVD-R THIS SHOULD SOLVE YOUR PROBLEM
Oct 20, 2007 | Panasonic DMR-E50 DVD Recorder
DVD DMR-E50 Doesn't Work
As it's been 5 months I suspect problem's been solved - how? I have similar problem, E50 recorded DVD-r's lock up after playing about an hour. RAMs and commercial DVDs play fine.
Aug 12, 2007 | Panasonic DMR-E50 DVD Recorder
Panasonic DMR-E50 won't recognise blank DVD's only
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Dec 03, 2006 | Panasonic DMR-E50 DVD Recorder
Panasonic DMR-E50 DVD Recorder Logo
192 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
