Question about Brother DCP 130C All-In-One InkJet Printer
DCP-130c error 44 Please Help
Had a paperjam and when paper was removed tried to print again and yhis error message came up Init unable error 44 Please help have just bought new ink for printer as have urgent print job Cheers Andrew
  • buffy71 Mar 21, 2008
    Thanks for the fix.
    Both didnt work for me.
    For the second fix the PH won't even move at all so couldn't do this one.
    And the cart are brother cart so it's not generic ink. Could it be a bad batch of ink from Brother.
    Cheers
    Andrew
    Thanks again
  • Anonymous Mar 21, 2014
    how to fix unable to init 44
  • 832 Answers
Error 44 dcp 130/mfc 240/440 etc.:
abnormally high temperature within print head.
You have two choices to TRY to fix it:
1. put in new carts. press menu then start copy b/w then  fourtimes arrow up button (AUB) quickly one after another.
press by help of AUB and OK:
7 - (Ok) 6  - (ok) 4 (ok) then start b/w copy to initiate the carts and let the machine do some power cleaning.
leave the maintenance mode by pressing AUB 9 (ok)  and 9 again.
2. Make sure that the ph is at correct position simply by pressing on it from top (power up machine. wait til ph runs to left side. unplug from power. simpl press onto the ph). replug to power.
If you still receive the error the ph is defective due to bad generic ink and needs replacing.
Posted on Mar 21, 2008
How to clear "unable to init.73" in brother dcp-j125 printer?
Hi
This is a mechanical problem of some description. Open the scanner cover and remove any foreign objects and paper scraps from inside the machine. Then, disconnect the machine from the power for several minutes and reconnect it. This should clear the error, but if it does not repeat the procedure making absolutely certain there is nothing in the printer obstructing the paper path.
You can get a manual for this machine here:
http://data.manualslib.com/pdf2/36/3557/355673-brother/dcpj125.pdf?5f68814c3d046699f5763ce9725a25e1
and there is a manual resetting procedure that you might try here:
Reset Methods for All Brother Printer Models
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 29, 2014 | Brother Dcp-J125 Compact A4 Colour Inkjet...
Unable init 4f
the dcp-130c 3 in one printer not working. message appears on the printer screen is init unable 4f. pliz help me
Jun 22, 2013 | Brother DCPJ125 All-In-One Inkjet Printer
Init unable 51
The message means that there is something stuck inside the printer. Open it and look for staples, paper clips, torn pieces of paper, etc.
Hope this helps. Please rate this response.
Randy
Oct 10, 2012 | Brother DCP 130C All-In-One InkJet Printer
Error 50 brother dcp 130 d
on my DCP 130C display appear an errore message "imp. stamp 50". This is an error message in italian language that indicate impossible to print, error 50.
Please, have you some suggestion to resolve this problem?
Thansk in advance
Sep 19, 2009 | Brother DCP 130C All-In-One InkJet Printer
Init unable 4f
uninstall your printer software under control panel/add remove programs..then reinstall your software again make sure your printer is plug to your pc also...hope this helps..ITTech7574
Aug 31, 2009 | Brother DCP 130C All-In-One InkJet Printer
Brother Print Unable 50 Error
No ;-)
The encoder strip switched off the ph and has to be set into place again.
see here how to fix it:
http://www.fixya.com/support/t211210-brother_mfc845cw
(enlarge the browser window to see pics somewhat better)
An advice:
when you have set the encoder strip in pos. again stick some scotch tape on the top of the ph cover where the strip runs thru to prevend the slipping off again on next paper jam ;-)
Mar 29, 2008 | Brother DCP 130C All-In-One InkJet Printer
Not printing
Sure. Its a new common problem of brother printers. The paperjam lifted the encoder strip (a foil strip) out of position. The encoder strip gives positioninfo to the printhead. You have to disassemble the printer and simply fix the encoder strip in its position upon the printhead. To avoid this prob in future stick a 3cm tape with a 1cm plastic strip in the middle onto the position where the encoder strip runs thru the printhead. The plastic foil avoids a sticking contact of the encoder strip.
Oct 01, 2007 | Brother DCP 130C All-In-One InkJet Printer
Brother DCP 130C All-In-One InkJet Printer Logo
856 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
