Question about Canon CLC 1120 Color Copier
Error code is 0180
First i got the error code 0181, then i cleand bk sensor. when i restart the machine error code is 0180
  • 4 Answers
Mr rupabai your problem is in the magenta starter try to intialiaze it again by pressing " 28 at the same time
copier
function
install
int m press it and wait a few minutes if an error occured after intializing change the magenta starter and intialized again
Posted on Mar 28, 2008
SOURCE:
Error 027-0400 canon 5240i
https://printcopy.info/?l=en&mod=erc&brand=Canon&model=iR%20Advance%20C5560i&code=027-0400-05
Canon iR Advance C5560i Error Codes
Quoting from link:
Code
027-0400-05
Description
Error in supply with K Developing Assembly
Causes
The Toner Supply Screw Rotation Sensor detected rotation error within the specified period of time.
Remedy
[Related parts] R1.01 - Harness between the Feed/Drum Driver PCB (UN2/J225) and the Developing Motor (Bk) (M8/ J6011) - Harness between the Feed/Drum Driver PCB (UN2/J212) and the Toner Sensor Relay PCB (Bk) (UN42/J1430) - Developing Motor (Bk) (M8) - Developing Assembly (Bk) - Main Drive Assembly - Set-on Hopper Assembly - Feed/Drum Driver PCB (UN2) [Remedy] Perform the following in the order while checking whether the error is cleared. 1. Check that the Developing Coupling of the Developing Assembly is not damaged. 2. Check that the Developing Coupling of the Main Drive Assembly is not damaged. 3. Check/replace the related harness/cable, connector and parts.
Apr 29, 2018 | Canon Office Equipment & Supplies
My Lg front load washer will not drain. clothes are soaked. showing IE error code
the problem with air guider,,which is connect with presser sensor,might its block with durty. kindly check &cleand,,,
Apr 20, 2014 | LG WM1814CW Front Load Washer
F 12 whirlpool 6 th sense washing machine.
hello,
simple ,The "F 12" error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
what you need to do to fix up your washer is to check on the wiring connection from the power supply to the water temperature indicator.
thank you and thanks for using fixya.
Jun 01, 2010 | Whirlpool AWM8143 Front Load Washer
Unable to print mcf-215
plz press menu then start-bk-copy then fourtimes arrow up quickly after another. machine turns to maintanence mode. press start bk copy: what two digit error code does the machine display?
If it starts with a 4 you do need a new printhead!
Mar 28, 2008 | Brother Multi-Function CenterĀ® MFC-215C...
Screen says unable to init and cannot find guide.
press menu then start bk copy then 4 times arrow up. Lights will flash and machine turns to maintenance mode. In case you cant see an 2 digit error code press start bk copy again.
If the error code starts with 4 the printhead is defective and needs replacement.
If you have another code displayed search code here at fixya. Most of them are explained a thousand of times...
To leave the maintenance mode press 9 then 9.
Feb 15, 2008 | Brother MFC-640CW All-In-One InkJet...
UNABLE TO PRINT
press menu then start bk copy then fourtimes arrow-up button (tel.index) quick after another.
machine will be in maintenance mode and lights will flash.
press start bk copy in case machine wont directly display the error code.
Error starting with 4 means defective print head.
Error starting with 5 menas defective purge station or cycle problems.
both error series means: you need a new printer...
Feb 13, 2008 | Brother MFC-5840CN All-In-One InkJet...
Error message on my Brother MFC-420CN
press menu then start bk copy then fourtimes arrow-up button. Machine will switch to maintaenance mode. You may have to press start bk-copy. The machine will display an error code.
Error code starting with 4 is always a defective print head which needs replacing (except error 46: new waist ink tank needed).
In case it is another error code plz post here again.
Jan 28, 2008 | Brother MFC 420CN All-In-One InkJet...
COF37 error code
C0F37: Abnormally high toner density detected by Black ATDC Sensor
Toner density that is 4 % or more higher than the target level is detected ten consecutive times during a print1.gif cycle, ATVC, or image stabilization sequence.
The sensor for this error is in the black imaging unit not the toner hopper. See the steps below. If that doesn't work then visit my website1.gif for contact and I will sell you a full service and or parts manual on CD.
Step
Check Item
Result
Action
Imaging Unit Bk is installed correctly.
NO
Check and correct ATDC
drawer CN of imaging unit Bk.
Each of Imaging Unit Bk contacts makes
NO
Clean or correct.
good contact.
ATDC Sensor harness is open-circuited.
YES
Change Imaging Unit Bk.
Jan 20, 2008 | Minolta CF2001 Copier
Minolta cf 2001
Toner density that is 4 % or more higher than the target level is detected ten consecutive times during a print cycle, ATVC, or image stabilization sequence.
The sensor for this error is in the black imaging unit not the toner hopper. See the steps below. If that doesn't work then visit my website for contact and I will sell you a full service and or parts manual on CD.
Step
Check Item
Result
Action
NO
NO
Clean or correct.
good contact.
YES
Dec 18, 2007 | Minolta CF2001 Copier
Canon CLC 1120 Color Copier Logo
220 people viewed this question
Clive
Clive
old marine
old marine
Ekse
