Question about Sony STR-DG510 Receiver
No video output using either HDMI or component video
Have just purchased a STR-DG510 and after setting it up have found that I cannot get a video signal out of the receiver using either HDMI or component video cables.
The old RCA (yellow, red, white) is working fine.
please help.
  • 4,234 Answers
Make sure that these inputs are enabled. I'd have to confirm within the manual, but I believe that these have the HDMI section disabled by default.
Dan
Posted on Mar 21, 2008
No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
Jan 20, 2008 | Sony STR-DG510 Receiver
Do the HDMI ports support audio or do I need to go buy optical cables to use them on my STR-DG510
The STR-DG510 carries video only over the HDMI port. Technically, this is a "pass-thru" port. Most older receivers are engineered to operate this way. Why? I don't know. You MUST provide the audio connection using a separate TOSLINK or RCA cable from the program source to the receiver while your video is connected via the HDMI port.
Stick to IT work, MSOFT IT pro. I got smart and bailed out being an IT guru. I got better things to do than screw around with the idiotic nonsense of Microsoft operating systems and applications being a thing of fashion rather than being useful and practical.
Aug 01, 2009 | Sony STR-DG510 Receiver
Sony STR-DG510 From component to HDMI
You have to use the same connection in and out. You can not mix inputs and outputs (Example- HDMI IN will not play on Component out and Vice Versa.)
Nov 18, 2008 | Sony STR-DG510 Receiver
NO Picure
Hi 1prosource
I concur:) Glad you got it sorted out. Any other dramas you may have, just give me a hoy :)
regards
robotek
Jun 02, 2008 | Sony STR-DG510 Receiver
Sony HDMI receiver STR-DG510
On Page 54/55 of user man. has a step by step instructions.
May 10, 2008 | Sony STR-DG510 Receiver
HDMI Connection
is the hdmi connected to the tv
Apr 09, 2008 | Sony STR-DG510 Receiver
Sony STR-DG510
I think you have to run a separate audio line from the dvd to the 510, because the HDMI is only passive
Mar 12, 2008 | Sony STR-DG510 Receiver
No picture?
I called sony, even though the manuel shows that you can use a component wire to hook up the set top box and hdmi for the tv and dvd sony claims that you can not do this. The cable box must also be wired with an hdmi cable going into the video 2 port.sony claims it doesn't work using component and hdmi together because the receiver is unable to up convert. I hope this helps. I have not tried it yet (i'm at work) we'll see what happens when i get home.
Dec 25, 2007 | Sony STR-DG510 Receiver
High volume low sound
check the volume output from your components, and make sure they are not set too low
Dec 08, 2007 | Sony STR-DG510 Receiver
Sony STR-DG510 Receiver Logo
124 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
