Your mp3 player has two types of memory in it. The hard drive (where the music and photos are stored) and the Ram (where the firmware and active files are temporarily hosted).
When you soft reset your GoGear, it flushes the RAM, and restarts the operating system (which is why the contents of the hard drive does not get erased).
You can "hard reset" the device, by formatting the drive and resetting it to factory defaults in the Settings field. This is the closest thing to a "hard reset: that's available with an HD based MP3 player.
Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.
Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.
Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persists and you see no paper that is stuck in the printer it
Step 1 Turn off the printer. Step 2 Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it. Step 3 Remove all paper trays and any paper that may be stuck between the tray and the printer. Step 4 Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. Step 5 Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again.If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue.
Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and i suggest contacting theprinter manufacturerfor additional assistance and/or repair.
"Unable to Init" indicates a mechanical error, unless you're able to find a stuck paper or parts of a stuck paper or similar, you'll have to send the unit to service to have it fixed.
# Turn off the printer. # Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.* # Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.* # Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.* # Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue
I was able to pry the stuck tab open with a small flat head screwdriver. After a number or repetitions of that process, plus some repeated pushing on the tabs, they started working normally.
