Question about ASUS A7N8X Motherboard
Do connections to the motherboard have anything to do with connectirng to the internet?
I recently opened my PC to blow it out with canned air. Ever since then, I have not been able to connect to the internet. My wireless network is showing connected but it will not let me acess the web. Is it possible that I disconnected a connection to the motherboard?
    Genius:
  • 1,913 Answers
Hi
i think u have not hardware problem.
go to your iexplorer tools internet option.
reset your iexplorer settings.
off your firewall .
if u have dialup connection clear your ip address auto alll give exact ipaddresss of dns server.
Posted on Mar 21, 2008
I can run laptop in safe mode with networking only at moment - on normal screen it freezes once connected to Internet - cant get any further than desktop screen - cant open anything and can't then...
When did the problem start?
What internet browser are you trying to open?
What if any changes were recently made?
have you tried system restore?
Jan 07, 2013 | Computers & Internet
After formatting my PC with Window 7, I cannot hear anything!\r\nChecked the pc with windows update,it said it have lost the audio driver. But I can't find my driver cd!! What should I do in order to fix...
if you can get the model and brand name of your audio you can go and search driverguide.com. is you sound built in with the motherboard? just get the motherboard model and brand search the internet for the website that supports your motherboard. your can download at their site driver updates.
Apr 10, 2011 | Computers & Internet
Within 20 seconds of turning my computer on the computer shuts off. It recognizes the hard drive, memory and other accessories. Is my motherboard defective ?
This could be any one of a number of things, really. Disconnect everything connected to the PC that is not needed and boot. If you're able to boot OK, that tells you that there is a problem with one or more of your devices. This could be anything from a defective peripheral device - to having good peripherals, but simply too many connected to the PC. If you can get every device working at one point or another - but fail as more and more are added - if indicates a power supply unit (PSU) that is over burdened - and cannot supply the load. This is remedied by replacing the PSU with one that has a higher wattage rating than the one it is to replace AND has enough wattage to supply the connected load - plus 20%. Why plus 20%? That's because we don't want to run the PSU at maximum capacity all the time. 80% of capacity is a good starting point - and allows for a small amount of expansion. The more extra capacity you allow - the longer it will be able to work for you before becoming "too small".
The internet is loaded with guides as to how to go about sizing a PSU. Look through them and manufacturer's sites for help with that.. look for recent articles as there are many that are 2, 3, or more years old. Prices back then were high compared to now - so if you find info you like on an old page - don't be put off by the prices quoted.
Heat is another big problem. Especially if the PC is on the floor instead of your desk. There's tons of dust and dirt on the floor and your PC has several fans sucking it all up. Vents get clogged, fan blades get coated - basically - the entire innards of the PC is wearing a thick, furry jacket - keeping it warm. This is NOT a good thing. Disconnect everything, and open the PC up. With a crevice tool on a vac - vacuum all the dust and dirt you can. Pay particular attention to the CPU fan and cooler assembly. Remove the fan from the cooler to vacuum the jacket off of it. Clean dirt and dust that collects on all the fan blades - this reduces efficiency and throws the fan out of balance and will shorten the life of the fan considerably. Vacuum the power supply too - you'll be surprised how much dirt will be trapped inside it. Resist the temptation to blow out the case with a can of compressed air. Doing so will only drive dust & dirt deeper into the machine. Once cleaned up, consider moving the PC to your desktop (if it isn't already), reconnect and try again.
Pleas rate this reply - thanks & good luck!
Dec 17, 2010 | Abit SG-80 Motherboard
4 OR 5 DAYS BEFORE WHEN I START COMPUTER IT CAN STOP AND RESTART AUTOMATICALLY AND GIVE BLUE SCREEN ERROR AND ALSO NOT CONNECT WITH INTERNET LANDLINE CONNECTION OR USB CONNECTION
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Sep 20, 2010 | Acer Aspire 5542 Notebook
Hi I have an advent roma 1000 and it is constantly overheating and shutting off. Is there anyhing I can do? David
HI David, anything you do is going to require taking apart the laptop. Befere you do that though, any vent that air comes thru, take a can of air and blow so into the vents so that way if there is dirt in the way it will be removed.
If that doesn't work then you'll need to take apart the laptop and then take the can of air and blow some into the CPU fan and make sure there is no dirt in the cpu fan assembly. Remove it if you see it.
If after all that the laptop is still overheating, then that means the motherboard isn't controlling the voltage and the motherboard is bad and would need to be replaced.
Dec 22, 2009 | Toshiba Satellite A25-S207 Notebook
Whenever i start my pc fan's start's even monitor start's imediately but 'no signle' massage appears on screen & monitor screen got off
Do you get any "Beep" sound coming from the internal speaker, if so is it just one straight beep or numerous beeps.
If it's one straight beep then this indicates the PC has passed it's POST (Power On Self Test), if it's a series of beeps, some long, some short, it means there is some problem inside the computer, like loose graphics card, RAM, CPU, cable, etc. The beep sequence should be in your motherboard manual under beep codes. That will give you a hint as to what to look for next.
If it is one straight beep and PC passes POST then check your monitor connections, and monitor, it could be that the power saving/signal detection pin is either not connected properly, or damaged.
If you don't have the internal speaker connected (normally in the bottom or front of the case), you need to connect this to find out what is going on.
If you need to connect it you should look at your motherboard manual for where to connect it, normally if you look at the motherboard you will see a load of thin cables coming from the front of the case going onto the motherboard at a point, the 4 pins on the bank of pins at the end are normally the PC speaker (you also get a blank pin between them and the Power Switch pin), although check your manual first, or see if you can see the SPK connection on the motherboard (normally Gigabyte boards are very well marked for this, and colour coded.)
Oct 31, 2009 | Computers & Internet
My Carrier Home AC unit stopped blowing cold air today. I opened it up and cleaned everything and didn't notice anything out of place, any ideas?
This could be complicated to resolve over the internet but I'll give it a try. When you stated that it stoped blowing cold air, did it stop blowing air all together? Also is the outside unit rtunning?
Sep 05, 2009 | Carrier 38CKC042 Air Conditioner
INTERNET CONNECTIVITY
that could be right but thats something hard to guess... in this cases better to disconnect and check every part separately and find if any part smells like burned... if all is ok just connect it back and try... if you feel strange smells better go to a tech or report here but with specific info...
gluck
Mar 21, 2008 | ASUS A7N8X Motherboard
PC SUDDENLY SROPS
I think your system may be heated check out your processors temperature, if it is very hot change your cpu fan.
Feb 22, 2008 | EliteGroup P4VMM2 Motherboard
Beeping sound emitted from motherboard
hi,
this is due to a faulty connection of your motherboard. did you recently changed anything in your motherboard like wire connection, RAM etc.
check out soon or else it might harm the computer....
regards.
bzoy
Jan 08, 2008 | Computers & Internet
Open Questions:
Having issues on Acer Product ' call +1888784-9316 Care Number 24/7 Helpline Acer is a Taiwan-based electronics multinational that is best known for its computer products, although it also produces other consumer electronics such as personal digital assistants and mobile phones, as well as computer-related products such as servers and storage devices. Acer has ruled the consumer electronics market because it has the most innovative approach. Acer laptops are famous for their energy efficient performance with long lasting battery life, high portability due to the laptop's light weight construction, along with the added features like high speed Bluetooth and wireless connectivity and also wide screen display that provides exemplary image quality with higher resolution. Because of all these and many more qualities acer support have made it to the top of the list of customer's choice for best laptops. But its users might face some issues from time to time that could prove to hinder their important work and so, to prevent this, we have a team of technically superior and experienced technicians who can be contacted anytime on our toll free call acer tech support number. Issues faced by Acer customers:- • Black laptop screen issues • Stretched images on laptop screen issues • Laptop heating up followed by forced shut down • Window update issues • Crashing issues in acer computer support • Windows 10 upgrade problems • Computer Tune up issues • BIOS update • Virus removal issues Call on our Acer support phone number acer customer service and get all these issues and many more related to Acer laptops, addressed by our technically advanced and experienced support team members. Our Services: If you have any query or issue related to Acer laptops that you want to get resolved in the most efficient way possible by some of the greatest minds in this job with highest levels of experience then contact us on our toll free Acer support phone number. Contact our technical support team for any assistance regarding issues concerning Acer Laptops by Calling on our acer technical support phone number. Get all your troubles sorted out in a matter of few minutes by most courteous and experienced technicians.
Jun 18, 2018 | Acer Computers & Internet
See all ASUS A7N8X Motherboard Questions
ASUS A7N8X Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
