Question about Sony PFM-42V1 42 in. HD-Ready Plasma Television
Black Vertical line about an inch wide right of middle - PFM-42V1 Sony
This black line is a permanent addition now to my screen. Sometimes a second line will also appear about 2 inches to the right of the current line... it comes and goes though.
Anyone with any idea how or why this line exists, or even why the second line will pop up from time to time....
  • 6 more comments
  • Anonymous May 05, 2008
    Please describe the specifics of your problem below. We'll add
    your post as a comment to wallyrj's Black Vertical line about an inch wide right of middle - PFM-42V1 Sony
  • wallyrj May 31, 2008
    I still have not heard anything... now have 2 black lines, some times 3, they can appear then dissappear!! very annoying.. will let you know if I hear anything, and appreciate you saying you will do the same... cheers
  • Anonymous Jun 02, 2008
    After did some techinical research. The problem is with X-board. But, I can't find that replacement any where.
    Thanks.
  • Anonymous Jun 28, 2008
    I have a 2 inch vertical black line to the far right. Not sure at this time what to do except call a Sony service person... Any other ideas anyone?
  • cbiferi Jun 28, 2008
    THE SAME PROBLEM: 2 BLACK VERTICAL LINES AND SOME TIMES 3 LINES. ABOUT 2 INCHES WIDE.
    MY SONY IS PFM-42V.
    SOMEBODY KNOW HOW TO SOLVE THE PROBLEM?
    THANKS.
    MY EMAIL: [email protected]
  • wallyrj Jul 26, 2008
    Seems others are having same problem, butno fix available??
  • Anonymous Aug 11, 2008
    Same problem. Any suggestions from anyone.
  • cafeakava Dec 15, 2008
    I have the same problem when I first bought it in 2004. Sony replaced the whole panel since it is under warranty. It happened again after 4 years. I called Sony this morning, they told me that this model is discontinued. There will be no parts, they told me to toss it out.
  • 20 Answers
The problem is the actual PDP panel address chips blown or a faulty ribbon cable to the PDP or if your lucky it may be a dry joint - Tap the ribbon while the set is on very lightly on all cables with something plastic and see if the black line goes away - if so your lucky and its an easy but fiddly repair.
Posted on Aug 25, 2008
I have the same problem, please email if you have a solution at [email protected]
Posted on Aug 04, 2008
I have exactly same problem. If you find solution. please email me at [email protected]. I greatly approciated. I'll do the same if I found solution.
Thanks,
Posted on Apr 08, 2008
SOURCE:
My sony pfm-42v1 no pictue
turn it off for around 30 min..try it again, then let us know what you find...could be a control board issue
Apr 27, 2008 | Sony PFM-42V1 42 in. HD-Ready Plasma...
Vertical black lines on screen
Unfortunately it sounds like the video processor or a capacitor inside the TV has started malfunctioning, causing the vertical lines. I recommend contacting where you purchased the TV from and ask for help regarding a repair or replacement if it's still in warranty.
Hope I helped,
MichaelPrest
May 07, 2011 | Sony PFM-42V1 42 in. HD-Ready Plasma...
Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Nov 28, 2009 | Sony BRAVIA KDL-46V3000 Television
Sony PFM 42V1 Vertical black line
you have a bad lcd panel call sony they may help
Jul 02, 2009 | Sony PFM-42V1 42 in. HD-Ready Plasma...
Pulsing/strobing on black screens or dark backgrounds
It is very likely that there are electrolytic capacitors going high in ESR on the processor and driver boards, and also in the power supply areas. The tech should be able to see this by monitoring supply distributions with a scope.
Depending on the complexity of changing the caps on the boards (if it is actualy a cap problem), the best choice may be board replacements.
In almost all the cases where I had this type of fault, it was a number of capacitors that had to be replaced.
Jerry G.
Apr 13, 2008 | Sony PFM-42V1 42 in. HD-Ready Plasma...
Sony Plasma PFM 50 ci black screen
. Check blink of leds
check the 5 v control voltage.
check Ysus and Zsus board.
check Voltage sc, Vs and Voltage a .
Yareth De Matos - Venezuelan -
Mar 28, 2008 | Sony PFM-50C1 50 in. Plasma HDTV
Sony PFM-42V1 42 in
sounds like X buffer/scan or control/logic problems. without good service info you will have a hard time troubleshooting. And it will get expensive guessing. Could even be a panel, probably gonna need a pro look.
May 11, 2007 | Sony PFM-42V1 42 in. HD-Ready Plasma...
Vertical Black line on display
Rakesh, You have a "dual scan" panel, this is why the line only decends down the screen half-way. This could be a connection problem on the buffer board which causes loss of the drive signal only to that part of the display which it is connected to. The vertical address buffer will be located on the top rear of the display, use great caution in inspecting these cables and connectors. If the integrity of the cable and connector is good the panel itself may be bad due to the drive IC being located on the ribbon cable attached to the panel body. this is better known as COF or, chip-on-film technology. I hope this helps you. Good luck. Joe Weibel CustomElectronics.Org
Jan 28, 2007 | Sony PFM-50C1 50 in. Plasma HDTV
Sony PFM-42V1 42 in. HD-Ready Plasma Television Logo
1,054 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
