Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
DC07 cylone not cycloning
Hi
Just got a refurbished DC07 today from woot (soooo excited!!)
Put it together and started to run it...picks up beautifully...but after a few minutes running, I notices inside the canister no cyclonic action going on....still picking up lots of dirt, but the yello spinner-blade-like thing is not spinning, and my dirt is not spinning, just sitting there in a pile getting bigger and bigger......I doublre triple checked all connections to make sure everything was snapped in correctly and it was.....is this supposed to spin all the time when using or do I have a problem??thanks, michele
  • 372 Answers
Hi Michele.
The yellow tube with the fins on does not spin. So that is fine.
If you have pets or lots of fluff vacuumed up it may not roll around in the waste bin when using this is normal & nothing to worry about.
Just empty bin & start cleaning you will see the grit particles spinning but as you collect fluff or hair that may roll around at first but as more is sucked up it will stay still.
http://dysonmanuals.llc.nu/
Posted on Mar 21, 2008
SOURCE:
On the Dyson DC07, can the cyclone canister be COMPLETELY disassembled?
Hi Jeff, it's Jack at Dyson.
DC07's cyclone pack isn't designed to be dismantled. To ensure optimum performance, some parts are bonded together to create an airtight seal. It wouldn't be possible to disassemble this section of the cyclone pack without damaging the machine. We also advise against removing the cyclone top as it can be difficult to do this without causing damage to the internal bin release rod.
If you need some help with your DC07 you're welcome to contact us directly for advice. You can reach the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 24, 2015 | Dyson DC07 Animal Bagless Upright Cyclonic...
My problem is with the bin canister I have two dysons one loses suction but the problem is with the bin assembly as when i swap them over the problem is solved. I have replaced the base bin seal...
Sorry to hear you're having difficulties with your DC07. If you feel the cyclone assembly needs to be repaired or replaced, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Jul 07, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Ive got a dc07 dyson just changed the belt on it as i had to since then it isnt picking anything up at all nothings clogged up had it to bits and put it all back together again properly. The hose is...
Sounds like the hose underneath has become detached. Have a look and if its not that come back to me. Also can yo9u check your U Bend is still on as these can come off.
Feb 26, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
My dyson will not pick up. cansiter has been emptied filter clean
unscrew plates underneath to expose cavities.
These fill with hair and debris.
Clean them out and put back together, good as new
Jan 07, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a dyson dc07 hoover, is it possible to replace the carry handle
Hi thanks for contacting FixYa. My name is Don.
Whilst it is "possible" to fix the carry handle it is a far trickier job than just buying a whole new Cyclone. For this reason Dyson do not sell the handle separately.
I would suggest you buy the whole new cyclone. You can buy them new for around £30 £40 from Dyson or Espares.co.uk.
You could probably get a second hand one or better still a refurbished one on eBay though. Shouldnt cost you too much on Ebay. Maybe £15
Hope this answers your query.
Thanks for contacting FixYa. Don
Oct 24, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 bagless - upright mode v poor suction, wand mode ok
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the bleed valve is activating which only happens when there is a blockage.
We would recommend following the full blockage through as outlined in your user guide or in the Support section on our website at www.dyson.com.
Kind regards
Darran
Dyson Customer Service
Jan 11, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
My dyson DC07 has no suction. motor runs, brush spins, just no suction.
hi..the reason to this problem may be the bottom pieces
might not have been fully seated.Take it apart and put it
carefully back together.This will solve the issue.
check it out..
thank u..
kindly rate my response..
Jun 10, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Canister will not release
I've done that.
There is a stem that runs down the center of the cyclone that releases the bottom. You didn't get that stem back in place. The only thing you can do is pry it open, hope is doesn't break, and put that cyclone back together correctly.
I've never broke one, but I had to pull pretty hard. Thought I was going to.
Good Luck
Nov 24, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
219 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
