Question about Yamaha RX-V995 Receiver
Vcr recording what procedure do i have to do to record from one vcr to another using the receiver.
See page 10 of the manual re connections
The vcr (or DVD hard drive) you want to tape to has to be plugged in to the sockets shown for "video cassette recorder"
I connect the vcr that I want to tape from as per the "TV/DBS"
I select TV/DBS and hit play on the from vcr.
Then I hit record on the to VCR (or in my case a DVD hard drive)
Posted on Apr 17, 2009
How to record to vcr player/recorde from dish 625 dvr
Hi, Mari!
You can definitely use a VCR with your DISH 625 receiver. To set this up you would need to connect your VCR between your receiver and the TV.
The easiest way would be to run RCA cables from the TV Out to the VCR's TV input. From there, all you would have to do is run cables from the VCR's Out to the TV. Make sure the VCR and receiver are powered on and change to the input on the TV based on where the cables are plugged in on the TV.
If you have any questions let me know!
Tommy Faust
DISH Internet Response Team
Jan 18, 2012 | DISH Network DVR-625 DTV Receiver /...
I have a dvd/vcr rrecorder with no coaxial connection. How can I tape or record a TV program?
Hi,first of all I assume that your Magnavox DVD/VCR Dual Player has the recording features as well..othervise you cant do anything"NEGATIVE" ..If yes than follow the procedure below..
If you want to record your TV program while watching to your DVD/VCR system you need to connect "Video - Audio Output " RCA jacks or "Optic cable output" of your TV or CABLE box to "Audio-Video input or "Optic Cable input" of the DVD
There you go..Your TV's video and sound is on the
DVD/VCR Dual Player Receiver..of course your DVD source input should correspond with the jacks you used on the back...push "RECORD" button it should start for recording the coming signal into DVD
when you recording the output RCA jacks of DVD will generate the signal of whatever records that can be monitored with another TV set after properly connected..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 15, 2011 | Philips Magnavox DVD/VCR Dual Player
I have a vcr samsung dvd-v2000. How could i record from dish reciver dual mode model id= vip222k-hd Thank you in advance
Hi this is Luke. Here's how: 1. Put receiver on single mode. 2. Use RCA cable on tv2 out chan 21 - 69 out as output from back of vip222k. 3. Plug the other end of RCA to Video input of vcr. 4. Turn on receiver, press record. 5. And whatever you watch on TV1 will be recorded on VCR. Let me know if this help.
Jan 25, 2011 | DISH Network DISH-2800 DTV Receiver
Recording 3 digit channels
With the VCR connected to DirecTV, you're not picking the channel with the VCR anymore. You're picking the channel on the DirecTV receiver, and the VCR will record on channel 3 or 4 (if you've hooked the receiver up using the RF output to the VCR) or through its line (A/V) inputs if you're using those. The tuning range of the VCR is completely unimportant.
With your new system, though, there's one big drawback. Since the VCR is always set for channel 3 or 4, or its line input, and you're changing channels on the DirecTV receiver, you can't program the VCR to record several different channels if you go out. You won't be home to change channels on the receiver, so the only channel you'll be able to record is whichever one you've selected before you go out. Remember the VCR is taping the output of the satellite receiver, and not the satellite channel directly. If you record on some channel other than the receiver's output channel, there won't be anything there. All you'll get is snow or a blank screen.
Mar 31, 2009 | RCA VR706HF VHS VCR
DTV Converter hookup
Is it possible to record TV programming on a VCR when using a DTV converter? h1 = document.getElementById("title").getElementsByTagName("h1")[0];h1.innerHTML = widont(h1.innerHTML); Hi,
I had the same problem and found this answer that worked for me. Hope this does the trick for you.
Simple stated, your VCR must be set to channel 3 also. Check it out.
woody
  1. You must have the VCR tuned to record on channel 3.
  2. You must have the VCR connected to output signal of the DTV converter box. In other words, the converter box must be connected between the antenna and the VCR. So, the likely configuration you would use with a coaxial cable is antenna to DTV converter to VCR to TV.
  3. You must tune the DTV converter to the channel you want to record prior to recording. The VCR won't be able to change channels on the DTV converter.
  4. You will be able to use the timed record function on the VCR but you must adhere to steps 1-3.
If this sounds freakishly familiar to recording on a digital cable or satellite set-top box, you are right. It is exactly like recording a signal from a digital cable box or satellite receiver. While it may be inconvenient to perform the steps above, at least the option still exists to record on a VCR while using a DTV converter box.
Disadvantage of DTV Converter: You will lose the ability to watch one program and record another with the DTV converter. Sorry for the bad news.
The reason is the tuner. The VCR tuner is useless with digital except for recognizing channel 3. The digital converter is a single tuner item so it only receives one station at a time.
Oct 17, 2008 | Emerson EWV603 VHS VCR
How to Record TV Programs w/o Cable Box/Satellite Receiver?
if there are rca ports on the front of the vcr which are output, connect those to the tv input 3, the input to input connection is definitely not going to work...
May 09, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Manual
If you are looking for a replacement manual, please see below.
Panasonic DMR-EZ47V Replacement Instruction Manual
Apr 02, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
CNNECTING DMREZ27EB FREEVIEWDVD RECORDER, TO MY TV 2 SCARTS, AND MY PANASONIC VCR VIDEO RECORDER
I CONNECTED SCART TO TV 1 TO DVD FREEVIEW SCART 1, THEN I VCR SCART IN/OUT TODVD FREEVIEW RECORDER SCART 2, THEN RF CABLE FROM FREEVIEW RECORDER OUT TO VCR RF IN ,VCR RF CABLE OUT TO TV RF IN. RF SLOT IN ON FREEVIEW LEFT EMPTY THEN CHANGED TV TO AV 2 WHEN USING TO RECORD /PLAY EITHER VCR OR/ FREEVIEW DVD . I DO HOPE THIS HELPS SOMEONE. IT TOOK ME A WHILE TO SORT OUT REGARDS R. ELLIOTT.
Feb 22, 2008 | Televison & Video
Recording
Coax out from box into cable in on VCR. Coax out from VCR to Cable in on TV. Set TV and VCR to ch 3. Put in blank tape. Start show on DVR and hit record on VCR. Hope that works for you.
Feb 07, 2008 | Arris DCT6200 DTV Receiver
Yamaha RX-V995 Receiver Logo
77 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
