Singer Model 9410
Would like to know how I can get a new plastic case that the bobbin sits in for my sewing machine?
There's a site called www.plasticase.com
also www.ULine.com that makes those plastic cases.
Also www.SingerMachinesPlus.com
maybe these will help have your model # handy.
marcy5
Posted on Mar 21, 2008
Metal Bobbin Case falls down in machine when I try to sew
the bobbin case needs to be checked to see if it needs to be replaced
and also checked the hook and hook race.
Feb 16, 2013 | Sewing Machines
I inherited a singer model 9410. I have never used this model and am not quite sure how to insert the bobbin. My last sewing machine was a front load for the bobbin.
Go to the singer website
Go to the home page
At the bottom of the page look for instruction manual--click on it
It will take you to another page
In the box put the model number (example 9410 ) & click search
They have a free download,,the second one is free
Sep 05, 2011 | Yamata FY700 Mechanical Sewing Machine
The bobbin case will not stay in my singer 9410 machine. The case has broken before. I have a new one and I cannot get it to work.
Hi. The position finger on the right hand side needs to be adjusted closer to the case. It may very well be bent. If it is bent, it needs to be repaced.
Sep 04, 2010 | Singer 5050 Mechanical Sewing Machine
Bobbin case came out of my singer 9323 and I dont
The bobbin case should sit flat on the raceway and make sure the metal clip is pushed over to hold it in
Mar 24, 2010 | Brother LS-2125 Mechanical Sewing Machine
Singer 9410 Bobbin
Update:  Today I took my machine in to get serviced - they replaced the metal bobbin I was using with a plastic one, that was a little less rattley inside the bobbin case, replaced the needle with a new, universal one, and changed out the thread with something a little higher quality.  They also adjusted the spring holding the bobbin case slightly, and now it seems to work fine.  I'm not sure how long it will last, but for now I'm good.
Oct 02, 2008 | Sewing Machines
Singer sewing machine model 9410 - Seems like each time I change bobbin I have trouble sewing. 1. Plastic case bobbin sits in comes loose - finally think I have metal bar over that securely. 2. It's...
I have the same problem and the part that the bobbin sits in is called a STITCH LENGTH CONTROL CRANK Part number 312801 That's all I could find out. Unfortunately for me - that little lip on that part broke off. I didn't realize it had come loose and when I changed out the bobbin - crunch! Do you know where to get parts online???
Feb 14, 2008 | Washing Machines
Singer 9410 Bobbin
I had the same problem and after looking on here and finding no answer I went back to my machine and found out what the problem was...ok, where the bobbin case sets in,the metal plate beside it needs to be fitted right close to the bobbin case, so loosen the screws(just two of them) that are in the plate(DO NOT REMOVE JUST LOOSEN) and slide the metal plate over some just enough to fit snug...NOT TOO TIGHT... if its seems to sew too tight loosen it a bit It worked for me, GOOD LUCK
Nov 11, 2007 | Yamata FY700 Mechanical Sewing Machine
Washing Machines Logo
89 people viewed this question
Top Washing Machines Experts
