Question about Samsung SyncMaster 174V 17" Flat Panel LCD Monitor
Auto Adjust box keeps appearing
Just today the syncmaster 174v monitor I had has had the same message appear repeatedly. The auto adjust box keeps appearing and runs through 100 percent, the screen shakes a bit then all is well. Then minutes later it repeats the entire process
  • 151 Answers
Check the section of command.check frontpanel switchs and components related with it. if it dont work then change memory ic.
Posted on Mar 21, 2008
  • jitendra singh
    jitendra singh Mar 21, 2008
    Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
    Good luck and kind regards.
    Thank you for using FIXYA.
How do I unlock the OSD lockout on a Samsung B2430H monitor. I've unplugged the power and computer connection cable. Tried holding the menu and auto keys nothing seems to work. There is just the...
OSD LOCKED/UNLOCKED
This function allows you to lock the current control settings, so that they cannot be inadvertently changed. Press and hold the MENU button for several seconds. The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear.
Sep 09, 2013 | Samsung SyncMaster 753S 17" CRT Monitor
Lock on monitor adjustments don't know how to turn off the lock so we can adjust brightness and color
Follow these instructions :
  1. Turn on your Samsung monitor (if it isn't already.)
  2. Press the "AUTO" button on your Samsung monitor. This will run the automatic configuration utility. This will look at your current computer settings and adjust your monitor to best match those. This will take a few seconds. If this has calibrated the monitor to meet your needs, you are finished with the process. If it hasn't, continue to Step 3.
  3. Press the "Menu" button on your Samsung computer monitor.
  4. Use the arrows and the "Enter" button on the monitor to highlight and select various settings categories.
  5. Use the "Brightness" menu on your Samsung monitor to adjust how bright or dark you want the image.
  6. Use the "Colors" menu to adjust how prominent certain colors are displayed on your Samsung monitor.
  7. Use the "Contrast" menu to adjust the level of black on your Samsung monitor.
  8. Select "Save and Exit" to save your changes and exit the Samsung monitor's on Screen menu.
Dec 24, 2010 | Samsung SyncMaster 174V 17" Flat Panel LCD...
Auto adjustment locked? Screen is dim on SyncMaster 174V Monitor
press all keys simultaneusly and keep pressed untill the locked massage dissappear and unlocked massage will appear
Feb 26, 2010 | Samsung SyncMaster 174V 17" Flat Panel LCD...
"auto adjust blocked" message recors
there is auto button on the screen as well try from there
Feb 11, 2010 | Samsung SyncMaster 171S 17" Flat Panel LCD...
How do I change the setting on my Syncmaster monitor if I can't see anything but the message box..."Not Optimum Mode recommended mode 1280x1024 60 hz?
You could try pressing the auto adjust button (simply says 'Auto'), and see if that changes anything...don't know if this will work, but it is a start.
Sep 29, 2009 | Samsung SyncMaster 913N 19" LCD Monitor
AUTO ADJUSTMENT LOCKED BOX FLASHES ON THE SCREEN ALL THE TIME.
Depends of what seems to be a problem.
If you want to get rid of that message box, appearing by itself, then probably you need to take front panel PCB with buttons and replace "Auto" one, 'cause it's stuck.
If you want to unlock an Auto Adjustment and other functions in your monitor, then press and hold 'Enter' button for 5 seconds.
Sep 14, 2009 | Samsung SyncMaster 17" LCD Monitor
Auto adjust doesnt work
try to push the menu button for 5sec, maybe it will be solve the problem..
Jul 11, 2009 | Samsung SyncMaster 913N 19" LCD Monitor
Samsung syncmaster 720 n
Is the auto adjust button stuck?
May 09, 2008 | Samsung SyncMaster 720N Monitor
Samsung SyncMaster 174V 17" Flat Panel LCD Monitor Logo
523 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
