Question about Sony VAIO GRZ660 Notebook
Testing..1..2..3.. testing the system to see if it notifies
  • 4,889 Answers
Nope it didnt notify me.. i found this on the unanswered page.. it wont notify you as well...
Posted on Mar 21, 2008
04 pont gp 3.8 won`t crank but if u hold in start will crank & start batt. conections are cleaned
No guessing here ,testing the starter system , controls ,wiring etc... is the way to diagnose this . The starter is control by the PCM - engine computer through a relay . The ignition switch is an input to the BCM .
Here is how the factory service manual tell's how it works
Circuit Description
When the ignition switch is placed in the Start position a discrete 12 volts signal is supplied to the BCM notifying it that the ignition is in the Start position. The BCM then supplies a class 2 message to the PCM notifying it that CRANK has been requested. At the same time the BCM is supplying 12 volts for the IGN 1 relay closing it and supplying battery positive voltage for the Crank relay coil. The PCM verifies that the transmission is in Park or Neutral. If it is, the PCM grounds the control circuit of the Crank relay. When this occurs battery positive voltage is supplied through the switch side of the Crank relay to the S terminal of the starter solenoid.
Rather then guessing , your best bet would be to take it to a qualified repair shop that has the diagnostic equipment an knowledge to test it .
Dec 04, 2017 | Cars & Trucks
My 2006 Chevrolet Uplander 3.5 has no crank, no start, no lights on dash board only engine lights, no radio what do I need to do?
Do you know how to do automotive electrical testing , with a volt meter . Check out videos on youtube basic automotive electrical testing . Do you have a scan tool ? That would be a good first step . Do you have any idea how many elctronic control modules are on your vehicle ? Do you know what a serial data communication network is . C.A.N How to Diagnose Controller Area Network CAN When you turn the key to start do you know what happens ?
Circuit Description (Key Start)
For ignition switch power modes refer to Body Control System Description and Operation . When the ignition switch is placed in the Start position a discrete signal is supplied to the body control module (BCM) notifying it that the ignition is in the Start position. The BCM then sends a message to the powertrain control module (PCM)/engine control module (ECM) notifying it that CRANK has been requested. At the same time the BCM is supplying 12 volts for the IGN 1 relay closing it and supplying battery positive voltage for the crank relay coil. The PCM/ECM verifies that the transmission is in Park or Neutral. If it is, the PCM/ECM grounds the control circuit of the crank relay. When this occurs battery positive voltage is supplied through the switch side of the crank relay to the S terminal of the starter solenoid.
What you need to do is have it towed to the dealer !
Mar 07, 2017 | Chevrolet Cars & Trucks
Laptop beeps 7 times
Try link: How to identify beep codes: When a laptop or computer first powers on, it goes through an initial set of diagnostic tests to make sure vital components are preforming correctly. These tests are called POST or Power On Self Test. When a test fails, the user is notified via POST codes, Light codes, or Beep codes. For diagnosing Beep codes you need to:
  • Power on the laptop or restart it if it is already on.
  • Listen to the number of consecutive beeps when the computer begins to boot. Restarting the laptop may be necessary and should not harm the laptop at this time.
Dell Inspiron M501R (M5010) Beep Codes # of Beeps Description Possible Cause(s) 1 BIOS ROM checksum in progress or failure System board failure, covers BIOS corruption or ROM errors. 2 No Memory (RAM) detected Memory or Memory slot failure 3
  • chipset Error (North and South bridge error, DMA/IMR/Timer error)
  • Time-Of-Day Clock test failure
  • Gate A20 failure
  • Super I/O chip failure
  • Keyboard controller test failure
System board failure 4 Memory read / write failure Memory failure 5 Real Time Clock (RTC) power fail CMOS battery failure 6 Video BIOS test failure Video subsystem failure 7 CPU Cache test failure Processor failure or motherboard failure 8 LCD LCD failure Most Common Fixes:
  • 1 Beep: Replace the motherboard / system board.
  • 2 Beeps: Reseat the memory or replace the memory.
  • 3 Beeps: Replace the motherboard / system board.
  • 4 Beeps: Reseat the memory or replace the memory.
  • 5 Beeps: Replace the CMOS battery.
  • 6 Beeps: Reseat or replace the video card or replace the motherboard / system board.
  • 7 Beeps: Reseat or replace the CPU or replace the motherboard.
  • 8 Beeps: Reseat the LCD cable or replace the LCD screen.
Jul 21, 2014 | Dell Inspiron M501r Laptop Computer (AMD...
Once a week at 4:00am my GE Simon XT does an auto phone test. At 4:12am it notifies me that the phone test has failed by beeping continuously until I press disarm. How do I get the system to stop running...
You will need the installer code to change the setting. Factory default is 1234. press the up or down arrow until "system programming" appears on display. press "OK" and "enter code" appears. Enter installer code. If it accepts it, "access codes" appear on the display. Use the down arrow until "timers" shows on display. Press"OK". Press the down arrow until "auto phone test tm" appears on display. Press" OK". use up and down arrows to adjust to "off". Press"OK". press "Status" and "timers" is shown. Press up arrows until "phone numbers" is showing on display. Press "OK" press "OK" again press "disarm" press "OK" press "Status" 4 times. You have now completed removing the phone number and turning off the phone test.
Nov 21, 2012 | GE Security Simon 3 Wireless Home Security...
97 Camry with ABS light continuously, but brakes act fine.
There is a fault in the abs system and the light is on to notify you that the system is not working. normal brakes will work fine. this will need professional repair as there are specific tests that can only be performed with a professional scan tool, not just a code reader.
Mar 14, 2011 | 1997 Toyota Camry
On my 1999 suburban 1500 came out on the panel, the ( service engine sun } light, I test it and on the test came out manfacurer control p1345, ignition system or mis fire. the engine crank perfect it...
if you have 1 of the newer type code testers, there is a selection on them consisting of yes or no, this is to notify you if you want to remove the trouble code from the system , or not, if you select the yes button to remove the code , it will take the service engine light out, if you do not have 1 of the code testers, then, you can disconnect the positive battety cable for a couple of minutes, then reconnect it, if the light still stays on , go to you closest local auto parts store, let them hook up their code tester, and remove the code for you, hope that this information has been helpful.
Feb 14, 2011 | GMC C1500 Cars & Trucks
A problem caused theprogram to stop working correctly. Windows wi
Your problem is a little hard to say. Have there been any power outtages or has you computer been powered-off rather than the regular shut-down procedure. Windows registry and programs can be thus corrupted.
Also computer viruses can disrupt programs so please run for example
Mcafee's free online anti-virus to rule-out a virus problem.
Even if you have an anti-virus installed, it needs to be running the latest virus definitions.
You could also try in programs accesories system tools to select "system restore" and bring back your computer to a date where you understand the problem was not happening. (Try this one last)
Jul 11, 2009 | Computers & Internet
I want to have a message from gmail appearing on screen telling me I have an e-amil message waiting for me. This should occur even when working on another application. Thanks in anticipation of...
Go to your gmail, then go to settings and disable this feature selecting on general TAB >> "Don't always use http"
About the Gmail Notifier The Gmail Notifier is a downloadable application that alerts you whenever you have new Gmail messages. (Mac users, please read What is Google Notifier? for Mac-specific information.) After you download the Notifier, an icon will appear in your system tray (so you don't have to open a browser) to let you know if you have unread Gmail messages. Once you install the Notifier, you'll be able to:
  • Automatically check for new messages every two minutes.
  • See a snippet of text from up to 30 unread messages.
  • Select a sound to indicate when you have new mail.
  • Make Gmail your default email application.
To use the Gmail Notifier, you need Windows 2000, Windows XP, or a more recent version of Windows. (Download the Notifier*) The Notifier is not compatible with Windows ME at this time, but we look forward to offering support for more operating systems in the future. The Notifier is currently available in English only.
If you have an idea for improving the Notifier, please click the 'Contact Us' link in the Gmail Help Center and send us your idea using the suggestions form. But before you do, please check out some of the things we're already working on.
*Note: If you've enabled the 'Always use https' setting in Gmail, you'll need to install a patch for the Notifier to work with this setting:
  1. Download the patch (.zip).
  2. Open the folder.
  3. Double-click the notifier_https.reg file.
  4. Click yes when you're asked to confirm if you want to add the information to the registry.
  5. Restart the Notifier.
If you decide you no longer want to use the https setting, you'll need to install the other file included in the download to reset the Notifier. Use the same method as above, except with 'notifier_https_undo.reg.'
Oct 07, 2008 | Computers & Internet
My pc dont start
The problem identified that your system wont start. By solving, let begin from the very the very start. 1. be sure that power supply function well. u can test PS by changing temporary identified functional PS. if u sure that PS is good then, examine processor. remove memory. switch on system w/out memory if hear beeping. u are sure that processor is working.if not then something wrong with your processor. if beefing then insert memory. if not solve, examine memory clean it very well. and insert. if same problem replace memory. notify me if more problem identified. we will continue.....
Dec 14, 2007 | Systemax Venture PC Desktop
Sony VAIO GRZ660 Notebook Logo
35 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
