Lexmark Optra S 1855
I need to find the printer drivers for th above. I realize that this beast is getting rather long in the tooth but it still works like a joy so why cast. Just bought a new laptop and thus need to install new drivers but can't seem to locate.
Can you help or just point me in the right directions?
Appreciated,
Hendrik
    Genius:
  • 3,587 Answers
You may find them here(where long toothedness is popular)..
Posted on Mar 21, 2008
SOURCE:
Optra S 1855: Error "202 paper jam open rear door" appears constantly as soon as I turn on the printer, and I can't do anything. However, there is no paper in the printer!
Get the user manual/support/information for your Optra S1855 here:
http://support.lexmark.com/index?page=manualsguides&linkSelected=node2%5Esubnode1&channel=manualsguideschannels&locale=EN&userlocale=EN_US
Also, sometimes if you blow out a printer with a spray can of air or small air compressor it could remove a little piece of paper/debris that is stuck to the jam sensor. Good luck.
Jan 11, 2018 | Lexmark Optra S 1855 Laser Printer
Good morning, I bought a acer aspire 7540G laptop with Windows 7, 64 bit. I connected the Lexmark Optra S 1855 printer with the USB but my computer cannot find the driver. Where can I find the correct...
You may click on the following links below to download the available printer driver for this printer model.
http://bit.ly/oLHVX3 - 64-bit PCL XL Emulation Print Driver Universal Print Driver
http://bit.ly/p0RF71 - 64-bit PCL 5 Emulation Print Driver Universal Print Driver
http://bit.ly/oOi99g - 64-bit PostScript Level 3 Emulation Printer Driver Universal Print Driver
For further assistance, please contact Lexmark Technical Support
Jul 26, 2011 | Lexmark Optra S 1855 Laser Printer
I am getting a 922 service fuser error on my lexmark optra s 1855
922 Fuser Error message indicates that the fuser unit failed to reach the standby temperature. This usually requires a service call but try to turn off the printer for 30 seconds before turning it back on to give the engine board a chance to reset. Make sure the printer is plugged in straight to the power outlet in the wall. Bypass any surge device or power strip as they can cause low amperage. If the problem continues or if the error appears every time the printer is powered on, you will probably need service on the machine.
Aug 26, 2010 | Lexmark Optra S 1855 Laser Printer
900 service rip software error on our Lexmark Optra S1855 what does it mean? How do I fix it?
These errors indicate an unrecoverable engine software
error. Replace the engine board is the only solution
Apr 07, 2010 | Lexmark Optra S 1855 Laser Printer
I HAVE A LEXMARK OPTRA S 1855 DISPLAY NOT READABLE HOW DO I PRINT A TEST PAGE UNHOOKED FROM THE COMPUTER?
Hello, Leo.
Here are the steps:
  1. Turn the printer power off (O).
  2. Press and hold Select and Return together.
  3. Turn on the printer.
  4. Release the buttons once Performing Self Test appears on the operator panel display.
  5. The printer performs its normal POR cycle, then prints one copy of the Print Quality Test pages.
Hope this helps.
Oct 15, 2009 | Lexmark Optra S 1855 Laser Printer
Lexmark optra s1855 makes knocking noise when printing envelopes from the mp tray
this noise is usuallt cause by a flat spot on the backup roller of the fuser remove the fuser turn it by hand if you feel a flt spot when turning replace the fuser
Sep 23, 2009 | Lexmark Optra S 1855 Laser Printer
Swap parts between Optra S 1255 and 1855
I can say for sure that these parts do not translate. The service manual says.
Jun 09, 2009 | Lexmark Optra S 1855 Laser Printer
My Lexmark Optra S 1855 is showing a fuser error. What needs to be done?
the fuser needs to be replaced its about 200 dollars just search for Fuser for the model of your printer
Thank You John C
Mar 03, 2009 | Lexmark Optra S 1855 Laser Printer
Can't print from bottom drawer, will only print from tray,
There are at least three possible solutions. The first two are simple the third is fairly complicated unlr=ess you can read a hex dump of a print file. 1) Use the front panel "Paper Menu" to select the tray. 2) Check the driver settings to make sure the driver is set to "Auto" or the correct tray. 3) Set the driver to "Print to File". When prompted to name the print file, name it "tray_fail". If you do not know how to read this file, send it to me at [email protected] and I'll be happy to take a look at it and see I I can correct the problem. Don
Jan 16, 2009 | Lexmark Optra S 1855 Laser Printer
Open Questions:
Kodak Wireless Printer Tech Support pHoNe%%[+l{85526O^0O64]:~%%NumbER Vujsery Kodak Wireless Printer TeCh SuPpOrT Number +[185526O0O64]VuLogin Kodak Wireless Printer customer service phone Number Repair service center to resolve all Kodak Wireless Printer products. Kodak Wireless Printer is an American multinational company which was founded by Michael Kodak Wireless Printer using its company headquarters in Round Rock, United States of America. Contact Kodak Wireless Printer for Setup & Installation Kodak Wireless Printer Setup Free & Installation Kodak Wireless Printer TECH FREE number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Kodak Wireless Printer Connect, Kodak Wireless Printer TECH Free Phone Number you'll be searching out Kodak Wireless Printer Connect setup as well. So, here we're with all cthe setup process and for your to Kodak Wireless Printer Connect. Get Kodak Wireless Printer Setup Instant Free Kodak Wireless Printer TECH FREE Phone Number Usually, the setup TECHnique takes a number of time. One TECHnique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may locate the approaches simplified tdako help you even if you aren't TECH-savvy. Let us undergo the method of Kodak Wireless Printer Connect setup for Windows and for Mac. So, right here we go vikki TALATUMAS
Oct 18, 2019 | Kodak Office Equipment & Supplies
LeXmark Wireless Printer Tech Support pHoNe%%[+l{85526O^0O64]:~%%NumbER Vujsery LeXmark Wireless Printer TeCh SuPpOrT Number +[185526O0O64]VuLogin LeXmark Wireless Printer customer service phone Number Repair service center to resolve all LeXmark Wireless Printer products. LeXmark Wireless Printer is an American multinational company which was founded by Michael LeXmark Wireless Printer using its company headquarters in Round Rock, United States of America. Contact LeXmark Wireless Printer for Setup & Installation LeXmark Wireless Printer Setup Free & Installation LeXmark Wireless Printer TECH FREE number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for LeXmark Wireless Printer Connect, LeXmark Wireless Printer TECH Free Phone Number you'll be searching out LeXmark Wireless Printer Connect setup as well. So, here we're with all cthe setup process and for your to LeXmark Wireless Printer Connect. Get LeXmark Wireless Printer Setup Instant Free LeXmark Wireless Printer TECH FREE Phone Number Usually, the setup TECHnique takes a number of time. One TECHnique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may locate the approaches simplified tdako help you even if you aren't TECH-savvy. Let us undergo the method of LeXmark Wireless Printer Connect setup for Windows and for Mac. So, right here we go vikki TALATUMAS
Oct 18, 2019 | Lexmark Office Equipment & Supplies
Epson Wireless Printer Tech Support pHoNe%%[+l{85526O^0O64]:~%%NumbER Vujsery Epson Wireless Printer TeCh SuPpOrT Number +[185526O0O64]VuLogin Epson Wireless Printer customer service phone Number Repair service center to resolve all Epson Wireless Printer products. Epson Wireless Printer is an American multinational company which was founded by Michael Epson Wireless Printer using its company headquarters in Round Rock, United States of America. Contact Epson Wireless Printer for Setup & Installation Epson Wireless Printer Setup Free & Installation Epson Wireless Printer TECH FREE number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Epson Wireless Printer Connect, Epson Wireless Printer TECH Free Phone Number you'll be searching out Epson Wireless Printer Connect setup as well. So, here we're with all cthe setup process and for your to Epson Wireless Printer Connect. Get Epson Wireless Printer Setup Instant Free Epson Wireless Printer TECH FREE Phone Number Usually, the setup TECHnique takes a number of time. One TECHnique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may locate the approaches simplified tdako help you even if you aren't TECH-savvy. Let us undergo the method of Epson Wireless Printer Connect setup for Windows and for Mac. So, right here we go vikki TALATUMAS
Oct 18, 2019 | Epson Office Equipment & Supplies
64 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
