Question about Sony PlayStation Portable (PSP) Console
Power shut off
I look the battery, then open the UMD but not touch anything inside.I charge the psp slim. then after that i power on.It open the screen is green then suddenly it take off.I power it on again same things happen.
  • 3 Answers
Turn it on with the plug but no battery inside, if it works then, your battery is fried or has been short-circuited.
Posted on Mar 24, 2008
My sons psp has a black screen
Without a functional screen, the PSP doesn't have much of a purpose. If the power light next to your screen is off as well, all your PSP needs is a good long battery charge. But if the power light is on and the screen is still dark, a few quick troubleshooting steps can help you get to the root of the problem. If troubleshooting doesn't work, you will need to contact Sony eService through its support site, particularly if your PSP has recently been dropped or had liquid spilled on it.
Step 1Turn off your PSP. Remove the battery pack. Replace the battery pack, making sure that it is securely inserted. Turn the PSP back on. If the screen is still black, continue to Step 2.
Step 2Press any system button. If the backlight is turned off, pressing a system button should reactivate it. If the screen has turned back on, go to the PSP settings menu. Select "Power Save Settings." Select "Backlight Auto-Off." This option automatically turns off the screen if the PSP has been idle. If you do not wish to have this feature active, select "Off." If this step did not solve the problem, continue to Step 3.
Step 3Press the screen brightness button below the screen. This button is marked with a small donut-like icon. Pressing the button will incrementally increase the brightness of the screen. Holding down the button will turn off the backlight. It is possible that this button was accidentally pressed down after placing the PSP in a pocket or a backpack. If the screen remains black after the brightness has been increased to full, continue to Step 4 if your model of PSP is any but the PSP Go.
Step 4Open the top hatch on the PSP. This will eject the UMD disc. Only touch the UMD at the edges, as fingerprints can interfere with the disc's functionality. Clean the surface of the UMD with a clean, dry cloth. Do not clean the UMD with water or any other chemicals. If the disc looks scratched or damaged, this is likely the cause of the screen issue. Additionally, moisture can condense on the UMD if the PSP has undergone a recent temperature change, such as being brought into a warm house from a cold car. If the UMD looks wet, turn off the PSP and allow the UMD to air dry. Wait several hours before trying to restart your PSP.
Dec 27, 2011 | Sony PSP (Piano Black)
Umd keeps reading
the umd drive is approaching its end of the life. you might need to buy http://www.consolezombie.com/store/slim-replacement-drive-laser-assembly-p-34.html and replace your umd drive. This is what i just did to my psp-2001.
PS: The above link is only for PSP-200x (slim version of PSP)
Nov 26, 2009 | Sony PlayStation Portable (PSP) Slim...
Psp always read from umd,making it hang
Hi! I incounter this problem as well even without UMD its still loading and even I disable auto-start UMD still same so I tried reflashing the software but still same problem so I discover the solution before you turn-on your PSP try to open your UMD cover you'll see it will load faster then close again the cover once you see the battery and clock icon... The problem that causing this is the switch inside the UMD possible its stock-up or spoiled already!
Jun 08, 2009 | Sony PlayStation Portable (PSP) Console
Psp 5.03 downgrade to 3.9 m33-3
First, try to determine your PSP's version. If it is the PSP 3000 (PSP slim with a narrow ring on the UMD Door), you can only play game demos from the PSN and can't be modded as of this date. If you have the PSP 2000 (slim with a wide ring on the UMD door) there is a chance you can't downgrade depending on your motherboard. Pandora's Battery and MMS is required to 'jaibreak' your PSP if you are on Sony official firmware.
Apr 11, 2009 | Sony PlayStation Portable (PSP) Slim...
My psp dosen't work well
have you modded the psp in anyway? are you trying to use homebrew apps? if you are trying to use a umd and you have modified anything other than stock then you need to clock your psp back to the factory level because the voltage is dropping too low from the umd reader activating and the strain the cpu is putting on the battery you could also try resetting everything to factory defaults afterall this is what the games are designed for
Mar 16, 2009 | Sony PlayStation Portable (PSP) Slim...
PSP Slim making click sounds when UMD is in
it could be a problem with the inside mechanisms of the UMD dock. Better make sure that the insides are clean and free of dirt or small particles.
Feb 08, 2009 | Sony PlayStation Portable (PSP) Slim...
Psp slim problem
I heard the psp slim is pandora-proof. you might need to exchange that for the original psp. and i have an original psp. i get that error code 80410A0B thing or w/e. your not  going to able to fix the problem. you should just sell your psp and buy a refurbished one.
Jun 02, 2008 | Sony PlayStation Portable (PSP) Console
Problems with the umd
do you have a slim or an old one?
May 08, 2008 | Sony PlayStation Portable (PSP) Console
Sony PSP wont play umd
Same with my PSP. My son accidentally broken a spring sensor for the UMD when you close the UMD cover of the PSP. That's why the drive doesn't recognize if there's a UMD. Sony Service Center here in the Philippines doesn't have a replacement part for this.
Aug 19, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
20 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
