Question about Vacuums
84 kawasaki voyager bike has sat up for 2 years. has low spark & fuel but will not start once in awhile it will pop or back fire.
Fresh gas is correct.
However this bike is fuel-injected - no carburetors.
Posted on Aug 18, 2008
  • 1,512 Answers
You need to do some restoration work to get the ol girl back up again. Drain the fuel from the carbs and tank. Fresh fuel will help it fire up. If fresh fuel dont fix it, you may need to strip down and clean the carbies out. They gum up with old fuel left in them and will produce the problems you are having
regards
Graeme
Posted on Mar 21, 2008
  • 883 Answers
Fuel problem :
first try starting fluid spray can. if runs very short time, then carburetors are gummed up...need re-jetting or remove and buy a gallon of carb solvent and soak carbs for a day then shake out vigorously then air blow dry with compressor then retry
low spark...could be dirty plugs-clean them- or worse may be bad spark unit...try removing spark unit and pull away from chassis then re-attach wires and try....if ok spark, then unit is grounding out to chassis on rear mounting surface...look at back for small cracks in black plastic on unit.
How do I stop the engine from back fireing
Sounds like the timing is off. Plugs are firing either a little to early or a little to late.
Feb 11, 2015 | Clymer Yamaha 2-225 HP Two-Stroke...
What could I damage on my boat fuel line? Primer bulb, any filter ... ?
There could be several reasons. I'd first look at stuck floats in the carbs. I believe there's 3 carbs and if all spark plugs are wet all floats are sticking.
But assuming it didn't overheat, and the spark plugs are wet with fuel (as opposed to water) - sometimes a defective coil will short out only when it gets warm (most time they short all the time). They can be tested.
A very good mechanic once told me there are only four things to concentrate on: Suck, Squish, Bang, and Blow. In other words, Fuel delivery, Compression, ignition system/spark, and proper exhaust. My experience has been that I've never had to worry about Blow (knock on wood) with an outboard. Others have however.
Additional advice: The number 1 cause of outboard problems is gas. Todays fuels are great for fuel injected cars but break down sooner than old gas mixtures. Always put a fuel stabilizer in you tank. It's cheap and only takes a few ounces to protect from hundreds of dollars worth of carb work - and avoid sticky floats.
Jul 06, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
Toyota Corolla GE-4A. Back fire in motto when accelerating but run alright at low speed.
timing advance is off you will have to take it in and have the time set or see if gears or worn down
Jun 04, 2014 | Toyota celica sensor assy, vacuum....
Vacuum runs for awhile and then shuts off
This sounds like an overheat issue. I suspect that something has restricted the air flow. Air flow is required for function and to cool the motor. if the air flow is restricted a thermal limiter opens the circuit, rather than have a fire.
Mar 04, 2013 | Proteam ProForce® 1500XP Bagged Vacuum
Will not start- seems to be fuel starvation.
Hi peterblesset...
You did not give me any info on what kind of engine that is starving for fuel.
So I will give you my solution to 2 cycle some 4 cycle chainsaw and trimmer engines with fuel problems and igintion problems.
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Then follow the procedure below:
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later
reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil mix if your using a two cycle chainsaw or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indetion in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me thumbs up
Sep 13, 2011 | Vacuums
Hi i hae a star product whipper sniper and i cant get it to go i hae spark i hae fuel but it seems as if there is no fuel getting to cylinder i think it is a problem with my carby the serial no is fcb12071...
one thing that you can try is to remove the carb from the unit and spray it down with carb cleaner -- maybe it is blocked (?),,, one more thing to try would be to see if it will fire using ether. there could also be something wrong with the fuel diaphram and it is not delivering fuel.
again -- try the ether and see if it will fire up.
if you are still having troubles - please feel free to wrote me back here and I will do my best to walk you thru the next steps to fix.
c...
Mar 13, 2011 | Vacuums
I have a McCulloch Model PM 310 , Gas Chainsaw. How would the spark plug be accessed?....Rich
Storing a chain saw for longer than 30 days requires storage maintenance. Unless the storage instructions are followed, fuel remaining in the carburetor will evaporate, leaving gum-like deposits. This could lead to difficult starting and result in costly repairs. Never store a chain saw for longer than 30 days without performing the following procedures:
Remove the fuel tank cap slowly to release any pressure in tank. Carefullydrain the fuel tank.Start the engine and let it run until the unit stops to remove fuel from carburetor. Allow the engine to cool (approximately 5 minutes).
Using a spark plug wrench, remove the spark plug.
Pour 1 teaspoon of clean 2-cycle oil into the combustion chamber. Pull starter rope slowly several times to coat internal components. Replace spark plug.
Store the unit in a dry place and away from possible sources of ignition such as a furnace, gas hot water heater, gas dryer,etc. When removing the unit from storage, be sure to perform the following procedures:Remove spark plug. Pull starter rope briskly to clear excess oil from combustion chamber.Clean and gap spark plug or install a new spark plug with proper gap.Prepare unit for operation.Fill fuel tank with proper fuel/oil mixture.
This will help. Thanks, please keep updated. please do rate the solution positively .thank you for using fixya
Dec 15, 2009 | McCulloch MC1275 Steam Vacuum
Smells like the motor is burning. observing sparks. It the motor cooked and is it just time for a replacement?
If you're observing sparks, then yes, just get a new one. With the low prices of good vaccuums its not worth starting a fire with your vaccuum. If it just smells like the motor is burning, check the belt and make sure its rotating freely and if you have an attachment, make sure the brush on the vaccuum is not being stopped while using the attachment. However, if you are seeing sparks,,,, definately time to junk it
Aug 20, 2009 | Sharp Twin Energy EC-TU2603 Bagged Upright...
I have a dirt devil that is only 2 years old, I used it and sparks began to shoot out from the front grill area. I called dirt devil's corporate office at 12noon today July 25th, and was told that with out...
The sparks may be from the carbon brushes in the motor. Bagless vacuums do not filter dirt out as well as a bag does so dirt and grit gets sucked into the motor. Filters should be cleaned frequently and replaced at least once a year. If the filter gets clogged the motor can overheat. If you got two years out of a $39 vacuum you did well. Many people are lucky to get a year.
Mar 24, 2017 | Dirt Devil Vacuums
HEPA Filter
It maybe that the filter is in need of replacement. They need to be changed once a year.
Sep 13, 2007 | Hoover U8311900 WindTunnel 2 Vacuum
Vacuums Logo
135 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
