Question about HP PhotoSmart 1115 InkJet Printer
LEAKING INK? There is INK below the cartridge carrier where it rests on the right side. I was told that it an indication that the printer is going bad. It looks like a collector to catch the ink. Everything else seems to be running and printing fine. What or why is the ink collecting under the carrier and how do I clean it out?
  • DIDD2 Mar 21, 2008
    Does anyone know about these units or where I could get a repair manual?
    Thanks, Didd
    President:
  • 2,351 Answers
You correct about the collector but you can empty it as well. With the printer unplugged. Move the carriage to the left manually. Here comes the hard part. Glued to the top of the collector is a piece of foam. You'll need to remove this, try not to rip it. Clean out the collector & wash the foam. Let them both dry. Some people use a syringe to pull out most of the ink.
Cotton swads help too. A small screw driver pushing down on a light cloth to pull out the ink. It's not easy, this i promise.
You can use a blow dryer to help dry, just don't melt the parts. Use super glue & replace the foam. Plug in the printer & print a test page out. The next time you need to replace your ink cartridge's make sure there is no build up of ink in the cartridge holder. Use soapy water & a clean cloth to clean it out. After the cartridge holder dries use some alcohol & cotton swab & clean the copper contacts from soap residue in the cartridge holder.
If everything goes well your good! Time for you to start helping at FixYa..
Good Luck & Kind Regards.
Need more help feel free to ask.
Mike
Posted on Mar 21, 2008
Ink Cartridge Carrier will not move from right side. Cannot open top of cradle to install cartridge. How do I move it?
I had one EPSON printer. When you keep holding the button with a tear drop sign, the carrier will rest at reach.
Aug 08, 2015 | Epson WorkForce WF-3520 All-in-One Inkjet...
Ink jet cartridge
  • 1 Select the ink cartridge specific to your printer. Canon inks are versatile, so your selection may be as simple as choosing between black, color or a multi-pack with black and color cartridges.
  • 2 Turn on your Canon printer. The switch is generally located on the top right hand side of the printer. Open the printer's lid.
  • 3 Wait a moment. The cartridge carrier will automatically disengage.
  • 4 Put your hand behind the existing ink cartridge and pull the cartridge towards you until it pops out. Dispose of or recycle the used cartridge.
  • 5 Carefully pull the tape off the new cartridge.
  • 6 Position the new cartridge into the cartridge carrier. Make sure it is facing the correct position.
  • 7 Press the cartridge carrier gently until it clicks into place. Some cartridges have indicators to demonstrate that they are properly positioned.
  • 8 Close the printer's lid. Print a test page to ensure everything is working properly.
  • Hope It's resolve all Your Printer Problem,
    Or Still having Problem Then follow Us For
    Canon Printer Support
  • Apr 22, 2014 | Canon MX340 AllInOne InkJet Printer
    I got always the message Print Head not installed
    follow these steps:
    1.
    Turn the open the top cover. Wait for the cartridge carrier to stop moving, then lift the first cartridge out of the printer. Tilt the cartridge forward, then carefully lift it out of the printer.
    2.
    Examine the electrical contacts on the bottom of the cartridge. Look for any tape that might be covering those contacts. New print cartridges ship with this tape to protect the cartridge and prevent leaks. If you fail to remove this tape, the printer cannot sense the cartridge and it might return a "print head not installed" error.
    3.
    Remove the rest of the cartridges from the printer. Check them for tape and other obstructions. Also check the cartridges for leaking ink, and clean them if necessary. Discard and replace any cartridges found to be leaking.
    4.
    Clean the ink cartridge carriers thoroughly, using a soft cloth or a small vacuum cleaner designed for cleaning computer components. Paper dust and ink residue can accumulate in the carrier and cause communication issues with the printer.
    5.
    Place the ink cartridges back in the printer and close the top cover. Power cycle the printer if the error message does not go away immediately.
    in case of any additional help, please revert back
    Jun 12, 2011 | Computers & Internet
    How do i change my lexmark x4650 print cartrige?
    Installing/Replacing your ink cartridges:
    1. Open the printer, and then press down on the cartridge carrier levers. printmastert_52.jpg
    2. Remove the used print cartridge or cartridges. 3. If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid. 4. If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid. 5. Close the printer.
    Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
    1. Unplug the printer from the power source.
    2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
    3. Remove the used cartridges.
    4. Load the new cartridges. Close the cover.
    5. Plug the printer back to the power source.
    May 15, 2011 | Lexmark X4650 InkJet Printer
    I have a lexmark printer model 5495,it tells me that the right cartridge is incorrect, i just put in new cartridges in . the cartridges 28-black/29-color, it still tell me the samething
    Hi, The Right Cartridge Incorrect error message generally indicates a communication error between the All-In-One and the cartridge. This can be due to a faulty cartridge or to a simple interruption in the communication between the cartridge and the All-In-One. The procedures below will help you identify the cause and resolve the issue.Lexmark uses, at least they used to, a chip in the ink catridges that verifies that the ink catridge is Lexmark and hasn't been refilled. There are ways around it, which is why third party cartridges work. Yours may not have been reset or damaged when refilled. Follow the below steps: 1) Disconnect the power from the printer.
    2) Remove the black power brick/block from the rear of the machine. (It may be a little tough to pull it out the first time you remove it.
    3) Open the top of the printer/multi-function unit.
    4) Gently pull the ribbon in order to center the printer cartridge carrier.
    5) Open either the left or right side and remove the cartridge. (Depends on which side the error is occurring on, black on the left, color on the right)
    6) Verify that all of the plastic strip that covered the new contacts on the cartridge have in fact been removed.
    7) Wipe both the cartridge and printer contacts with a dry, lint free cloth.
    8) Wipe the bottom of the cartridge with a damp, lint free cloth in order to verify that the ink is flowing and looks correct.
    9) Make sure there is no water remaining on the cartridge.
    10) Re-insert the cartridge into the carrier and make sure that it is bottomed and inserted all the way to the rear of the carrier slot.
    11) Re-insert the power brick/block.
    12) Re-connect the printer power cable.
    13) Power on the printer and the error should be resolved.
    14) Run the print alignment and print or copy several pages to insure the problem has been resolved.
    IF YOU NEED TO BE WITH THE ORIGINAL CATRIDGES PLASE FOLLOW THE BELOW STEPS.
    ALWAYS PREFER LEXMARK CATRIDGES FOR LONG LIFE OF PRINTER
    1. Remove the indicated print cartridge.
    2. Disconnect the power cord from the electrical outlet.
    3. Reconnect the power cord to the electrical outlet.
    4. If the button_power_0.jpg button is not lit, press button_power_0.jpg.
    5. Reinsert the print cartridge.
    6. If the error:
      • Does not reappear, the problem has been corrected.
      • Reappears, replace the print cartridge with a new one.
        BESTWISHES.....
    Dec 19, 2010 | Office Equipment & Supplies
    How do i install the ink cartridge in my lexmark z35 printer
    Oct 31, 2010 | Lexmark Computers & Internet
    My roller dont take in the paper
    MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error. The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix. When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
    Jun 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
    Error E3 when no paper jam
    E3 Error
    Aug 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    What is error 0xc18a010a on for the 8250 hp printer
    If you are not using HP ink cartridges you may have trouble. I was using Rapid Refill cartridges and had the same problem. I returned them and was told that a new chip has been installed in hp cartridges, so you need to make sure that the cartridges have this chip. Rapid Refill set me up and have not had any problems since.
    Aug 19, 2008 | HP Photosmart 8250 InkJet Printer
    HP PhotoSmart 1115 InkJet Printer Logo
    102 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
