Question about Microsoft Windows XP Professional x64 Edition for PC
How to configure FTP server in windows xp prof ?
Hi
I need help for configuring the FTP server in win-XP Prof . Please tell me your suggestions.
Thanks.
Padmaprabhu
  • 2 more comments
  • shiva_mkv Jul 28, 2008
    How to configure the FTP in win xp sp2. Kindly let me know if you have any solution.
    Thanks,
    Siva.
  • Anonymous Aug 19, 2008
    I get this message " install and configure system components" when trying to enstall a cd
  • Anonymous Sep 27, 2008
    how to create users in ftp server in windows xp proffessional
  • Anonymous Oct 06, 2008
    sir pls help me creatin ftp sites in winxp
    Scholar:
  • 117 Answers
Setting up an FTP site Using Windows XP Professional Windows XP professional (as well as Windows 2000) includes Microsoft's IIS (Internet Information Server) which can be used to create an FTP site on your computer. It's a fair bit less complicated and less flexible than using some third-party FTP server software packages, so we will give you guides for setting up both. If you are using XP Home you will need to use third-party software. There is no way to publish an FTP site with the Home Edition of XP.
The first step is to check that IIS (Internet Information Services, Microsoft's web-server application) is configured properly.
Go to start\'control panel'\'add/remove programs'\ choose the 'add/remove windows components' button from the bar on the left. Highlight the item 'Internet information services (IIS)' If it is unchecked, check it, then click 'details.'
The components you will need are: 'common files,' 'file transfer protocol (FTP) service' and 'internet information services snap-in.' Uncheck any others then click next. IIS will configure itself, and you may be prompted for the XP CD.
Posted on Mar 22, 2008
  • Terry Lynn Deschamps
    Terry Lynn Deschamps Mar 22, 2008
    Beginners Guides: Setting up an FTP Server in WinXP - PCStats.com
    www.pcstats.com/articleview.cfm?articleid=1491&pag...
    Configuring hardware firewalls for FTP
    Advertisement
    Home Internet sharing devices
    like Cable/DSL routers are very common, and almost all come with some form of
    firewall that is enabled by default. To successfully pass FTP traffic through
    these devices, you will need to create a 'virtual server' entry in the setup of
    your Internet sharing device. Pictured below is an example of this from an SMC
    Barricade home DSL/cable router.
    A virtual server is an instruction to your Internet sharing device
    telling it to forward any traffic it
    receives on a specified port to a specific computer inside your network. For
    example, if you create a virtual server for port 21, IP address 192.168.5.220,
    your internet sharing device will listen for traffic coming in on port 21, then
    pass that traffic through the firewall to the computer with that IP
    address.
    Though the instructions will vary depending on the brand of your
    device, what you will need to do is find the 'virtual server' setup section (or equivalent),
    and specify the IP address of the computer that is running
    the FTP server (to find this, go to start\run and type
    'cmd' then 'ipconfig.'). You will
    need to enter port 21 for data coming into and out
    of the router.
    Once this
    is saved, FTP information will be able to pass through your firewall. For more
    information on firewalls and their configuration, see our Beginner's guide to firewalls and Internet security here.
    FTP security
    Important topic.
    The problem with FTP is that, by default, it is an extremely
    insecure protocol. Usernames and passwords are not encrypted in any way
    when they are sent from the client to the server, and so are
    prime targets for anyone intercepting network packets between your server and your
    clients.
    This is the reason that the Windows FTP server software recommends that you use only anonymous access for your FTP site,
    as the alternative is to use valid user accounts from your XP
    installation.
    If these credentials are intercepted, they could be used to
    severely compromise the security of your entire system, never mind your
    FTP site. Hence the recommended practice for home users is to allow anonymous
    access to the FTP site directory and simply not place sensitive files
    there. Obviously, this is not going
    to meet everyone's needs, so there are alternative methods of securing FTP
    transactions.
    Generally
    speaking, these involve using SSL (Secure Socket Layer) or some other encryption
    method to encrypt the plain FTP information, creating a secure channel between
    the client and server. Ffor more information on SSL and other methods of
    encryption, see
    PCstats' Beginners Guide to encryption here .
    Most third-party FTP server software packages support encryption as part
    of the FTP program itself, but using IIS for Windows XP,
    the only possible method of security is to use a method
    that encrypts all traffic between the server and a specific client, such as
    a VPN (Virtual Private Network). For more information on how to set up Virtual
    Private Networks,
    see PCstats' Guide.
    Serv-U
    supports creating an SSL certificate within the program for encrypting traffic,
    but only in their commercial versions of the program. The free personal edition
    does not have this feature.
    So to sum up, unless you have
    specifically placed security measures, assume that all FTP traffic is inherently
    insecure. Therefore, don't put data in your FTP site that you would not want
    seen by the general public. Don't be scared away from it though, since the fact
    that anyone can access your FTP site does not affect the security of the rest of
    your system unless you are using your Windows user accounts with IIS.
  • 24 Answers
I would get an FTP Client Called Core FTP Lite, and it is a very good, feature packed Client.
SM
Posted on Apr 08, 2008
How to configure FTP server in vista home basic
I don't believe that Home Basic has an FTP server component built-in. Try a free alternative, such as NcFTP server.
Feb 11, 2010 | Microsoft Windows XP Professional x64...
Will try to make a long story short...Attempting to install Windows XP Prof. on a friend's IBM NetVista 6645 Model W2U which he purchased from someplace. It already has XP Prof. installed, but my friend...
Can you get into the BIOS configuration to enable the CD and USB drive?
If so enable these devices.
Check the interior of the desktop to see if the CD drive and USB connectors are still connected.
Nov 02, 2009 | IBM NetVista PC Desktop
Ethernet cotroller drivers for Win XP Prof
Here is a link to an excellent tutorial that will guide you through the process of updating drivers in XP.
It has instructions for opening the Device Manager and finding out what hardware is installed in your system. Then you need to go online from another computer, download the appropriate drivers and burn them to cd, load this cd in your computer, then update the drivers on your system from the cd. You can drag the setup files to your desktop and install them from there.
I hope this information allows you to resolve this issue. If I've managed to answer your question or solve a problem, please take just a moment and rate this post....thanks!
Mar 31, 2009 | Microsoft Windows XP Professional With...
Problem while installing Win XP Prof.
The prolem is with Windows Xp cd...
When i try to install through the Genuine Win XP cd then it works fine...
Ok...
So use the original softwares....
Feb 16, 2009 | Intel DG31PR Motherboard
Driver for compaq cq50-106au with win xp prof
Your audio card is the conextant High Def Audio
The XP drivers for this card are here
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32823.exe
Hope that helps
Aug 22, 2008 | Compaq Presario Notebook
H D Audio Driver fails to install
Have you checked to see if the driver is already installed, and the volume is just turned down? (Start> programs > accessories > entertainment > volume control) If so, try going into Device Manager (right click My Computer > properties > hardware > device manager) See if the sound card is showing up there as a yellow question mark or other error icon, it will stand right out. If it's there, right click, and uninstall it. Now (still in device manager) press the button that looks like a computer screen with a magnifying glass on it, that will scan for hardware changes and pick up the sound card, which windows includes the driver for automatically. If this still doesn't work, try downloading from realtek here, and installing that. Hope this helps.
Jul 17, 2008 | Microsoft Windows XP Professional With...
Windows Vista home + Windows XP Professional Networking issue
Make sure domain settings to your server are correct on the notebook computer. These settings are located in the control panel of the system setting.
Whats the operating system of your server?
Make sure the firewall in windows security is turned off too. Sometimes that thing sneaks up on you.
I haven't used the home edition of Vista but another reason why it might not be working is because it isn't the business version. Microsoft might have added extra security to prevent the home version from connecting to a server. I know we use the business version of Vista at work and it is working that way on the intranet server without a problem.
I would check with Microsofts website on that.
Jun 21, 2008 | Microsoft Windows XP Professional for PC
AUDIO DRIVER FOR WIN XP PROF.
make sure u have the correct audio driver for ur motherboard if all else fails try going to motherboard makers web site and downloading from there
Jan 24, 2008 | Intel SVM266A VIAP4M266A (SYNTAX SVM266A...
Microsoft Windows XP Professional x64 Edition for PC Logo
7,270 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
