Tweeter "drive" out on wharfedale svp - 15
I have a set of wharfedale pro svp-15's and by process of elimination i found that the back pannel that holds the parallel inputs doesn't push my horn anymore can u point me in the direction of where can i find parts that i can order thanks bertsteen@aol.com
    Sniper:
  • 109 Answers
It has a bulb in it. Per the manual. www.wharfedalepro.com
Posted on May 01, 2009
  • 1,512 Answers
Hi bertsteenrt
Can you check the resistance of the HF driver(tweeter). If it is open it will need a new diaphragm. Most of these speakers use a lamp to act as protection for the HF driver. Sometimes these lamps fail. You will need to pull the horn out of the cabinet to check, and the rear connection panel off to get access to the crossover where the lamp is located. Get back to me here and I can talk you through fault finding the speaker.
regards
Graeme
Posted on Mar 21, 2008
I require 2 wharfedale 708 tweeters . Where can l purchase them ?
Probably best to buy a pair of Wharfedale 505 or 507 speakers just for the drive units - they are exactly the same and can be picked up for £40 a pair
Apr 17, 2014 | Audio Players & Recorders
Can't get wharfedale melton 2 tweeter to work. Looked inside cabinet and need advice on internal wiring please. These are very old but one works perfectly and the 12'' bass driver on the problem speaker is...
The tweeter has burned out and cannot be salvaged. I also own a pair of (ex) Melton 2s. In the beginning Wharfedale were good at supplying spares (see www.wharfedale.co.uk for contact info and advice). A few years ago after my cat destroyed the 12 inch unit in one, i invested in new insides, including state of the art 12 inch woofers, 4 inch mid range and 1inch tweeters with a good 3 way crossover. The cabinet is great so consider asking a techie friend to do this for you. Please don't just cut out and connect to amp speaker wires! You will get terrible sound and risk ruining both amp and speakers! Best regards Karl (karl@simpson.nom.fr)
May 12, 2010 | Audio Players & Recorders
I have 1 set of wharfedale speakers valdus 400 .power handling (programme) 150W .normal impedance 4-8ohms.1 of the tweeter is not working .please advise how to repair asap ,thanks
you should first try if the driver is really gone or not, maybe it's just a wiring problem, also there can be something wrong with the cross-over network. Check the tweeter with a multimeter, if you don't see something between 2-16 ohms, you need a new one (or two, you probably won't be able to find the original part, so you'll have to change both left and right channel drivers) but if you see the desired impedance on the meter, check the internal wiring, crossover solder joints, capacitors, etc. I hope this helps.
Jan 03, 2010 | Wharfedale Valdus 400 Speaker
My wharfedale titan 15 passive loudspeaker only sounds the tweeter but not the driver
If you have never overdriven the speaker, it'll probably be a dry solder joint in the crossover. Take all the screws out the back panel, the crossover is mounted on that. Unscrew the crossover board, redo all the solder joints, finaly make sure the cheap spade terminals are connecting to the speaker properly, then put it all back together. You can check all the connections if you have a multimeter. Same happened to me.
Dec 23, 2009 | Audio Players & Recorders
Tweeter broke need replacement wharfedale
Just google the brand name of your reveivers and ask link site of thier service center so you can order the spare for tweeter don,t forget give also the model number.
Hope it may help you;
Regards;
VOTIT
Jan 02, 2009 | Audio Players & Recorders
Tweeter not working on 15" EON G2
I have the same problem and the same conditions.
The tweeter is good, 3.8 ohms.
Some points of solding (donuts), have bad aspect.
I resolder the power transistors to the PCB and I solve the problem.
Jun 05, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Wharfedale Modus One
The tweeters are probably blown, i had the same problem.
You can test this by placing the cable on the dismanteled crossover at the back of the speaker. colour blue/yellow.
No high volume please.
See http://www.hometheatershack.com/forums/diy-speakers/4549-wharfedale-modus-one-six-crossover-pics.html
for pictures.
If the tweeter is blown it can be dismanteld with the aid of a screwdriver, horizontally.
Place it between the tweeterbowl and the ring which has the mark wharfedale on it. The tweeter comes loose. On second hand sites you can buy little speakers, like modus one or two's with the same tweeters for a good price and put them on your larger speakers.
This how i repaired 2 of my 4 modus eights.
good luck Danny Mol
the netherlands
Jan 15, 2008 | Wharfedale Modus One-Six Speaker
Tweeters only works when touched!
This is not a solution, but I have the same problem. Obviously, the problem is with the tweeter not the crossover. I can't find a replacement tweeter so i am about to take it to my local stereo repair store and see if they can fix it. If you find a replacement tweeter, let me know.
Oct 13, 2007 | Audio Players & Recorders
488 people viewed this question
 Grubhead
Grubhead
