Teac hdb820 I was not getting channels on the tv and thought that it was because of the set top box, so i set the box back to factory settings and then tried to re-tune the channels. Now the box won't do anything. The digital display on the front of the box has P00 displayed and it will not even display the menu on the tv when the menu button is pressed. The only thing that seems to work on the remote is the on off button.
  • joepor1981 Sep 16, 2008
    my teac hdb820 set top boxe says no service list so i tried to re tune the channels and had no luck, then i tried to restore factory settings and it still would not work, the display on the front panel says P00. nothing else seems to work, can anyone help me?
  • dezsmitty82 May 15, 2009
    i have the same problem with my teac hdb820 nothing works says p70 on box and only switchs on and off no other functions work.. cant even get a menu signel
I just did a factory reset this morning and I had the same problem until I realised that you have to use the "Output" button to get the Video Outputs to DVI Digital (see page 17 of the manual), if that's what your connection is, then I could select "menu" and do a channel search. Hope this helps.
Posted on May 30, 2009
I set up teac HDB840 to tv- via coxial cable from wall to set top box, then rca cables output of set top box , then to input to tv.-tried av button on tv showing av1 av2 and av3 but still no picture only...
Hi, Your set top box (PVR) is running on channel 3 or 4. Go to menu and sellect a source TV, DVD
Note: Do not connect more than 1 set of cables to tv or you may damage something.
TV > box connect RCA cable or HDMI not both.
Set top box > connect RCA or HDMI Not both.
audio devices > TV connect RCA or HDMI not both.
Good luck.
Jun 18, 2011 | Televison & Video
Reset All Settings *Back to factory*
Unplugs everythings like all those cables boxes and the tv also,replugs the tv and those cable boxes,like Time Warner,Telecoms companies Veizon,AT&T,Dish Network,Direct tv boxes about an hour later.Let those boxes updates it softwares.Go in ur tv menu.Go to the menu selection PICTURE,go down select reset.That should reset the incomming broast Tuner board in the tv.Go to tv menu AUDIO,go down to reset.That should reset the audio setting.Now all those boxes have it updates softwares,and the tv reset it back to the factory setting.Now go to tv menu,go to SETUP,go down to CH. setup pick CABLE not AIR.Now the tv will go into scan modes to pick all those cable channels incomming broscast that ur pay for.
Jun 02, 2010 | JVC HD-52G786 52" Rear Projection HDTV
Failed tv reception after about an hour????
Witout knowing your set up I can only guess at the set top box getting hot and failing.
Is the Teac box well ventillated? If not, put it somewhere where it can get cool air (ie not enclosed in a TV cabinet for instance).
I doubt it's your antenna if it works for a while, but you maty want to have your coax connection checked out. If you use a booster, that may be failing.
Sorry I can't be of any further use.
Jan 13, 2010 | Televison & Video
Could you tell me why the tv insignia channels swich fron 2 to 3 channel, and the tv value is going up and down by itself? Because I"m not able to watch my programs. Can You help with this?
if you have set top box ,go to main menu ,check on restore factory settings ,put in default password 0000 and press ok,restarting the set top box automatically,waiting for some minutes.
restarting starts scanning all channels one by one and put them on their respective location in channel store.
now ,enjoy with all channels.
same process is done with tv if u have't any set top box ,only RF input from ur cable operator.
Nov 29, 2009 | Insignia IS 20" TV040919 TV
We cannot get our hdb841 to tune into our awa hd
Hi! I believe you have some concern on how to get good picture on your hd tv. I will be more than glad to assist u.. on your teac hdb841- there is a port connection - ant in, you have to connect the ant cable from your off the air tv antena to the ANT IN of the Teac HDB841. then on the back of your Teac HDB841, you have several output connection there like component, coax, s-video, rca and hdmi. since u have the hdtv u need to use the hdmi or the component cable whiich is the red blue and green then access the menu of the teac hdb841 and do a scan for the local channels.. ur tv should tune in to hdmi if u use hdmi cable or component if u use the red blue and green.. i hope this will fix the problem..
Aug 24, 2009 | Televison & Video
Set top box installation
RF is the normal round coax cable in black.
Further you need to select your video channel on TV to watch the set top box RF signal. Usually you change the RF channel frequency also on these things. If you don't know channel number let TV scan it.
Apr 18, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
I dont have manual and i am trying to find and set channels on my teac sdb450 set top box
43D8UXA Toshiba TV - DVD playing with sound. No picture on tv, Playing normal tv but not DVD.
worked 2 days ago. How do I adjust the tv to get picture?
Jan 24, 2009 | Televison & Video
I have just installed a Teac SDB451 set top box for a friend and I have installed antenna to it then used the video and audio outs to their vcr and vcr to their TV. I can get a picture using the set top...
Go to http://vk3khb.gak.net.au/atv/chnlchrt.html#TV_Table
I went there and checked the details vs those appearing on my STB. Went through the manual channel search and changed the frequency to those on the above website. Now all channels work perfectly. I only bought this STB because my last one froze, it appears this one doesn't have the best auto search facility but with a bit of tinkering it will work for you!
Aug 30, 2008 | Televison & Video
TEAC EU68ST - No AV Channels
Look for a "reset to factory defaults" option, if available, use it then retune for your TV channels. Don't know the particular set.
Mar 26, 2008 | Televison & Video
Televison & Video Logo
614 people viewed this question
Top Televison & Video Experts
