Question about Apple MacBook PC Notebook
MacBook opening screen leaves a one inch black strip on both sides.
Anyone know how to expand this screen?  I can expand all applications. Just not the opening screen which limits my ability to expand applications to full screen.
  • 1 more comment
  • jaycoure Apr 27, 2008
    When I open the internet my screen will not expand fully.  When I hit expand it only gets a little bit bigger and when I hit expand again it just gets smaller.  I can't figure out how to get the screen to the full size of my computer screen.
  • Anonymous Feb 24, 2009
    Display is smaller than screen. Edges black now.
  • tallgrass May 11, 2010
    What color is your screen?  Have you worked with your preferences folder any?  Uploaded/selected any pics for your screen pic?
    haven't seen this before.
    Linda H.
    mac
Use the gray bar on top to move the screen to the upper left hand corner.  Then click and drag the bottom right portion of the screen to the size that you want it be.
Posted on May 24, 2009
I have one white line across my screen about a mm thick 1/3 of the way down on my MBP.  It is 1.5 years old 15.4 screen.  Thanks Ben
Posted on Apr 01, 2008
4 Suggested Answers
  • 25 Answers
SOURCE: My macbook pro makes the startup noise then just stays black
There's a magnetic reed switch in there, to the right of the mousepad. It's activated by a magnet in the screen, so when you close the lid the reed switch closes its circuit and the machine goes into standby. It's common for it to fail. To get your machine to start up again you'll have to remove the problem: open up the case and find that switch. Unplug and remove it and you'll find your problem is solved, although you will of course need to put it to sleep from the Apple menu from then on - it won't do it automatically any more. You can get replacement reed switches but they're not cheap.
Hope that helps!
Matt
Posted on Aug 25, 2009
APPLESUPPORT
  • 70 Answers
SOURCE: Hanging blue screen on 13-inch MacBook
The issue is with the software.Boot the system with installation media and go to disk utility and repair the file permission.This can solv the issue.If still the issue persist.Then go ahed and format the drive and re install the software
Posted on Apr 12, 2010
  • 10406 Answers
SOURCE: Dear sir How can I expand
Point the mouse at the bottom-right corner of the browser's window, and click-and-hold on that corner. Then, "drag" the mouse-pointer both "down" and "right", and then release the mouse.
Posted on Apr 21, 2011
How can i remove the dvd from my mac, it is stuck. macbook pro 17 inch
A few ways of doing this
restart mac and press down the trackpad after you hear the startup noise
if that does not work try opening up disk utility and click on the icon of your disk under the left hand column then go up to eject button and click eject
or open up terminal found in the utilities folder within your applications folder and then type in
drutil tray eject and then press return
Finally what to do is try pick up your macbook tilt the macbook to the one side and ise the eject key and hopefully the effect of gravity will allow the DVD to fall out.
One other way to do it which I have used recently but IT CAN BREAK THE DVD DRIVE, so only use it as a last resort. Get a thin piece of plastic and put a piece of double sided tape on it then with the macbook switched off insert the piece of plastic with the tape facing down in relation to the keyboard. Put it in about half an inch and you may be able to drag the dvd out.
Hope this helps.
Sep 27, 2010 | Apple MacBook Pro 17-inch 2.4GHz Notebook
Screen shrunk and can't be changed?
It sounds like the display somehow simply got set to a different resolution. Open System Preferences / Displays and choose a resolution that satisfies you.
Jul 13, 2010 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Headphone jack must be moved around to get right speaker working
You will find that sound comes from the right side speaker only when it is bent at a certain point. By trial and error you can roughly locate the point. Then you can cut the wire at that point, cut 1 inch each from both ends, strip the cables, and connect the conductors. What has happened is, due to unusual bending, the conductors to the right-side speaker has damaged (broken). After roughly locating the place and removing 1 additional inch each, you will remove the wire section with the broken terminal. Now you can strip the wires and make the connections again. If you are not good at stripping and soldering wires, better to to take it to an electrician. (You need to take only the headphone pin and parts attached to it). This repair won't cost much. Good luck!
Jun 25, 2009 | Logitech Z-2300 Computer Speakers
Strips of 2 inch wide black and white, running top to bottom
Definately a damaged screen, no way to fix it for less than the cost of a replacement screen sorry.
Jun 16, 2009 | Philips 200P4 (Silver/White) 20.1 in. Flat...
If we close the screen a little bit it goes bright white. Have to switch off and restart. Also, after doing a power point presentation the display is only opening about 80% of full screen with a black...
In LCD screens is a common problem that after setting a lower resolution than recommended you'll see a black stripe sometimes up and right, right click on any empty spot on your desktop and select properties then go to display options and move the resolution bar to a higher point and click apply also click yes in the warning display and accept.
Regards.
Jun 15, 2009 | ASUS A6Ne Notebook
I have a Samsung SCX-4725FN & it is leaving black marks 2 inches apart on the left hand side of anything I print.
Ddcorbin.... lift the cover... on the left side of the plate is a long black glass strip. wipe that glass strip with a soft towel. i used windex. the black mark should be go away.
Apr 11, 2009 | Samsung SCX-4725FN All-In-One Laser...
MacBook Repair Application
I believe you will need to download Stuffit Expander. We used to use SEA files a lot in the old mac days, but now they've been replaced by the DMG file. Anyway, Stuffit has a free version that can be found here. Since they don't make it extract itself on the new Macs, you need a program to do it now. If that doesn't work, you might have a corrupt file or something else. Let me know what happens.
Sep 07, 2008 | Apple MacBook Mac Notebook
When turning on my macbook pro
Does it work with an external?
1) If it does boot through external. Your LCD, LCD inverter, or LCD cable may need replacement.
2) If it does not boot, then it may be problems with video card or motherboard problem. May need motherboard replacement.
Please let me know the follow ups of it. Thanks!
Mar 03, 2008 | Apple MacBook Pro Laptop Computer with...
2 inch Black strip on screen
It all depends where this strip is and exactly how wide it is, it could be a panel problem or one of the pcb's that control that part of the screen, if you can post a photo of it, I can tell you what is wrong with it.
Apr 02, 2007 | NEC PX-42VP5HA 42 in. EDTV-Ready Plasma...
Apple MacBook PC Notebook Logo
1,352 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
