Question about Compaq A1000 InkJet Printer
How to program new fax number
How do I program a new number in the fax machine?
Moved the fax to a new location and I need to change date/time. It also sends faxes fine, but will not receive. How do I fix these problems? Can not locate manual.
Thanks,
Posted on Sep 11, 2008
    Genius:
  • 3,587 Answers
It's on the menu..under speed dial
Posted on Mar 21, 2008
How do i change programed number
Hello Ms Nelling,
You can change the programmed numbers by simply programming new numbers on the saved position.
Press the MENU/SET button and select FAX \ Setup Quick Dial and then choose whether you want to program a speed dial or a one touch button.
If you had previously programmed a 1 touch on button 3, just select that 1-touch and it will ask you if you wish to change the current settings.
Thanks,
Pat
Apr 14, 2011 | Brother IntelliFax-2820 Laser Fax
I would like to pre program a new fax #. add it
1. Press function 64 set to print out a directory.
2. Press function 72
Choose 1 touch
set
press the next available number with the small yellow numbers such as 02
enter fax number
set
enter name
set
Continue or press STOP
Mar 27, 2010 | Panasonic PanaFax UF-8000 Laser Fax
Our Brother intellifax 2800 won't receive some faxes
Not entirely positive but it looks like you need to enable "polling" on your machine. I think it's a way to ensure they don't send out personal medical info to a wrong number by mistake. If polling is enabled, they've already determined that your machine is expecting a call from theirs.
To enable polling on your machine:
  1. Press Menu/Set 217
  2. Use Up/down arrow to turn on polling
  3. Enter the fax number you're polling
  4. Press Fax Start to dial that number
  5. Press Menu/Set
I hope this works for you. All the best!
Greg
Jun 17, 2009 | Brother IntelliFAX 2800 Laser Fax
I want to send a fax message using Brother 2820 fax machine, but I don't want the receiver to see my phone number when he receives the fax message print out. Is there any way I can do this?
The FAX machine will print the Tel number that has been programmed in your machine. It does not print on the basis of the caller ID received. So i think if you remove the number programmed in your fax machine
May 23, 2009 | Brother IntelliFax-2820 Laser Fax
Trouble transferring to another fax machine
error 330 is bad news the power supply needs repair. First press the data registration button scroll down to file settings and press set scroll down to transfer and press set depending what was programmed you can start new and program in the fax number to where its going and select which days and time when you want it transferred. When you are finished you must push the TRANSFER button underneath the one touch panel for this feature to take effect. It will say transfer on the display.
Mar 26, 2009 | Canon LaserClass 7000 Plain Paper Fax
Letters vs. numbers
After you put in the number with the hard buttons press set twice, then enter letters for the NAME with the soft buttons on the left side.
Jan 19, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
Panasonic UF-890
Take the swinging drum cover off of the toer cartridge and throw it away. It's only for shipping. They come loose and block the paper path.
Put the number you want to forward to in a one touch number position. (if you have to dial 9 for an outside line, be sure to put that into the one touch number also).
Function 74 set 54 set 2 for valid set stop.
Answer to last question, probably...not.
Aug 28, 2008 | Panasonic Panafax UF-890 Plain Paper Laser...
Instrution book for 8860 DN
I have a Brother MFC 8860DN Network Fax machine and I need to program some phone numbers on it for automatic fax. I don't have the book to follow the steps to program it.
Nov 21, 2007 | Brother Office Equipment & Supplies
Fax Numbers-Memory?
Unfortunately that is a function of the sending unit. If they did not program their number in, then you won't have a record. If this is a persistent problem, you may want to sign up for Caller ID. Even if they put the paper in upside down, your fax will still print a head on top of the page with the information they have programmed. If they program a wrong fax number, then all you will have is a wrong number. Wish I have better new for you. Ed
Jun 13, 2007 | Muratec M1250 Fax
Compaq A1000 InkJet Printer Logo
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Tony
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
